Razer Deathadder 3.5G Mouse Wheel Problem - Overclock.net - An Overclocking Community
post #1 of 21 (permalink) Old 08-10-2012, 09:28 PM - Thread Starter
Osea23's Avatar
Rep: 66 (Unique: 61)
My Razer Deathadder 3.5G is having a strange mouse wheel problem. Whenever I scroll (whether up or down), it seems to have a mind of its own. When I scroll down, it's usually fine, but occasionally will skip a bit. Nothing bad. But when I scroll up, this is where the mouse thinks for itself. When I scroll up, the mouse will skip randomly, either down or up. It's prettying annoying, especially when i'm looking at threads on OCN. Also it's a nuisance in games, as I can't switch weapons properly. Does anyone else have a problem similar to this, whether a DA or something else?
What is signature?
Osea23 is offline
post #2 of 21 (permalink) Old 08-10-2012, 10:11 PM
2shellbonus's Avatar
Rep: 41 (Unique: 33)
Had the same issues with Black Edition. Encoder razer is using for the wheel is utter crap.
"It's all fun n games till someone looses an eye. Then it's just fun you can't see" - James Hetfield, Metallica
2shellbonus is offline
post #3 of 21 (permalink) Old 08-10-2012, 10:15 PM - Thread Starter
Osea23's Avatar
So you're saying it's a software/driver bug?
What is signature?
Osea23 is offline
post #4 of 21 (permalink) Old 08-10-2012, 10:27 PM
snipekill2445's Avatar
Rep: 133 (Unique: 97)
I don't think it's a driver issue, cause mine is absolutely fine. One QS though, are you using a USB 2.0 or 3.0 port?
snipekill2445 is offline
post #5 of 21 (permalink) Old 08-10-2012, 10:34 PM - Thread Starter
Osea23's Avatar
It's hooked up to a usb 2.0 port. Asus gave me this usb add on bracket. Sorta looks like this: http://di1-4.shoppingshadow.com/images/pi/6d/40/10/106580218-260x260-0-0_asus+asus+midi+game+port+header+2+port+usb+2+0+bra.jpg
It uses a front panel usb 2.0 plug. I'll test if a usb 3.0 port makes a difference.
What is signature?
Osea23 is offline
post #6 of 21 (permalink) Old 08-10-2012, 10:39 PM - Thread Starter
Osea23's Avatar
Whoa dude! Are you working magic or something? I just plugged my DA into the usb 3.0 port on the back of my mobo, and everything is fine! Well it skips a line or two here and there, but it's improved by 95%! Wow!
What is signature?
Osea23 is offline
post #7 of 21 (permalink) Old 08-10-2012, 10:56 PM
post #8 of 21 (permalink) Old 08-11-2012, 12:32 AM
How did you come to that?
The encoder (the mechanical thing that transmits the signal of up down wheel movement and makes those wheel detents) - that thing is going on your DA. You may think its fixed, but it will be back. The encoder in simply crap.
post #9 of 21 (permalink) Old 08-11-2012, 01:03 AM
DaClownie's Avatar
Rep: 286 (Unique: 244)
Yea, encoder is a physical piece that picks up on the spin of the wheel inside the mouse. I've used my DA for about 2 years, and it was about 1 year old when I bought it here on OCN, and it's started doing this recently.
My best solution? Change weapons with your number keys, and use page up and page down to scroll. tongue.gif
R.I.P. Syrillian - August 13, 2011
Amazing during your time here on earth, but your calling in heaven must be extraordinary.
About drbaltazar's translated posts:
i like the!new GPU from AMD!this discovery( could mean !alot ! i like grapes!
DaClownie is offline
post #10 of 21 (permalink) Old 12-20-2012, 02:25 AM
Electricmann's Avatar
Rep: 6 (Unique: 6)
Hi,
I joined so I could help you with this, and help others who are having the same problem.
My Deathadder worked great when I first bought it. After many months of use, I noticed the scrolling had a mind of its own. When I go up, it would go down, when I go down, it would go up, and sometimes it would skip. Exactly the problem you're having. My left button on my mouse would also double click a lot of times. Very annoying. I fixed both problems.
I put some WD40 into the clicker, then wiped excess with a (cotton) Q-Tip. This removed the double clicking immediately.
For the crazy scrolling. All you need to do is get some strong tweezers and squeeze the part which the plastic scroll part inserts into. (On the left side) I suppose this is the sensor which picks up the scrolling. It's a mechanical problem. Over time it gets loose from all the scrolling. Squeeze it and it will perform as new. My mouse has not skipped a single time after doing this. You may need to do it a few times before enough pressure has been applied, but once you get it then you got it for good! (well, at least for another 6 months to a year)
I was debating whether or not I should throw mine in the trash and buy another brand. Doing these two tricks turned mine back into a brand new mouse. I think Razer should be embarrassed they have made such a great mouse that turns to junk so quickly. I saved mine, so hopefully you didn't throw yours out before you see this message.
Electricmann is offline
