CM storm spawn, which firmware ? - Overclock.net - An Overclocking Community
post #1 of 10 (permalink) Old 01-03-2012, 04:34 AM - Thread Starter
-=oopeteroo=-'s Avatar
Rep: 0
which firmware is best for the spawn ? i use razer scarab for mousemat
-=oopeteroo=- is offline
post #2 of 10 (permalink) Old 01-04-2012, 08:23 AM - Thread Starter
Rep: 0
someone plz tell me what settings is best for this mouse? iam using razer scarab mousemat
post #3 of 10 (permalink) Old 01-04-2012, 08:55 AM
Linux Lobbyist
Rep: 11 (Unique: 9)
I use 31 on a Artisan Hayate, which is black. When I was testing out the Artisan Shiden, which is white, I was using 30a.
Limniscate is offline
post #4 of 10 (permalink) Old 01-04-2012, 10:18 AM
blueslobster's Avatar
Rep: 2 (Unique: 2)
The Scarab seems to be white, so you might run into problems when using firmware 31 or 32. My Spawn does not function on an Artisan Shiden (which is white) when using 31 or 32. The only firmware which works with my white mouse pad is 30a.
For more information on the different firmware versions of the Spawn see here and here.
blueslobster is offline
post #5 of 10 (permalink) Old 01-04-2012, 11:26 AM
CMCarter's Avatar
Rep: 43 (Unique: 35)
If your looking to use a light colored pad with the same shape. The Xornet performs really well on light surfaces.
Best firmware for the spawn on light surfaces would be 30a.
Product Manager: CM Storm
CMCarter is offline
post #6 of 10 (permalink) Old 01-04-2012, 02:10 PM
Rep: 2 (Unique: 2)
Quick question: are there any further firmwares for the Spawn in development?
post #7 of 10 (permalink) Old 01-04-2012, 03:29 PM
Mehehe!
CorruptBE's Avatar
Rep: 86 (Unique: 50)
When I was using the spawn I prefered the 30a ones. The firmwares which fix lift off have a really low malfunction speed.
CorruptBE is offline
post #8 of 10 (permalink) Old 01-05-2012, 02:47 PM
UZ7
UZ7's Avatar
Rep: 109 (Unique: 91)
On my Qck I use 30a, works perfectly fine on it. 31 had a very low LOD and would sometimes lose tracking and 32 had a higher LOD. I would test them all out to see which one fits your mousepad as material as well as color will affects the performance and will be different for everyone.
Voodoo 2 -> MX440 -> 9800Pro -> 6800GT -> X1900XT ->
9800GT -> 4870 -> 5850 -> 6970 -> 7950 -> 770 -> 780 -> 290 -> 970 -> 970M -> 1070
UZ7 is offline
post #9 of 10 (permalink) Old 01-05-2012, 03:35 PM
Glymbol's Avatar
Rep: 41 (Unique: 25)
As UZ7 wrote above, you should try all 3 fw for yourself. In my opinion fw 31 isn't working properly even on mono black mousepad (very low max speed). Fw 32 is good and fw 30a is fine too but LOD is pretty high. Fw 30a should give best tracking on different mousepads.
This post is supposed to be written in English, at least I did my best, to make it as close to English as I could :-)
Glymbol is offline
post #10 of 10 (permalink) Old 11-21-2012, 05:24 PM
Scorpion667's Avatar
Rep: 120 (Unique: 111)
+1 Appreciate it =) found this thread on google lol
31 has the worst perfect control speed of any mouse I've ever used, on my QCK.
30a is not bad.
Personally I'M IN LOVE with the shape of the mouse, I can live with the so-so LOD
[edit] with tape fix I'm at 1.5mm liftoff and 3.79m/s PCS according to enotus on firmware 61, it feels excellent while gaming
cookie cutter 2012
(15 items)
3930k 4.7 1.384v
RIVE BIOS 2105
1080TI FTW3 2050/6003
16GB Samsung 2133Mhz CL10
Samsung 850 Evo 1TB
EVGA 1300G2
H110
Arc Midi R2
Operating System
Win 10 Pro 64bit
XL2420T
Keyboard
K70 Reds
Mouse
SS QCK+
Mouse
Zowie FK2, many opticals
Audio
Xonar Essence STX
Other
Intel EXPI9301CT NIC
Scorpion667 is offline
