"Tape-Trick" for lower liftoff-distance(LOD) with optical mice - Overclock.net - An Overclocking Community
post #1 of 18 (permalink) Old 02-06-2012, 04:22 AM - Thread Starter
Rep: 122 (Unique: 91)
To reduce the LOD in the first place, you have to decrease the illuminated spot on the surface, rather than weakening the light itself(with more or less transparent tape).
So take non-transparent!!! tape, and stick it over the hole of the bottom of the mouse, until it reaches the small lens:
done!
G400: L4Ka6Pvs.jpg Abyssus: TnlvTHds.jpg Alcor: NlvTfIOs.jpg
EC1 evo w/o custom lens: uoH0dFqs.jpg
thuNDa is offline
post #2 of 18 (permalink) Old 02-06-2012, 04:54 AM
Skar's Avatar
Rep: 64 (Unique: 41)
Should also reduce the maximum speed, did you try that?
Skar is offline
post #3 of 18 (permalink) Old 02-06-2012, 05:20 AM
fasti's Avatar
Rep: 15 (Unique: 8)
ah.. followed some wrong guide, now this tape trick works on Kana : )
fasti is offline
post #4 of 18 (permalink) Old 02-06-2012, 05:24 AM - Thread Starter
In my experience it doesn't significantly decrease the max-speed, if at all when u leave the small lens area completly free.
It doesn't affect the area of light the mouse tracks when sitting down anyway, just the area infront of where the sensor takes pictures of, which then would wander right under the sensor while lifting the mouse off.
But that gets cut of with the tape:
thuNDa is offline
post #5 of 18 (permalink) Old 06-22-2012, 11:29 AM
Pentdragon's Avatar
Rep: 31 (Unique: 24)
Hi,
I have a Gigabyte GM-M6880 optical mouse. I have tried to put scotch on the entire hole but it reduced tracking completly. Then i put like you showed in the picture but depending how much of the hole i covered it either did nothing or it reduced tracking completly. Any suggestions?
Also why is non transparent tape essential? I've seen the same tutorial on youtube but many of them used clear tape.
Pentdragon is offline
post #6 of 18 (permalink) Old 06-25-2012, 07:11 AM - Thread Starter
because depending on which transparent tape it is, it wouldn't do anything at all.
but your mouse seems to be a laser mouse, so this doesn't work.
thuNDa is offline
post #7 of 18 (permalink) Old 06-25-2012, 07:36 AM
superj1977's Avatar
Rep: 213 (Unique: 185)
superj1977 is offline
post #8 of 18 (permalink) Old 06-25-2012, 07:44 AM
Gone
Skylit's Avatar
Rep: 541 (Unique: 328)
Technically it's still CMOS based using a simular lens assembly. The sensor itself is likely spec'd for optical illumination.
It should work if carefully placed, but I don't quite have an HD picture of the backside of the mouse.
Edit : http://product.pconline.com.cn/pdlib/263355_bigpicture2367624.html < Need better than this.
Skylit is offline
post #9 of 18 (permalink) Old 06-25-2012, 01:43 PM
AquaSurfer's Avatar
Rep: 16 (Unique: 14)
Originally Posted by Skylit View Post
(...) http://product.pconline.com.cn/pdlib/263355_bigpicture2367624.html < Need better than this.
http://www.mygarage.ro/attachments/componente/104135d1278578050-poze-componente-p1070245.jpg
source
Edit: I believe that this tape trick will not work with laser sensors.
Laser light is just too narrow. example - video
AquaSurfer is offline
post #10 of 18 (permalink) Old 06-28-2012, 07:48 PM
bobuy00's Avatar
Rep: 8 (Unique: 6)
Why don't(doesn't?) all mouse manufacturers use this on stock mice? As far as I know only A4tech do this with V-track mice..
Tweaks settings for 3 hours. Plays for 1.
bobuy00 is offline
