USB mouse hard overclocking (2000 Hz+) - Page 26 - Overclock.net - An Overclocking Community
post #251 of 786 (permalink) Old 05-13-2016, 05:18 AM - Thread Starter
SweetLow's Avatar
Rep: 55 (Unique: 31)
Originally Posted by Waisech View Post
Since I have 4 USB3.0 ports on my Asus laptop and I was on Windows 7 (64bit) I had no way to OC my MX518 other than to upgrade to Windows 10 (64bit).
To (possibly) you and all old Intel chipsets users:
https://www.overclock.net/t/596276/changing-usb-polling-rate-to-1000hz-or-lower/420#post_25046948
and below. But this will not work from 100 series of Intel chipsets - there is simply no USB2.0 controller.
5) Checked box 'Filter On Device' and selected 500hz (doesnt matter if I choose 62Hz, 125Hz or 1000Hz, it wont let me change the rate)
6) Restart (No difference, the filter checkbox will disappear whether I restart or not)
Looks like no elevated privileges. Are the windows ask to elevate privileges when you start setup.exe? If no - try to expressly run it as admin.
SweetLow is offline
post #252 of 786 (permalink) Old 05-13-2016, 08:29 AM
Waisech's Avatar
Rep: 0
Didn't even think of that, never had to do it in Win7. You were right. I ran it as admin, was able to easily change it and mouse rate checker shows the new Hz. Works beautifully. Thank you! I can finally use my MX518 to it's fullest potential
Waisech is offline
post #253 of 786 (permalink) Old 06-13-2016, 05:01 AM
Rep: 34 (Unique: 31)
Since this basically is a "custom" pollingrate - would this allow us to get something like the Xai had? "Exact Rate" or whatever it was called?
c0dy is offline
post #254 of 786 (permalink) Old 06-13-2016, 07:18 AM - Thread Starter
SweetLow's Avatar
SweetLow is offline
post #255 of 786 (permalink) Old 06-13-2016, 07:35 AM
AAGGHH~ MY EYES~ AAGGHH~
uaokkkkkkkk's Avatar
Rep: 157 (Unique: 67)
I could never get Exactrate to work on my Xai. Then again, nothing worked right with that mouse.
uaokkkkkkkk is offline
post #256 of 786 (permalink) Old 06-13-2016, 09:15 AM
c0dy is offline
post #257 of 786 (permalink) Old 07-13-2016, 11:22 AM
Rep: 0
Win7 64bit
MX300
I can't get it to work.
I tried 'NoPatch' drivers with 250Hz filter but whenever i restart the system the mouse doesn't move. In 'device manager' the 'mouse hid device' claims something's wrong with registry (installation incomplete) or something. I also manually installed the driver with 'pnputil -i -a hidusbf.inf' and it gets installed (not activated though as there were no device found) and is properly listed with 'pnputil -e'.
These are my usb drivers:
My 'usbport.sys' is 6.1.7601.18328 (MD5=12FEB33791920678F8433701C822BCFD) and i can manually create a 250Hz version by patching it but it only works in testmode:
24D13: 3A B0
24D14: C2 04
24D17: 88 12
24D1A: 01 BF
Any attempt (like >this) to sign the driver looks ok in file properties (usbport.sys) but it always results in Intel drivers showing exclamation mark and mouse doesn't respond when i swap the file and reboot.
There's a guy who regularly patches Intel drivers for older systems (here). For that you have to import his certificate first. It works properly. He just patches the inf file though. The *.sys files are still signed by Intel. Maybe that's the trick. Some people say its impossible to sign drivers with self-signing and certificates must be cross-signed with MS. I'm not sure if that's really true for all cases.
Whatsoever.. i'm wondering why it doesn't work here.
Any idea?
Risk64 is offline
post #258 of 786 (permalink) Old 07-14-2016, 12:34 AM - Thread Starter
SweetLow's Avatar
Originally Posted by Risk64 View Post
>Any idea?
>Win7 64bit, Etron USB 3.0
See first post of this topic if you really need 2000 Hz+. if you only need 1000 Hz- - look at readme (win 7+usb 3.0)
>NoPatch
under win 7 this version of driver can make rate lower only
it's not need now. take the last version (and read readme)
SweetLow is offline
post #259 of 786 (permalink) Old 07-14-2016, 02:23 PM
Rep: 0
Never mind... i've restored the original *.inf association (by registry fix) and installed the driver by right-click. Now its working. Thank you very much. smile.gif
No change with 1kHz *.sys file. Once i replug the mouse the 'HID Mouse' driver gets exclamation mark and setup.exe is empty. I delete the device in device manager and rescan for new hardware and mouse comes back to original state.
It just says 'driver is not properly configured (in registry)' when filter is active (in device manager).
I can send you my usbport.sys if necessary but for me it rather looks like it doesn't connect the driver or service. I cannot install the driver by right-click as i have *.inf associated with notepad++ and the old handler is not listed in context menu anymore. But i don't see why 'pnputil -i -a hidusbf.inf' shouldn't work. The driver gets properly installed as oem.inf.
If i try to manually assign the driver to the broken device in device manager it says there is no information in the driver for that device.
No clue what's wrong here...
Risk64 is offline
post #260 of 786 (permalink) Old 07-30-2016, 01:04 AM
rattleheadmegadeth's Avatar
Rep: 0
Originally Posted by qsxcv View Post
WMO DOES 8000HZ POLLING
also that's conclusive proof that my (new) x08, with last 4 digits=4103 (41th month of 2003?), does not run at 6000fps, because if it did it would not be possible to have consistent 125us report intervals
My IMO 1.1 from 2001 x06 runs @ 8000 Hz, exacly the same as my IME 3.0 x80...
rattleheadmegadeth is offline
