[Sponsored] project M8 (CaseLabs M8 workstation build) - Page 2 - Overclock.net - An Overclocking Community
post #11 of 315 (permalink) Old 05-09-2011, 09:01 AM - Thread Starter
Rep: 38 (Unique: 35)
Remember this? That was the project of the day:)
First, i had to mill down a 10 mm alu plate, since i did not have any 5 mm lol! Then bolting them together, and went to war with the mill.
As you can see, i just printed out the cad drawing, and used that as reference.
And on it went. Luckily this mill got "autopilot" so that I can just set it to move at a certain speed, and comfortably take my pictures.
For the detailed parts, I had to use a smaller bit, and then just fill the edges.
Finished middle pieces. The one on the right have been glasblasted, but will need to have another go.
And this is how they mount on the pumps.
And how they mount on the radiator! I will put some rubber pieces under each end to dampen vibrations. Once all of this is mounted I should have a great pump setup:D
And the finished result. Only need to weld it, and then grind it down again, give it another go in the sandblaster and maybe paint it, yet to be decided:D
I must apologize for the lack of updates, but exams are coming up at school, and there is quite a few things to do smile.gif
p0Pe is offline
post #12 of 315 (permalink) Old 05-09-2011, 06:11 PM
Senior Moderators
Blitz6804's Avatar
I am in for this one, the plans look intriguing!
Important reading: Terms of Service | Professionalism Initiative
For Sale / Wanted | Freebies
Report and ignore. Do not quote. Do not reply.
If I say anything to upset or confuse you, please PM me!
You should be Folding or Crunching! My stats: [email protected], BOINC
Clubs: 890FXA UD5/7 | Firearms | 939 | Pokémon TCG | Cooking with Blitz
"looks pretty flipping consistant to me :D I'm proud fo real" - juano (01/17/2012)
"okay Blitz you win" - juano (01/05/2013)
"Have you heard the news that you're dead? No one ever had much nice
to say, I think they never liked you anyway."
- My Chemical Romance
Blitz6804 is offline
post #13 of 315 (permalink) Old 05-09-2011, 06:16 PM
Blueduck3285's Avatar
Rep: 43 (Unique: 37)
Blueduck3285 is offline
post #14 of 315 (permalink) Old 05-09-2011, 06:33 PM
werds's Avatar
Rep: 147 (Unique: 137)
Subbed sucka!
werds is offline
post #15 of 315 (permalink) Old 05-12-2011, 11:43 AM - Thread Starter
Well, as the previous alu stands failed duo to not being "weldable" I decided to make some of 6 mm steel! This will provide better rigity, and I made them look better this time!
A picture of the failed alu welds.
Used the old stands as reference, and then bolted them together.
These are the new ones, with the old alu one to the left.
And again, new versus old.
I am going to make the support rods tomorrow, and hopefully get it welded too! Lets hope second time is the charm lol.
p0Pe is offline
post #16 of 315 (permalink) Old 05-16-2011, 08:56 AM - Thread Starter
And welding and filling done! After my .cad exam I picked this up from the workshop. A buddy had welded it in the meantime, and I went straight home and put the pumps on:D
How it looks in its full scale, mounted on the radiator. Did I mention that it is sturdy as hell!?
A close up of the milling. I also countersunk the screw holes for good looks:)
Had to fill about 2 mm off the Bitspower crystal link to get it to fit, but now its like a glove!
Cant decide what color I am going to paint it, but I think that white might be the choice!
Hope you like the end result here:) Now its on to the top!
p0Pe is offline
post #17 of 315 (permalink) Old 05-17-2011, 06:00 AM
smorg's Avatar
Rep: 37 (Unique: 35)
looking good! definatly looks interesting and look forward to seeing more.. think the case is a bit too big tho lol
smorg is offline
post #18 of 315 (permalink) Old 05-18-2011, 10:27 AM - Thread Starter
Hehe, you should see their other cases:D
p0Pe is offline
post #19 of 315 (permalink) Old 05-22-2011, 10:49 AM
Rep: 182 (Unique: 152)
Moar. Like the pump idea.
HybridCore is offline
post #20 of 315 (permalink) Old 05-22-2011, 10:57 AM
Farmer Boe's Avatar
Rep: 65 (Unique: 64)
Too big? You'd be suprised how quickly you run out of room with a dual loop in a rig. And the M8 is the smallest case that Case Labs make wink.gif
Prime Shiz
(18 items)
24/7 Rig
(14 items)
Media Rig
(16 items)
AMD R7 2700X @ 4.3GHz 1.37v
Asrock X470 Taichi
MSI GTX 1080 Ti GAMING X
G.Skill Flare X DDR4 3200MHz 2x8GB CL12
ADATA XPG SX8200 480GB (Win 10 Pro)
Corsair Force 3 240GB (Uplay/GoG)
Crucial BX100 500GB (Origin)
WD Blue 3D SSD 1TB (Steam)
EVGA SuperNOVA 650 G2
Noctua NH-D14 ~passive~
Silverstone Fortress FT05B-W
Operating System
Windows 10 Pro
AOC Agon AG322QCX
Keyboard
CM Storm Quickfire TK Red
Mouse
Mionix Naos 3200
Mouse
Corsair MM400 Compact
Audio
Asus Xonar Essence STX
Audio
Sennheiser HD 598
Intel Pentium G4560
MSI B250 PC MATE
XFX HD 7750 Core 1GB
Team Group T-Force Vulcan 2x4GB 2400MHz CL14
Western Digital Green 2TB x4
OCZ Vertex 4 128GB
Silverstone Strider ST50-P
Silverstone Fortress FT02B-W-USB3.0
Operating System
Windows 7 Ultimate
Samsung Syncmaster 2443
Keyboard
CM Storm Quickfire Rapid ~blues~
Mouse
CM Storm Spawn
Audio
Logitech Z337
Intel Core i5 4460
Asrock H81M-ITX
Gigabyte GT 1030 Silent Low Profile 2G
G.Skill Ripjaws X DDR3 2x4GB 1600MHz CL8
ADATA SX900 128GB
Corsair CX430M
Noctua NH-L9i
Lian Li PC-Q07R
Operating System
Windows 10 Pro
LG 55UK6300PLB
Asus VS24AH-P
Keyboard
Logitech K400
Mouse
Logitech M570
Audio
KRK Rokit 8 Gen 2's
Other
Audinst HUD-mx1
Other
Schiit Wyrd
Farmer Boe is offline
You may not post new threads
