[Sponsored] Spotswood | Vertical mini-ITX/mini-DTX Prototype Case Build - Overclock.net - An Overclocking Community
post #1 of 22 (permalink) Old 08-09-2019, 10:30 AM - Thread Starter
Hardware Rep
Spotswood's Avatar
Rep: 98 (Unique: 85)
This is a build log of a prototype case I designed to air cool a mini-ITX/mini-DTX form factor motherboard. The design of the case/frame is centered around a 90-degree oriented motherboard (vertically mounted GPU) and my preference to build with slotted aluminum extrusion.
Name:	Vertical and reverse mini-DTX case frame AIR v6.jpg
Some of the details of the case are:
Dimension: 435 x 235 x 300mm (height x width x depth)
Motherboard support: mini-ITX/mini-DTX (90-degree rotated)
CPU cooler height: 150mm
GPU support: maximum length of 325mm
PSU: SFX or ATX
Fans: 5 x 120mm
Storage: 2 x SSD/HD
Rich
Spotswood is offline
post #2 of 22 (permalink) Old 08-09-2019, 10:33 AM - Thread Starter
Hardware Rep
Spotswood's Avatar
The motherboard "tray" is completely removable.
Name:  IMG_1812 (Small).jpg
Name:  IMG_1813 (Small).jpg
Name:  IMG_1815 (Small).jpg
Rich
post #3 of 22 (permalink) Old 08-10-2019, 09:49 AM - Thread Starter
Hardware Rep
Spotswood's Avatar
Drives attach to the extrusion via rubber grommets (note the milled-out areas)...
Name:  IMG_1831 (Small).jpg
..and are located behind/underneath the motherboard tray.
Name:  IMG_1816 (Small).jpg
Here's the tray attached to the back panel frame:
Name:  IMG_1818 (Small).jpg
post #4 of 22 (permalink) Old 08-11-2019, 10:27 AM
Tetrapyloctomist
Aenra's Avatar
Rep: 45 (Unique: 27)
I tell this to every maker willing to listen, so here goes to you too
Trends are a fact of life;
I remember hating my reading glasses, because they covered half my damned face (and i felt like an idiot); fast forward it a bit and it's a trend all of a sudden.. 15yr olds (of all real ages) walking around with 70s-styled glasses on them.. fashiun!111!
I could go on, but point hopefully taken.
So on topic, am aware it's the new trend to cram everything in as tight an enclosure as humanly possible; slap some needlessly overpowered GPU in it, must-have RGB on it and call one's self.. whatever it is they call themselves.
For normal people however, mITX used to be.. mITX really.. you'd use the integrated graphics, so barring that PSU lying somewhere inside the case, your sole 'worry' would be the HDDs. Tidy, logical. No empty space inside wasted. Amazing thing, logic, is it not.
Enter trends and what happens when everyone adhers to them, ie mITX cases about as deep as a full tower; why? Who knows?
Make something compact that doesn't expect the user to have a dedicated GPU; ie something that isn't almost 3 times as deep as it should; ie something resembling what once was a typical mITX case; the kind no one, but no one makes anymore.
Who knows huh, someone might buy it.
Pride, honour and purity.
Aenra is offline
post #5 of 22 (permalink) Old 08-11-2019, 03:44 PM - Thread Starter
Hardware Rep
Spotswood's Avatar
Finished cutting and assembling the frame.
Name:  IMG_1819 (Small).jpg
Name:  IMG_1820 (Small).jpg
Name:  IMG_1821 (Small).jpg
Bottom sheet was cut on my Avid CNC router:
Name:  IMG_1802 (Small).jpg
Name:  IMG_1822 (Small).jpg
post #6 of 22 (permalink) Old 08-11-2019, 04:15 PM
Meep
Gilles3000's Avatar
Rep: 330 (Unique: 234)
Looks good so far, subbed
Gilles3000 is offline
post #7 of 22 (permalink) Old 08-12-2019, 10:03 AM - Thread Starter
Hardware Rep
Spotswood's Avatar
All of the side panels will be cut on the CNC. Here's a quick time lapse of the PSU cut out:
Name:  IMG_1846 (Small).jpg
Name:  IMG_1847 (Small).jpg
Rich
post #8 of 22 (permalink) Old 08-14-2019, 01:54 PM - Thread Starter
Hardware Rep
Spotswood's Avatar
Nuts can be inserted into the extrusion via small milled-out areas. By "capturing" a nut between two others (4mm long set screws are used to retain the two outer nuts), you have the ability to fasten to a fixed location (without having to drill and tap a hole) e.g. a side panel.
Name:  IMG_1850 (Small).jpg
Name:  IMG_1851 (Small).jpg
Name:  IMG_1849 (Small).jpg
Name:  IMG_1854 (Small).jpg
post #9 of 22 (permalink) Old 08-21-2019, 02:48 PM - Thread Starter
Hardware Rep
Spotswood's Avatar
I only realized after cutting the left side panel that the two fan hole cutouts were - um, ugly. So, I remounted that sheet to the inside of the case and cut another solid sheet, thus creating a bottom fed air duct to keep the GPU nice and cool.
Name:  IMG_1853 (Small).jpg
Name:  IMG_2074 (Small).jpg
Name:  IMG_2078 (Small).jpg
post #10 of 22 (permalink) Old 08-25-2019, 12:29 AM - Thread Starter
Hardware Rep
Spotswood's Avatar
The top was milled from a 2.25mm thick aluminum sheet.
Name:	IMG_2082 (Small).jpg
Name:	IMG_2086 (Small).jpg
I still haven't decided on the design of the ventilation holes to be milled out of the top. In the meantime, I leveraged the extra length of the corner extrusions (moving them up a bit), allowing the top to "float" 2.75mm over the side panels (creating the equivalent of a 2.75-inch square ventilation hole).
Name:	IMG_2089 (Small).jpg
Name:	IMG_2092 (Small).jpg
Name:	IMG_2094 (Small).jpg
Name:	IMG_2103 (Small).jpg
You may not post new threads
