WMO-Adder Guide - Overclock.net - An Overclocking Community
WMO-Adder Guide
post #1 of 12 (permalink) Old 03-23-2015, 05:41 AM - Thread Starter
Br3chtel's Avatar
Rep: 12 (Unique: 11)
Hello guys,
i've recently done some WMO-Adder mods and want to share my findings on this, because I found it quite hard to get some informations about this mod (and ESR registration doesn't seem to work :/ ).
I managed already to mod two WMOs (1.1a), one with the guts from a Deathadder 3G (1800 DPI) and one with a DA 3.5G (3500 DPI).
First thing to say, if you only swap the sensor the mousewheel scroll wont work at all only middlemouse button, because the mice uses different tech each for registering scrolls.
In order to get a working scrollwheel you need to swap it from the DA to the WMO, wich is not so hard as I thought first.
The hardest thing was to figure out the right pinout.
I managed to get it frome some guys pics who already done WMO-Adders and some wiretracing.
Some pictures will follow later, I'm currently at work and have some freetime to post this guide wink.gif
Tools I used:
  • Solder iron
  • Solder
  • Helping hand (tool with clamps to fix the pcbs while soldering)
  • Tong
  • Cuttingknife
  • Drill
  • Sandpaper
  • Hotgluegun
Steps:
  1. Preparing the WMO-shell to fit the DA sensor
  2. Mousewheel-encoder swap
  3. Mousewheel fusion
  4. Soldering both pcbs together
  5. Fitting in and some finetuning of positioning
First open both mice, you'll find guides for the steps using google wink.gif
Step 1 - preparing the shell:
If you look inside the WMO shell you'll have two locations for the pcb, the "button part" and the "sensor part".
Everything thats behind the button part has to be flatened.
I used a tong, cuttingknife and sandpaper.
I broke out the most of the sensor part with tong and used the sandpaper to clean it down.
Next I drilled up the sensor window to the bottom so that the DA sensor-pcb could fit without having it to cut.
When everything fits without much wobbeling and the DA sensor still gets the mousecursor moved its good.
Step 2 - Mousewheel-encoder swap:
For the mousewheel mod first you need to desolder the wheel-encoder out of the DAs pcb.
It's easiest if you take a good pinch of solder on the irons tip and then pull it over the three connectors from the wheel-encoder.
Then you can carefully pull the wheel-encoder out and be carefull not to bend the little legs to much, they are a easy to bend over if heatend.
After that you do the same with the WMOs wheel-encoder.
To install the DA encoder on the WMO pcb you have to install it reverse as the DAs installment was.
Step 3 - Mousewheel fusion:
You take the wheelthingy appart from the WMOs mousewheel and flat it down, the otherside for the middlemouse button stays.
Then you take the DAs wheel and cut of the nib wich connects to the encoder carefully with a cuttingknife.
Time to connect the nib to the WMO wheel, therefore you drill a whole in the middle of the WMO wheel (used 2.5 mm diameter drill) and put the DAs wheel nib in it, till it mostly sits in and only the boat tail with the nib sits outside.
I've done this trial and error until it fits best.
Step 4 - Soldering pcbs together:
Here's the pinout for the 3.5G mod, if 3G pinout is wished, I'll upload it later because I'm at work wink.gif
Pinout 3.5G mod:
(DA 3.5G pinout is written on PCB, WMO pinout is from left mousebutton to right mousebutton)
I've cuttet the flatwires from both mice so, that I had enough lenght left to connect them.
I splitted them up, tied them together and soldered them according to the "layout" shown above.
Also I glued the DAs led to the WMOs red back part for some crazy stylish light effects - yay breathing WMO biggrin.gif
Step 5 - Fitting in:
After everything was done I finetuned the perfect position for balance and sensor positioning.
Sensor position is a bit more backwards than the original WMO, but I it's fine for me.
Then glued it up with some small points of hotglue and ended up with a weight of 84g without cable on the 3.5G mod, the 3G mod is 82g.
Probably you could save another gramms if you use superglue instead of hotglue, but I was to lazy to get some. ^^
I think this mod is also do-able with IMs (maybe with working DAs sidebuttons) and IE 3.0s but dunno if the layout is the same.
So I hope this helps someone out who wants to do this and hasn't had a clue how to do it.
Feel free to ask if some questions come up.
Also I don't know if this is the right forum for it, if not please move it to right topic.
Ah - and sorry for my english, I'm from germany had it only at school and this is 8 years ago tongue.gif
Mice:
Logitech G903 (current daily driver), Rival 310, Logitech G403, Logitech G Pro, Logitech G303 , WMO-Adder (3.5G), Custom WMO 1.1a (/w Omrons), WMO, IE 3.0, Deathadder 2013, Roccat Savu, Roccat KPM, Steelseries Rival 700, Gigabyte Torq x5, Zowie EC2-A, Ducky Secret
Trackballs:
Logitech Trackman Wheel, Logitech M570, Kensington Slimblade
Mouspads:
Logitech Powerplay (/w softpad), Razer Goliathus Control (L) + Sphex, Roccat Sense, Steelseries QcK Heavy, Sharkoon 1337 XXL
Keyboards:
Ducky Shine 3 TKL MX-Black (main), Cherry G84-4100, Roccat Arvo, Logitech G13
Br3chtel is offline
post #2 of 12 (permalink) Old 03-23-2015, 06:42 AM
CeeSA's Avatar
Rep: 117 (Unique: 73)
Nice!
"Scroll Mid" is "Scroll Up"?
And you connect 1+4 at the button pcb? Do you know why?
I'm more interested the other way around. I would like to transplant the WMO Sensor PCB into a different shell.
But I thinkt WMO could not control a different mouse wheel encoder....
What dpi are you using? Could you make some tests? MouseTester
I'm curious about the pics.
CeeSA is online now
post #3 of 12 (permalink) Old 03-23-2015, 06:53 AM - Thread Starter
Br3chtel's Avatar
1 + 4 has to be connected otherwise the wheel-encoder wont work, dunno why exactly but I figured out it has to be, after some wiretracing and trial n error.
Why would you do that, not bothered by the kinda low PCS of the WMO-sensor?
It should register the other encoder, you just have to figure out the pinout, because the signals are just input/output, nothing special.
I'm using the 950 DPI step, 1000Hz pollingrate, LOD is about 1CD.
Mice:
Trackballs:
Mouspads:
Keyboards:
Br3chtel is offline
post #4 of 12 (permalink) Old 03-23-2015, 07:44 AM
acid_reptile's Avatar
Rep: 10 (Unique: 9)
acid_reptile is offline
post #5 of 12 (permalink) Old 03-24-2015, 10:26 PM
Bonestorm Professional
thrillhaus's Avatar
Rep: 10 (Unique: 9)
thrillhaus is offline
post #6 of 12 (permalink) Old 03-25-2015, 01:42 AM - Thread Starter
Br3chtel's Avatar
Depends on the size of the buttons but seen someone done this with mechanical-keys here on OC.net
Link: WMO_with_sidebuttons
I think you need only the right tools, a steady hand and some patience while tooling... aaaand some buttons biggrin.gif
Oh forgot to take pics yesterday, they're following today. Shame on me :0
Mice:
Trackballs:
Mouspads:
Keyboards:
Br3chtel is offline
post #7 of 12 (permalink) Old 03-25-2015, 08:03 AM
CeeSA's Avatar
I like this one more Link
CeeSA is online now
post #8 of 12 (permalink) Old 03-25-2015, 08:08 AM - Thread Starter
Br3chtel's Avatar
@CeeSA just seen you're the dude who modded sidebuttons into the WMO biggrin.gif
Nice work, haven't followed the thread till the end maybe I had already seen your glorious work wink.gif
BTW the thread we linked is the one who "inspired" me modding a DA into a WMO, some of the post are really great.
Mice:
Trackballs:
Mouspads:
Keyboards:
Br3chtel is offline
post #9 of 12 (permalink) Old 03-29-2015, 07:25 AM
CeeSA's Avatar
hmm, still no pics...
Here is my try the other way:
But I could not make it work correct. It always scroll up and down. But I only move the wheel one way. Tried already all connection possibilities at the small MB/wheel PCB up and down...
Any idea's?
CeeSA is online now
post #10 of 12 (permalink) Old 03-29-2015, 03:07 PM
Rep: 122 (Unique: 91)
Any idea's?
heh, i thought this wasn't supposed to work due to different technologies that are used?
you need GND for the scrollwheel anyways, so connect that with the free remaining pin, or where the housing is soldered.
thuNDa is offline
