Use Mouse With USB 2.0 Or 3.0 Port ? - Overclock.net - An Overclocking Community
post #1 of 11 (permalink) Old 08-06-2012, 02:35 PM - Thread Starter
Rep: 35 (Unique: 27)
My board has Asmedia USB 3.0 Controller as well as the Generic USB 2.0 controller. I know they are compatible, but is one controller better than the other ? Any disadvantage to using the Asmedia 3.0 ?
mothman is offline
post #2 of 11 (permalink) Old 08-06-2012, 02:37 PM
ghostrider85's Avatar
Rep: 329 (Unique: 273)
mouse doesn't need usb 3.0. same concept as why HDD doesn't need SATA III 6gb/s.
ghostrider85 is offline
post #3 of 11 (permalink) Old 08-06-2012, 02:47 PM - Thread Starter
What ?..............I know mice don't need or benefit from USB 3.0, I just wanted to know if the Asmedia controller was as good or better than the generic one.
As for HDD Sata II doesn't need Sata III, but Sata III SSD sure as hell do.
mothman is offline
post #4 of 11 (permalink) Old 08-06-2012, 02:51 PM
the asmedia usb 3.0 CONTROLLER is for the USB 3.0 PORT ONLY, the generic usb 2.0 CONTROLLER is for the USB 2.0 PORT ONLY, they can't be interchanged, you can't plug your mouse to 2.0 port and use the 3.0 asmedia controller
post #5 of 11 (permalink) Old 08-06-2012, 03:41 PM - Thread Starter
No, No, No...........Put the bong down and listen to what I said man. I didn't ask if the Asmedia can control the USB 2.0 port, I simply ask if plugging the mouse into the Asmedia 3.0 port is better or worse than the Generic 2.0 port......Jesus !
mothman is offline
post #6 of 11 (permalink) Old 08-06-2012, 03:45 PM
duox's Avatar
Rep: 33 (Unique: 32)
I don't think there should be any difference unless someone releases a mouse that says it takes advantage of it , and even then it would most likely do nothing. I've seen nothing where anyone showed any benefit or loss one way or the other in my searches. Could be wrong though because I have not searched hard, just a couple days of googling.
duox is offline
post #7 of 11 (permalink) Old 08-06-2012, 03:49 PM
karod's Avatar
Rep: 22 (Unique: 20)
I can't imagine performance differences.
One thing I noticed. My Fanatec wheel doesn't work on my Asmedia USB3 ports. It only works on the USB2 ports.
So I just freed a USB2 port for the wheel and put the Thrustmaster TH8RS into the Asmedia USB3 port. That works fine. But I guess that is more a firmware problem with the fanatec wheel, because the Thrustmaster shifter works well with the asmedia usb3 port.
Performance in terms of throughput is not important for a mouse, so polling or something like that is more important.
The only difference is that the USB2 ports are directly connected to the Z68 chipset for example. While the asmedia may be routed through somewhere first.
karod is offline
post #8 of 11 (permalink) Old 08-06-2012, 03:50 PM
listen to remix's Avatar
Rep: 88 (Unique: 72)
Use it with the USB 2.0 and save the USB 3.0 slot for something else.
listen to remix is offline
post #9 of 11 (permalink) Old 08-06-2012, 03:51 PM
3.0 is better than 2.0, but the mouse don't need 3.0, 2.0 is just fine, there will be no difference.
post #10 of 11 (permalink) Old 08-06-2012, 03:52 PM
Traches's Avatar
Rep: 61 (Unique: 52)
Also 3.0 is more likely to have driver issues; 2.0 is rock solid. (I had some trouble with my 3.0 ports when first setting up my computer.)
And yeah, as said before there's no benefit to a mouse; save the port for something else.
LOOP ORDER DOESN'T MATTER.
I use arch btw
Traches is offline
