Help with EVO 970 SSD and ASUS Z97P MB - Overclock.net - An Overclocking Community
post #1 of 20 (permalink) Old 12-08-2018, 11:42 AM - Thread Starter
Rep: 0
Hey guys,
I need a little bit of help please, according to the web site for my mother board they banged on about the M.2 slot being able to handle speeds of up to 10Gb/s a second, so I thought, My old SSD is quite old (about 8 years) and I thought I'd splash out and get my self a new SSD, So I bought the EVO PRO 970 500GB as it has some great reviews.
They have some amazing benchmarks on youtube and the like so I thought why not!
Now this is the bit that I didn't take any notice of and that was the interface for my board (or the m2 slot should I say) which is only running at PCIe Gen 2 x 2 so this means that the pro 970 is running way less than it should be.
I'm only getting about 800 MB/s read speeds which is way less than what I should be. (the SSD is running like 6 times slower than what it can be run at)
Sent ASUS an email on it as I think it's a little bit confusing, but they only replied with something that was not even related to my initial query, so sent them an email back.
So just a couple of questions please,
I take it the board (ASUS Z97P) won't run the M2 any faster...? (can't find anything in the bios to change)
Is it possible to use a PCI Express riser card and use the M2 SSD with it to boot into windows giving me the speed and interface that I want?
Is there a possibility that I can buy another board that will take my chip and DDR3 that will use the faster PCIe 3.0 x4 speed ? (Only reason I ask is that my local PC store just dismissed it and said that I'd need a new board, processor, ram etc.)
Any ideas please?
Thanks.
p.s I have the correct drivers installed for the SSD rather than the stock MS one...
Name:	06-12-2018 09-16-07.jpg
Name:	06-12-2018 09-10-12.jpg
Name:	06-12-2018 09-09-53.jpg
Name:	06-12-2018 09-24-34.jpg
mowax is offline
post #2 of 20 (permalink) Old 12-08-2018, 12:25 PM
Watercooled
lexer's Avatar
Rep: 47 (Unique: 33)
The problem is that the SSD is running through the PCH at PCI-E 2.0 @ X2 because that you aren't reaching the advertise speeds.
Yes you can run a PCI-E to M.2 adapter but will be the same because your board doesn't PCI-E switchs the second PCI-E is also running at PCI-E 2.0 @ 2X.
Sadly the only option is changing the platform, but in my opinion you will not see a big benefit with the drive running at full speed, games and application will load at the same speed.
Only in very specific applications you can see a noticeable benefit SATA and NVME drive for the casual / gamer user is the same. Your drive right now is running faster than any SATA drive so is fast enough
I7 8700K@4.7Ghz / Z370-A / 2X8GB 3200Mhz ADATA Spectrix D40 / 1TB Intel 600P / EVO 850 250GB / 4TB WD Gold / RTX 2080 GAMING OC / NZXT Noctis 450 ROG / EVGA G2 850W@ECO
Heatkiller REV 3.0 / XSPC EX360 / DDC 3.25 + EK-XRES / 3x Venturi HF-12 PWM
lexer is offline
post #3 of 20 (permalink) Old 12-08-2018, 12:37 PM - Thread Starter
Rep: 0
ah shucks, thanks for that....I had a feeling that it was a possible board change. I have noticed a real difference in all my apps since running them from the new SSD, just some of the speeds that I see with them running on a rig that handles PCIe 3.0 x4 are insane.
So if I get it running then video rendering and game loading etc. would they then not become even faster?
here's some examples.....
Thanks
mowax is offline
post #4 of 20 (permalink) Old 12-08-2018, 02:38 PM
Watercooled
lexer's Avatar
You need to find a SLI Ready board, that have at least 2x PCI-E 3.0. So you can use a adapter a M.2 to PCI-E adapter. But as i said before in most applications you will not notice any difference.
I had my Intel 600P running in a Z97-A at PCI-E 2.0 X2 and then I move it to my actual setup. All the games and applications loads take almost the same time to load
lexer is offline
post #5 of 20 (permalink) Old 12-08-2018, 04:07 PM - Thread Starter
Rep: 0
ok thanks man, what puzzles me with this is if it goes faster will it not load faster......it's just my way of thinking....like what is the bottle neck? so I load cs the way it is....for example and then load it up on the PCIe 3.0 x4 lane....will it not load like instant, maybe faster than the 2 x lane?
mowax is offline
post #6 of 20 (permalink) Old 12-08-2018, 05:56 PM
Watercooled
lexer's Avatar
Most software don't take advantage of those drives at least for now, if you search some REAL world benchmark you will see that perform very similar to a SATA SSD. There is some applications where NVME drives shines like database. CS:GO is a very old game with small assets it will not load faster with a NVME drive
https://www.guru3d.com/articles-page...review,12.html
lexer is offline
post #7 of 20 (permalink) Old 12-09-2018, 11:03 AM - Thread Starter
Rep: 0
Thanks for that and thanks for your help
I'd still like to give it a go I guess, you know what it's like when you get something new for your PC , so I'm hoping I can find a board that will allow me to use the full potential of the EVO....
I think my chip is a 5 series, would you know about that or how to tell? and then I'll try to see if I can find a board that will take the processor and DDR3 that I have.....hopefully anyway...
Thanks again matey
mowax is offline
post #8 of 20 (permalink) Old 12-09-2018, 11:50 AM
Watercooled
lexer's Avatar
Thanks again matey
Your chip is 4° Gen "Haswell" and you need a Z97 (LGA1150) board that is SLI Ready. Because those board has at least 2x PCI-Express 3.0 that can run 8x/8x or 16x. So your ssd will run at their full speed with a M.2 to PCI-E adaptor and your video card at x8. Only high end board that as a PLX chip can run 16x/16x or 8x/8x/8x/8x
lexer is offline
post #9 of 20 (permalink) Old 12-09-2018, 02:16 PM - Thread Starter
Rep: 0
nice..that sounds like a plan....can i boot into windows with it? that's what worry's me....as all riser cards don't seem to want to boot..
mowax is offline
post #10 of 20 (permalink) Old 12-09-2018, 03:12 PM
Watercooled
lexer's Avatar
Yes Z97 can boot from any PCI-E. M.2 is just PCI-E + SATA with another form factor but in the case of Z97 only supports PCI-E. Only Z87 needs a BIOS mod to boot from a PCI-E
lexer is offline
