Samsung 840 EVO read speed drops on old-written data in the drive - Page 137 - Overclock.net - An Overclocking Community
post #1361 of 3282 (permalink) Old 12-05-2014, 06:00 PM
SATDK's Avatar
Rep: 9 (Unique: 6)
Originally Posted by Darkknight512 View Post
I just ran a test on my drive again, no problems at all about 2 months after the fix. 360 MB/s sequential read across the board, it was 385 MB/s sequential read with my setup right after the fix.
SATA3? Those both sound low.
What utility are you using to get those numbers?
SATDK is offline
post #1362 of 3282 (permalink) Old 12-10-2014, 08:22 AM
ReptilesYo's Avatar
Rep: 0
This issue has not been fixed, see image (2 months post patch). I will be returning the drives I have purchased for our organization to Samsung as defective and will be avoiding their 850 Evos as well. Crucial has won my business.
ReptilesYo is offline
post #1363 of 3282 (permalink) Old 12-10-2014, 10:50 AM
AMD Overclocker
Alastair's Avatar
Rep: 261 (Unique: 163)
Can anyone confirm as the problem is fixed? If not how do I go about an RMA?
If You Can Cool It! You Can Clock It! (AMD's Vishera)
GHOST rev 4
(26 items)
Rura Penthe
(12 items)
AMD Ryzen 7 3800X
Gigabyte Aorus X570 Pro Wifi
MSI VEGA 64 WAVE
Avexir Core 2 3600MHz 18-20-20-44
Samsung 850 PRO 1TB
WD Blue 500GB
WD Blue 1 TB
Samsung Spinpoint HD502HI
CoolerMaster V1300 Platinum
XSPC D5 Bay Res
1x CoolerMaster Storm Force 200
XSPC Raystorm CPU Block
EKWB Coolstream PE360
6x CoolerMaster Jetflo's 120mm
XSPC D5 Vario
EKWB Coolstream CE280
6 Corsair ML140's
Barrow Vega 64 full cover waterblock.
NZXT Phantom 820 Black
Operating System
Windows 10 Pro 64-Bit
Dell SE2717H
Keyboard
Roccat Ryos MK Pro
Mouse
Mionix Naos 7000
Mouse
Mionix Alioth
Audio
GX Gaming SW-G2.1 3000
Audio
Kingston Hyper X Cloud Core
AMD Athlon 860K
Asus A88X-Pro
MSI R6850 Cyclone Power Edition
G-Skill Ares 2133 CL10 8GB (2x4GB)
Seagate ST1000VX003
Optical Drive
Samsung HD502HI
Seagate M12II 620W
Arctic Cooling Freezer A30
Corsair Carbide SPEC-02
Operating System
Windows 10 Home Edition 64bit
Keyboard
Razer Lycrosa
Intel Celeron G1840
MSI Z97-Guard Pro
Gigabyte RX580 Gaming 4G
Gigabyte RX570 Gaming 4G
XFX RX480 reference edition 8G
Gigabyte RX570 Gaming 4g
G-Skill Ares F3-1600C9D
Samsung 750 Evo 120GB
Gigabyte XP1200M
Stock
Operating System
Windows 10 Pro
Alastair is offline
post #1364 of 3282 (permalink) Old 12-10-2014, 11:20 AM
trparky's Avatar
Rep: 38 (Unique: 19)
I wouldn't trust the results of that program. It's an old program that's no longer supported by the people that wrote the program and requires Windows compatibility to run on modern versions of Windows and who knows if the compatibility layer is messing up the read speeds.
So far I've not had any issues with my SSD and I ran the fix on my SSD the day that the fix came out.
Check the SSD with something like HD Tune instead and then post benchmark numbers.
Tom
trparky is offline
post #1365 of 3282 (permalink) Old 12-10-2014, 11:45 AM
ziggystardust's Avatar
Rep: 16 (Unique: 6)
Here are my results after 2 months. 120 GB 840Evo. 20gb free space.
Look ok-ish I guess?
ziggystardust is offline
post #1366 of 3282 (permalink) Old 12-10-2014, 11:45 AM
ReptilesYo's Avatar
Rep: 0
There you go.
post #1367 of 3282 (permalink) Old 12-10-2014, 01:26 PM
trparky's Avatar
These are benchmarks from two different systems of mine.
Tom
trparky is offline
post #1368 of 3282 (permalink) Old 12-10-2014, 01:35 PM
BigBeard86's Avatar
Rep: 4 (Unique: 4)
I fear that the "fix" was no different then to what people were doing prior to the firmware update, that is, using a program to rewrite the data, bringing a temporary return to normalcy.
Here are the results of the 500GB Evo, with the firmware applied on the first day of release; the results look poor. What do you guys think?
BigBeard86 is offline
post #1369 of 3282 (permalink) Old 12-10-2014, 01:40 PM
trparky's Avatar
That looks down right piss poor. I was really hoping that this fix would be a permanent fix and that we'd have nothing to worry about but... I guess that's not the case.
Basically, this is a hardware issue and that the 840 EVO is flawed at the hardware level and no amount of firmware fixes will fix this issue. This is clearly a hardware flaw. Samsung tried, I give them that, now they have to step up and admit that the 840 EVO is indeed flawed at the hardware level and they need to do something about it. They have the 850 EVO now, I expect nothing short of a full recall of the 840 EVO and have them replaced free of charge with the 850 EVO.
We basically need to get the major technology news sites (AnandTech, Tom's Hardware, etc.) to cover this issue again and make it known that the issue isn't fixed and that we demand nothing short of a massive recall of the flawed hardware.
There really is no other SSD that I would even think about buying. All of the other SSDs on the market are powered by Sandforce controllers and we all know that Sandforce controllers are such buggy pieces of crap that they make Windows looks perfect in comparison.
Tom
trparky is offline
post #1370 of 3282 (permalink) Old 12-10-2014, 01:44 PM
BigBeard86's Avatar
Rep: 4 (Unique: 4)
i hope so man. i doubt the firmware did anything; it is probably the performance restoration tool that simply "restored" performance, temporarily.
Does anyone believe samsung would actually recall these drives? i don't want to be stuck with this trash.
They should at least offer us a cheap option to upgrade.
