Logitech G19 Keyboard LCD - HWinfo64 Quick Guide - Overclock.net - An Overclocking Community
Old 01-18-2014, 05:39 AM - Thread Starter
Blue Dragon Level 1
Blue Dragon's Avatar
Decided to make this thread on the G19. I currently use HWinfo64 to monitor temps.
ZC
I like the simplicity of the HWinfo64 display.
the program - HWinfo64
First_ click configure sensors and go to the system tray tab and find a value you want displayed:
1- click show in tray
2- change to desired color
3- click show in tray to disable
Second_ go to the Logitech LCD tab
1- select first value you want displayed
2- click show value on LCD
3- Change screen, column, & line to 1
keep repeating, changing the line until you fill the LCD. changing font will decrease the number of lines, but make it easier for certain values to stand out. you can change a value to column 2 on same line to show multiple values on one line, but space is limited so you might need to rename the value. otherwise you should be good to go thumb.gif
to rename value go to layout tab
1- click
2- type
3- click
** make sure to hit save and quit to save all of your selections!**
Blue Dragon is offline
Old 10-29-2016, 11:51 PM
Nailz1911 Level 1
Nailz1911's Avatar
It's pretty sweet!
Nailz1911 is offline
Old 12-22-2018, 12:09 PM
Hodyshoran
How to add date time in G19?
I figured out how to display the sensors I want, but what I cant find is how to display the actual (system) time as well.
I found a another plugin called LCDHost that is featured on the Apps Page @hwin FO which does display the time, but I am not able to change its layout.
I guess the native G19 Plugin must save somewhere an xml sheet with the configured sensors where it should be able to add somehow a variable for the current time.
Can anybody help me out pls? :huh:
Hodyshoran is offline
