The 30 Second Dummy Plug - Overclock.net - An Overclocking Community
Closed Thread
post #1 of 211 (permalink) Old 09-12-2008, 03:32 PM - Thread Starter
CyberDruid's Avatar
Rep: 2585 (Unique: 1242)
Here is how to make up a dummy plug for your card in about 30 seconds.
All you need are three 68 ohm resistors from RadioShack. They come in packs of 5 for a buck.
You will need the DVI-VGA adapter that ships with every GFX card, the resistors and a clipper. You could use scissors or a nail clipper, the wire is soft.
Bend one leg of the resistor around till it is parallel to the other then clip off the long leg so it is the same length as the bent leg.
The wire is just the right gauge to slide into the VGA plus securely.
Push it home. Note you want to bridge the top three pins on the right with the pins directly below one-to-one.. Hold the plug so the wide part is up top.
Alternate the resistors so the leg of one is against the body of another to avoid shorting out the jumpers.
And that is all there is to it. Start Folding on your second GPU
August 13th, 2011 sad-smiley-002.gif Happy trails, may we meet again.
CyberDruidPC is History
CyberDruid is offline
post #2 of 211 (permalink) Old 09-12-2008, 03:34 PM
Litlratt's Avatar
Rep: 282 (Unique: 161)
Nice. +
"A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed."
Litlratt is offline
post #3 of 211 (permalink) Old 09-12-2008, 04:37 PM
Retired Staff
gibsonnova74's Avatar
Rep: 257 (Unique: 180)
gibsonnova74 is offline
post #4 of 211 (permalink) Old 09-12-2008, 05:44 PM - Thread Starter
CyberDruid's Avatar
It seemed a lot easier than soldering resistors to a VGA and then putting that on the adapter...and every card I've bought in the past couple of years comes with at least one adapter.
post #5 of 211 (permalink) Old 09-12-2008, 05:48 PM
Rep: 393 (Unique: 296)
Nice one there CD! *is sure to use this on 4870x2s*
~Gooda~
Start folding HERE!
Wow...
I never thought i'd have to say this, but any penis pictures will net you a hefty infraction mmkay?
Engineering Sample CPUs: Q6600 B0 - Xeon E3110 (E8400) E0 - E5400 (possibly) - E8400 (possibly)
Havegooda is offline
post #6 of 211 (permalink) Old 09-12-2008, 06:02 PM
Retired Staff
Lige's Avatar
Rep: 391 (Unique: 283)
Nice CD, now...
To get my [email protected] GPU rig started back up...
I just need a CPU, anyone want to donate.
Lige is offline
post #7 of 211 (permalink) Old 09-12-2008, 06:35 PM
GDP
GDP's Avatar
Rep: 16 (Unique: 16)
wait what does this do and why is it needed?
GDP is offline
post #8 of 211 (permalink) Old 09-12-2008, 06:51 PM
Retired Staff
It's for folding with multiple cards. It's needed as a "trick" to fool the cards into thinking that monitors are hooked up to all the cards, when in fact, the monitor is only hooked up to one card.
post #9 of 211 (permalink) Old 09-12-2008, 07:14 PM
Retired Staff
mortimersnerd's Avatar
Rep: 508 (Unique: 369)
Gollie had a thread on this here.
This might be useful:
I have made a few of these and they work well. I used 75ohm resistors and it worked too.
Eric - FTW PC Rep
[eric [at] ftwpc.com]
Store | Forum | Facebook | Twitter | Reseller Ratings
"Like" us on Facebook for a chance to win newly released products
Z is a pawn to the power that was Mort. He moderates like a boss.
mortimersnerd is offline
post #10 of 211 (permalink) Old 09-12-2008, 07:21 PM
Retired Staff
The thing that I like is that CD's method doesn't involve soldering.
Closed Thread
