[Sponsored] The One Rig | Dominus Extreme & 2080 Ti HOF OC Lab - Page 3 - Overclock.net - An Overclocking Community
post #21 of 32 (permalink) Old 06-19-2019, 01:54 AM - Thread Starter
FireKillerGR's Avatar
Rep: 1 (Unique: 1)
A couple of weeks after Computex, bit of exams on top as well but finally got some updates!
First of all, the fans arrived last week (will post photo soon).
Over the last few days, we started putting parts in place to see whats needed and did a couple of mini mods on the case (bit of drilling and cutting - to post photos).
When it comes to the waterblocks we started with the gpu:
Made a custom glossy sticker for the backplate as I didn't like the original.
The actual result is better than anticipated as the HoF logo of the backplate (among another 1-2 details) is still visible (more than actually shown).
Just a photo of the motherboard with all slots occupied before installing the VRM waterblock:
VRM Block installed:
And now the full combo completed:
Tomorrow, we should be able to mount everything in place and then leave the tubing for Friday in order to complete the build.
Oh, and just received the mounting plates/bases for the two pumps - will be painted black later today so they match the radiators on which they will sit on.
FireKillerGR is offline
post #22 of 32 (permalink) Old 06-19-2019, 08:45 AM
WaterCooler & Overclocker
Barefooter's Avatar
Rep: 115 (Unique: 97)
Barefooter is online now
post #23 of 32 (permalink) Old 06-22-2019, 11:29 AM - Thread Starter
Rep: 1 (Unique: 1)
So, we came to the point where almost half of the tubing has been done.
Before getting to the actual photos, let me share some issues and how these were dealt with.
A) Cables not fitting under the mobo.
For these we had to mod (cut with a dremel) some parts (not visible) and also use 0.8CM spacers for the side radiator.
Now all cables pass freely without any issues.
B) Mounting the double reservoir setup.
One of these is mounted on top of the rad while the other (in front) is being held into place with EK's Uni Holders on chassis' frame (drilled 2 small holes).
C) Now the ultimate issue; putting the side window back in place.
When checking which cards can be installed without issues I saw that the Galax RTX 2080 Ti HOF OC Lab wasn't one of them due to the extra height.
For this reason I ordered the original Bitspower VGA Multi Direction Link which could only be installed facing downwards instead of upwards due to the thickness of the block/gpu/backplate.
Unfortunately, a new version of this that is for thicker cards/blocks was released a bit after I ordered the original.
Thinking this would be fine, we proceeded till we saw that the power cables of the gpu are now the issue and not the block.
So the only solution seems to be the use of spacers to mount the window with a bit of space so the cables (and eventually the card itself) aren't being pushed really hard.
Since we came to the point where we got some extra space, we decided to go back to the original fitting bracket for the gpu block as its prettier than the multi directional one.
D) The 3 fans on the top of the case.
Since the mobo is significantly taller than most motherboards out there, there was barely any space on the top side of the case to begin with.
Once the cables were plugged, it is quite hard to get the fans installed (and also to run) so I decided to skip these.
First photo; everything installed except the ssd, gpu and the pumps:
Vga installed with the multilink for the fittings + the pumps:
Here is the difference as we went back to the original fitting bracket of the block + installed the fittings for testing:
First tubing done:
Hopefully, it will be finished this Tuesday so I can post more photos then and do some testing.
post #24 of 32 (permalink) Old 06-23-2019, 03:00 PM
OverChilled's Avatar
Rep: 0
A few tubes left and we will finish it! Cant wait to fill it up!
OverChilled is offline
post #25 of 32 (permalink) Old 06-28-2019, 07:31 PM - Thread Starter
Rep: 1 (Unique: 1)
Rig was finally completed some days ago.
Here are the final photos of it:
Pre-fill phase:
After filling it:
post #26 of 32 (permalink) Old 06-28-2019, 07:57 PM
Majentrix's Avatar
Rep: 12 (Unique: 10)
This is awesome! I love how neat the cabling and tubes are.
Sometimes the only way to make people aware of a fire is to set the whole town ablaze.
Majentrix is offline
post #27 of 32 (permalink) Old 06-28-2019, 08:12 PM
Invalid Media
J7SC's Avatar
Rep: 16 (Unique: 11)
I like it > a lot Very clean given all the power and components
J7SC is online now
post #28 of 32 (permalink) Old 07-02-2019, 06:02 AM - Thread Starter
Rep: 1 (Unique: 1)
thanks guys! ^^
post #29 of 32 (permalink) Old 07-09-2019, 03:51 PM
Hardware Princess
Hydroplane's Avatar
Rep: 22 (Unique: 20)
That's a lot of RAM.
CHILLER DESTRUCTION
Build Log - White Voodoo
Z390 Station
(10 items)
White Voodoo
(14 items)
9900K @ 5.5 1.46v
EVGA Z390 Dark
Titan RTX 2085/8500
Trident Z 3200c14 @ 4133c16 1.5v
Samsung 970 Evo Plus 250gb
EVGA 1300 G2
Dehumidifier
Dimastech Test Bench
AOC Agon AG251FZ 240Hz
Audio
Built-in Monitor Speakers (3 watt)
Intel Core i9-7980XE @ 4.3 GHz 1.10v
Asus Rampage VI Apex
Gigabyte Aorus Waterforce WB 1080 Ti SLI 2037/6318 1.09V
Trident Z 32GB (4x8GB) 3200C14 @ 3800C16 1.50V
Samsung 960 Evo 1TB
EVGA 1600 T2
HWLabs Nemesis GTR 420+280 Rads
(7) Noctua NF-A14 iPPC-3000 PWM Fans
EK-XRES 140 Revo D5 RGB PWM
LD Cooling PC-V7 280/420
Operating System
Windows 10 LTSB
Operating System
Linux Mint 19.1
NEC PA271W 2560x1440
Keyboard
Razer Blackwidow Chroma V2
Dual Intel Xeon L5520 2.26 GHz
48 GB Samsung DDR3-1066
120 GB Samsung 750 Evo SSD
2 TB Western Digital Green
2 TB Hitachi 7200 RPM
650W Delta PSU
1U Rackmount
Operating System
Ubuntu Server 16.04
Hydroplane is offline
post #30 of 32 (permalink) Old 07-12-2019, 06:54 PM
Farmer Boe's Avatar
Rep: 65 (Unique: 64)
Bro, that's sick!
Prime Shiz
(18 items)
24/7 Rig
(14 items)
Media Rig
(14 items)
AMD R7 2700X @ 4.3GHz 1.37v
Asrock X470 Taichi
MSI GTX 1080 Ti GAMING X
G.Skill Flare X DDR4 3200MHz 2x8GB CL12
ADATA XPG SX8200 480GB (Win 10 Pro)
Corsair Force 3 240GB (Uplay/GoG)
Crucial BX100 500GB (Origin)
WD Blue 3D SSD 1TB (Steam)
EVGA SuperNOVA 650 G2
Noctua NH-D14 ~passive~
Silverstone Fortress FT05B-W
Operating System
Windows 10 Pro
AOC Agon AG322QCX
Keyboard
CM Storm Quickfire TK Red
Mouse
Mionix Naos 3200
Mouse
Corsair MM400 Compact
Audio
Asus Xonar Essence STX
Audio
Sennheiser HD 598
Intel Pentium G4560
MSI B250 PC MATE
XFX HD 7750 Core 1GB
Team Group T-Force Vulcan 2x4GB 2400MHz CL14
Western Digital Green 2TB x4
OCZ Vertex 4 128GB
Silverstone Strider ST50-P
Silverstone Fortress FT02B-W-USB3.0
Operating System
Windows 7 Ultimate
Samsung Syncmaster 2443
Keyboard
CM Storm Quickfire Rapid ~blues~
Mouse
CM Storm Spawn
Audio
Logitech Z337
Intel Core i5 4460
Asrock H81M-ITX
HIS HD 7750 iSilence 1GB
G.Skill Ripjaws X DDR3 2x4GB 1600MHz CL8
ADATA SX900 128GB
Corsair CX430M
Intel i7 OEM heatsink
Lian Li PC-Q07R
Operating System
Windows 7 Ultimate
LG 55UK6300PLB
Keyboard
Logitech K400
Audio
KRK Rokit 8 Gen 2's
Other
Audinst HUD-mx1
Other
Schiit Wyrd
Farmer Boe is offline
You may not post new threads
