[Info] List and Uses of Folding Flags - Overclock.net - An Overclocking Community
post #1 of 42 (permalink) Old 05-12-2010, 06:45 AM - Thread Starter
Retired Staff
zodac's Avatar
Rep: 509 (Unique: 309)
Commonly Used:
-advmethods:
Used to request new/beta WUs from Stanford. It can also be turned on permenently in the initial configuration for the SMP client.
-bigadv:
Used on the Linux SMP client (or a Linux VMware in Windows) to request large WUs, which give much higher points.
Requires a CPU with 8cores/threads; an i7.
-configonly:
Used to enter the configuration screen for the SMP client and GPU console client. The client will close once configuration has been completed.
-local:
Forces the client to run in the install location; useful when running multiples of the same client.
For example, the GPU client runs by default in C> Users> [Your User]> AppData> Roaming> [email protected] With the -local flag, it would run in C> Program Files (x86)> [email protected]> [email protected]
-oneunit:
After a WU is complete and the results have been uploaded, the client will close.
-pause:
Similar to -onunit, but the client will ask if you would like to download a new WU.
-send all:
Forces the client to send all queued WU results, if any.
The client will close after sending all WUs, and not download a new WU.
-smp:
Allows the SMP client to request SMP WUs, which will use all available cores. You can also specify the number of cores by using -smp x, where x is the number of cores.
Without this flag, the SMP client acts as a Unicore client, only using a single CPU core to fold.
-verbosity 9:
9 is the level of information shown in the FahLog (1-9). More info can help if there are any issue with the client. Set to 3 by default.
GPU Only:
-forcegpu nvidia_g80:
When folding on multiple GPUs, this flag negates the need to use a dummy plug or second monitor. The flag is for all non-Fermi GPUs, regardless of core.
Doesn't always work.
-forcegpu nvidia_fermi:
The Fermi version of the above flag.
-forcegpu ati_r700:
Similar to -forcegpu nvidia_g80, but for ATi GPUs. You must add this flag to 5 series AMD GPUs when using GPU2, however, or else you will get a "GPU unsupported error".
Using the GPU3 client means you don't need this flag.
-forcegpu ati_r800:
As above, but for 6 series AMD GPUs,
Uncommon Flags:
-config:
Similar to -configonly, but begins a WU after configuration has been complete.
-delete x:
Deletes the xth from work queue.
You should only do this if there is an error with your current WU, and in most cases you would probably be better of posting a thread about it.
-forceasm:
Forces the WU core to use SSE instructions, even if the client has decided that the machine might not be running them well.
It may help older system, but don't use it for newer (dual core and up) systems.
-help:
Displays the flags available to the client.
-license:
Displays the end-user license agreement.
-queueinfo:
Shows information on all queued WUs.
-service:
Runs the program in service mode. If the client is not already being run as a service (chosen in configuration), when the user tries to log out, a "Waiting for program to close" window will open.
zodac is offline
post #2 of 42 (permalink) Old 05-12-2010, 06:45 AM - Thread Starter
Retired Staff
zodac's Avatar
How to add the flags:
SMP client/GPU console client
• Rightclick the client shortcut
• At the end of the "Target" field, add a space and the flag
• If you want to add more than one flag, put a space between each
GPU systray client/CPU Unicore client
You can use the same method as above, or the following:
• Rightclick the folding client icon in the system tray
• Choose "Configure..."
• Go to the "Advanced" tab
• In "Additional Client Parameters", type in the flag (with -)
Linux SMP client
Open Terminal and type this in:
sudo nano /home/USER/Desktop/SMP/fah
Add the desired flag at the end:
cd /home/USER/Desktop/SMP/
LD_LIBRARY_PATH=~/lib64-fah /home/USER/Desktop/SMP/fah6 -smp -FLAG
Ctrl+O, then 'ENTER' (saves it) and finally, Ctrl+X (closes file).
Then close terminal, and reopen SMP client. Your flag will no take effect.
zodac is offline
post #3 of 42 (permalink) Old 05-12-2010, 07:12 AM - Thread Starter
Retired Staff
zodac's Avatar
I think I got them all, but let me know if I missed any.
*Reserved... just because*
zodac is offline
post #4 of 42 (permalink) Old 05-12-2010, 07:42 AM
mike44njdevils's Avatar
Rep: 63 (Unique: 59)
VERY nicely done. I think this will help a little with some confusion.
Also, I've yet to use the -advmethods flag, is that OK, or should I try it?
"Those satisfactions are permanent..."
mike44njdevils is offline
post #5 of 42 (permalink) Old 05-12-2010, 07:45 AM - Thread Starter
Retired Staff
zodac's Avatar
If you followed my SMP guide, you would have activated it in the Advanced Settings in the initial config. I might add that in...
zodac is offline
post #6 of 42 (permalink) Old 05-12-2010, 07:50 AM
Velathawen's Avatar
Rep: 123 (Unique: 115)
Very handy for new folders, thanks zodac!
Velathawen is offline
post #7 of 42 (permalink) Old 05-12-2010, 08:00 AM
[CyGnus]'s Avatar
Rep: 211 (Unique: 168)
Another great and useful thread from our Super Editor
[CyGnus] is offline
post #8 of 42 (permalink) Old 05-12-2010, 08:05 AM
Ryahn's Avatar
Rep: 28 (Unique: 19)
I have to run -smp in my SMP client or it doesnt fold for some reason.
Ryahn is offline
post #9 of 42 (permalink) Old 05-12-2010, 08:06 AM - Thread Starter
Retired Staff
zodac's Avatar
Oh ****.
zodac is offline
post #10 of 42 (permalink) Old 05-12-2010, 08:07 AM
Ryahn's Avatar
Originally Posted by zodac View Post
Oh ****.
Hmm, a folding editor missing a flag..... Thats a little on strange side
Ryahn is offline
