To reduce the LOD in the first place, you have to decrease the illuminated spot on the surface, rather than weakening the light itself(with more or less transparent tape).
So take non-transparent!!! tape, and stick it over the hole of the bottom of the mouse, until it reaches the small lens:
In my experience it doesn't significantly decrease the max-speed, if at all when u leave the small lens area completly free.
It doesn't affect the area of light the mouse tracks when sitting down anyway, just the area infront of where the sensor takes pictures of, which then would wander right under the sensor while lifting the mouse off.
But that gets cut of with the tape:
I have a Gigabyte GM-M6880 optical mouse. I have tried to put scotch on the entire hole but it reduced tracking completly. Then i put like you showed in the picture but depending how much of the hole i covered it either did nothing or it reduced tracking completly. Any suggestions?
Also why is non transparent tape essential? I've seen the same tutorial on youtube but many of them used clear tape.
V-Track doesn't have any "tape fix" or "light blocking mechanism" to achieve that effect. The light is being trown towards the ground completely vertical thus whenever you lift your mouse, if it's not exactly 90º from the surface, it will stop tracking.
Originally Posted by Skylit
Oh Okay. it's actually an Avago sensor. Yeah, it will work, but pretty difficult to position placement.
We're talking about a milimeter or sub-milimeter precision to get the desired effect. Also, it depends on the lens, if the light is being twisted around you might even want to put the tape "fix" between the light stream and the sensor itself.
Great tip. I've had G400 a good while now and haven't tried this before. Makes this epic mouse even better. On my goliathus i have 1mm or less lift-off and it still tracks over 3m+
Related Threads
Ask a question
Ask a question
Overclock.net
27.8M posts
541.2K members
Since 2004
