How to maximize my SSD? - Overclock.net - An Overclocking Community
post #1 of 15 (permalink) Old 04-08-2012, 09:56 AM - Thread Starter
Rep: 70 (Unique: 53)
Hey guys, recently just put together that rig in my sig. Needless to say, its a beast.
But I wanted to make sure I have my ssd right and I am getting the full potential out of it. Advertised read/write on the disk is 500+mbs and it is a sata 3 ssd. I have it plugged up to a sata 3 port and have the controller set to ahci as well.
When using 7 zip to extract large files the max read time was averaging at like 120mbs. Not sure if this is the best way to test it, as I'm assuming the bottleneck in this operation is my ssd. I looked up some simple tips on youtube that had me disable little things here and there in windows that got me up to a starting 220mbs or so but it slowly throttled all the way down to 150mbs or so.
So how to I utilize the full potential of my ssd?
Outlawed is offline
post #2 of 15 (permalink) Old 04-08-2012, 11:55 AM
strych9's Avatar
Rep: 91 (Unique: 67)
Have you gone through this thread?
strych9 is offline
post #3 of 15 (permalink) Old 04-08-2012, 12:18 PM
kaivorth's Avatar
Rep: 435 (Unique: 364)
Reinstall and follow that thread step by step.
My System
(12 items)
Ryzen 5 1600
Asrock B350 Fatal1ty ITX
Asus GTX1060
G.Skill 8gb 3000mhz
250gb Samsung 850 Pro
Optical Drive
SATA LG DVD Burner
EVGA 500w Gold
EVGA Hadron Air
Operating System
Windows 10 Pro X64
23" Asus 144hz
Keyboard
Microsoft Ergonomic 4000
Mouse
Logitech G Pro
kaivorth is offline
post #4 of 15 (permalink) Old 04-08-2012, 12:42 PM - Thread Starter
Damn, I knew there were probably other things required to optimize it from a fresh windows installation.
Well wish I wouldn't have put in all the hours to getting everything setup on this partition already :/
Thanks for the help guys!
Outlawed is offline
post #5 of 15 (permalink) Old 04-08-2012, 12:46 PM
Rep: 83 (Unique: 67)
psyside is offline
post #6 of 15 (permalink) Old 04-08-2012, 12:54 PM - Thread Starter
Mushkin Enhanced Chronos 240gb sata III
Outlawed is offline
post #7 of 15 (permalink) Old 04-08-2012, 12:56 PM
Storage Nut
Sean Webster's Avatar
Rep: 1661 (Unique: 967)
Post a screenshot of AS SSD.
http://www.alex-is.de/PHP/fusion/downloads.php?cat_id=4&download_id=9
No need to reinstall. Just look it over from the "Now It's Time For The System Set Up!" section.
Originally Posted by psyside View Post
What kind of SSD?
This^
SSD GURU
Storage Essentials | My Server Build Log
"Some say he once took a backup of the entire NSA database. Others say he lays SSDs like chickens lay eggs. All we know is, it's Sean Webster!"
Main Rig
(15 items)
Terrorbyte V2
(16 items)
i7-6700K @4.6GHz
ASRock Z170 OC Formula
Gigabyte GTX 960 WindForce 2X OC
32GB Patriot Viper Elite @2666MHz
480GB ADATA SX8200
1TB Samsung 960 EVO
2TB HP EX950
Corsair RM650
Thermaltake Silver Arrow
Fractal Design R5
Operating System
Windows 10 Pro 64-Bit
BenQ GW2765HT
BenQ GW2765HT
Keyboard
Patriot Viper V760
Mouse
Patriot Viper V560
Intel Core i7 4790K
ASUS Maximux IV Extreme
32GB (2x 16GB) Corsair Vengeance Pro @2.4GHz
2TB WD Red
2TB Samung Spinpoint F4
2TB Hitachi Deskstar 7K3000
1TB Samsung Spinpoint F3
3TB Toshiba DT01ACA300
3TB Seagate Barracuda 7200.14
8TB HGST Ultrastar He8
4TB Seagate Barracuda
Corsair 650TX
Norco RPC 4224
Operating System
Windows 10 Pro 64-bit
Other
LSI 9261-8i
Other
Intel RES2CV240
Intel Core i7 9700K @5GHz
ASRock Z390 Taichi Ultimate
16GB (2x 8GB) Kingston HyperX Predator RGB @3.6GHz
Intel Optane SSD 905P 1.5TB
EVGA 500W
Noctua NH-U14S
Operating System
Other
ASRock TB3 AiC
Sean Webster is offline
post #8 of 15 (permalink) Old 04-08-2012, 01:18 PM - Thread Starter
SSD is a Mushkin Enhanced Chronos 240gb sata III
I initially installed windows the the sata controllers set to raid. I was under the assumption that this was the biggest and best. So everything ran fine but I couldn't get it to show my old hdd with all the old windows files on it, that I wanted to use as a slave.
Posted around on here and figured out I needed to set it to ahci. After changing this (without a new install), slave showed up fine with all the files.
As stated, I have done a little bit of research via youtube videos and followed some users instructions of how to change settings here in there in windows to help speeds. Other than that though, nothing has been done.
Also I don't mind doing a clean install if you think it will make a more efficient difference. Usually always seems to be the best option in most cases. Might have put some time into this system,, but its still build weekend so I can't say I didn't expect for something like this to happen :/
Outlawed is offline
post #9 of 15 (permalink) Old 04-08-2012, 01:24 PM
Storage Nut
Looks about right as that drive has asynchronous NAND which is less than half the speed of synchronous NAND when it comes to handling compressed data.
If you want faster speeds you should have gotten this drive: http://www.newegg.com/Product/Product.aspx?Item=N82E16820226226
or something more expensive.
If you want to see the speeds that are advertized benchmark with ATTO: http://www.softpedia.com/get/System/Benchmarks/ATTO-Disk-Benchmark.shtml
SSD GURU
Main Rig
(15 items)
Terrorbyte V2
(16 items)
i7-6700K @4.6GHz
480GB ADATA SX8200
1TB Samsung 960 EVO
2TB HP EX950
Corsair RM650
Fractal Design R5
Operating System
BenQ GW2765HT
BenQ GW2765HT
Keyboard
Patriot Viper V760
Mouse
Patriot Viper V560
Intel Core i7 4790K
2TB WD Red
Corsair 650TX
Norco RPC 4224
Operating System
Other
LSI 9261-8i
Other
Intel RES2CV240
EVGA 500W
Noctua NH-U14S
Operating System
Other
ASRock TB3 AiC
post #10 of 15 (permalink) Old 04-08-2012, 01:31 PM - Thread Starter
That sucks. SSD is one of the newer technologies that I haven't really messed around with. Should have researched it a little more before I just purchased one straight off of newegg reviews and details.
I saw read/write speeds of 500mbs+ on the details so figured thats what I would get with a sata III port :/
I believe 7200rpm hdds get around 120mbs read/write. So I really expected even the lower end SSDs to be exponentially faster, not just like 40mbs faster...
Outlawed is offline
