Kinzu v2, Kinzu v2 Pro and Kana - Page 139 - Overclock.net - An Overclocking Community
post #1381 of 1402 (permalink) Old 10-21-2012, 12:08 PM
Gone
Skylit's Avatar
Rep: 541 (Unique: 328)
Originally Posted by thuNDa View Post
heh, the kana is suited for lowsens at 800DPI, it just doesn't have real 1600/3200DPI steps.
The 1600 step on the Kana is the same native 3200 step on the Kinzu. Just a poor registry or limited processing power at the specific resolution.
Only interpolated or fake step is the 3200 (on Kana), which takes the already bad 1600 (3200) and interpolates it.
Confusing? Yes, though I agree that both the Kana and Kinzu should be limited to 800 and 1600 (Same registry) respectively.
Skylit is offline
post #1382 of 1402 (permalink) Old 10-21-2012, 12:18 PM
YOU MEAN kinzu = 800dpi and kana = 1600dpi
EliteReplay is offline
post #1383 of 1402 (permalink) Old 10-21-2012, 12:24 PM
Gone
Skylit's Avatar
No, I mean Kana's 800 step is = the Kinzu's 1600 in terms of cursor fidelity.
Both mice will track respectively fine till 1600 DPI (Kinzu) and 800 DPI (Kana) Max IPS is of course lower on the Kinzu. Hardware trade off of speed and resolution.
Skylit is offline
post #1384 of 1402 (permalink) Old 10-21-2012, 02:20 PM
Yori99's Avatar
Rep: 0
All fancy info but would you be able to answer my questions in the last page? :/
Yori99 is offline
post #1385 of 1402 (permalink) Old 10-21-2012, 11:19 PM
Phos's Avatar
Rep: 32 (Unique: 31)
If you're playing at 400 dpi the Kana is probably the better option, though I don't know the exact max speed you can expect.
Phos is offline
post #1386 of 1402 (permalink) Old 12-15-2012, 08:11 PM
dachef's Avatar
Rep: 0
Is it safe to get the Kinzu? Did they fix the sensor issues?
dachef is offline
post #1387 of 1402 (permalink) Old 12-15-2012, 08:21 PM
Gone
Skylit's Avatar
Yes.
Skylit is offline
post #1388 of 1402 (permalink) Old 12-15-2012, 08:25 PM
dachef's Avatar
Rep: 0
The width of the Kinzu and Kana are both exactly the same 64mm but the length of are different, 124mm vs 114mm. Is the 7 mm a huge difference? I tried the Sensei and it was too big for me. I want to get either the Kinzu or the Kana. I would rather get the smaller mouse but I love how the Kana looks and the colors it comes in. I use a claw grip and use a razer imperator. I click literally to the left of the scroll wheel right where it starts. I currently use a logitech g9x without the shell.
Edit: I check wiki but I just want to double check. The Kana and Kinzu use the same sensor correct? The only real different is the size? Off top but do you guys know if they fixed the Zowie Mico sensor issue?
dachef is offline
post #1389 of 1402 (permalink) Old 12-16-2012, 03:57 AM
woll3's Avatar
Rep: 128 (Unique: 87)
Same Sensor, different Lens, Kana has half the CPI of the Kinzu, but twice the malfunction Speed, and imo both are nearly the same to grip,
altough i find Kana more comfortable because its side go more |__|, instead of \__/ on the Kinzu.
woll3 is offline
post #1390 of 1402 (permalink) Old 12-16-2012, 05:02 AM
MrFerrari's Avatar
Rep: 18 (Unique: 14)
I bought a Kinzu V2 Pro, it was horrible. The tracking felt very unprecise, the scrollwheel was very flimsy and it measured very bad in every way. The pollingrate was very uneven.
MrFerrari is offline
