dnect problems - Overclock.net - An Overclocking Community
dnect problems
post #1 of 29 (permalink) Old 08-09-2010, 02:25 PM - Thread Starter
Rep: 960 (Unique: 705)
Ok my work output is droping alot cause for some reason now dnect will only use up to 75-78% of my GPu anyone else have this problem i suspended dnect and let collatz run and it used 97%.
Bal3Wolf is offline
post #2 of 29 (permalink) Old 08-09-2010, 04:22 PM
Dr. Boincinstein
DarkRyder's Avatar
my 5850 always runs in the 70's. i think its just the way dnetc is written.
OCN'S WhatPulse team, come join us!
OCN's Boinc Team. Come Join Us!!
My Boinc Project's Stats
_.=5GHz Overclock Club=._
"All is Fair in Love And Boinc." : DarkRyder
"May the Boinc be with you... always." : DarkRyder
DarkRyder is offline
post #3 of 29 (permalink) Old 08-10-2010, 11:13 PM
Rep: 1 (Unique: 1)
I think it has to do with the timing inside the card. Try running your clock up/down in 5 MHz increments and see if there is a place where utilization bounces up.
My 5850 runs 96% on DNETC.
Also, if you are using MSI AB then close it after making your settings ... it will eat up about 20% of the GPU even if you have all monitoring turned off.
Musketeer 6 is offline
post #4 of 29 (permalink) Old 08-10-2010, 11:22 PM - Thread Starter
I figured out the problem its a bug in msi afterburner and boinc if you have msi afterburner open then dnetc wont go above 78%. Can open and close msi afterburner and watch the gpu usage change in gpuz from 78 to 99%.
Bal3Wolf is offline
post #5 of 29 (permalink) Old 08-10-2010, 11:36 PM
Rep: 1 (Unique: 1)
Yeh, I found the same thing about a month ago. The nice thing is if you check the apply settings at system startup then it will adjust the card but not launch MSI AB so the card will start full bore. You can then use the BOINC start with system option.
post #6 of 29 (permalink) Old 08-11-2010, 01:22 AM - Thread Starter
you know the wierd thing i never had the issue befor up till a few days ago only change was i tried out a few differt drivers, And now it does it on every driver.
Bal3Wolf is offline
post #7 of 29 (permalink) Old 08-12-2010, 07:55 AM
Dr. Boincinstein
DarkRyder's Avatar
I cant get my server to run dnetc anymore without the display turning off. works perfectly on all the other boinc projects, just dnetc. Any ideas?
post #8 of 29 (permalink) Old 08-12-2010, 07:55 AM
Dr. Boincinstein
DarkRyder's Avatar
with the zalmon on it it only gets to the low 50c's. so it cant be a heat issue.
post #9 of 29 (permalink) Old 08-12-2010, 08:15 PM
Retired Staff
Rep: 1299 (Unique: 730)
grunion is offline
post #10 of 29 (permalink) Old 08-12-2010, 09:03 PM - Thread Starter
Originally Posted by grunion View Post
No AB dnetc issue here.
Attachment 167836
Thats how mine used to run up till about 3-4 days ago when it started only using 78% with ab open darkryders 5850 has been doing it for months.
Bal3Wolf is offline
