USB mouse hard overclocking (2000 Hz+) - Page 34 - Overclock.net - An Overclocking Community
post #331 of 725 (permalink) Old 11-18-2016, 04:59 AM
mantorker's Avatar
Rep: 3 (Unique: 3)
Originally Posted by trism View Post
Because this currently requires a driver "hack" which is not considered to be a valid approach for a commercial product.
The reason why 8 kHz polling is not used is simple: the USB 2.0 FS standard does not support it by default. You would need HS for that - and that's where things get tricky. The frequency the bus is working at is much higher and thus the design of the PCB needs to be really exact - in fact it's quite a hard task with 2-layer PCBs. The tolerances are just generally much lower and you would most likely see units that would either kick back to FS or not even authenticate at all with Windows. Generally 4-layer+ PCBs are used for USB 2.0 HS products which then again costs more. In addition, you would require a beefier MCU (as if 72 MHz STM32s weren't already an overkill for peripherals) and in many cases an additional external PHY making the PCB design for an already constrained space a harder task.
Conclusion: too much stuff to worry about with a negligible gain.
It's too soon to say "negligible" before you try a real 8khz mouse. And, high speed USB on 2-layer pcb is possible, in fact , following the layout guideline , it's quite easy.
mantorker is offline
post #332 of 725 (permalink) Old 01-12-2017, 08:55 PM
cool2000m's Avatar
Rep: 0
any chance we can get amd/via compatible drivers?
I've tried everything.
Every time I try to overclock something the mouse stops working, light switches off, and the device says "This device cannot start. (Code 10)
Insufficient system resources exist to complete the API."
Not only that but when I use 31 or 62 in usb 2.0 mode it filters to 31 and 62 polling rate in mouse tester... i'm not sure this is built for amd systems!
cool2000m is offline
post #333 of 725 (permalink) Old 01-13-2017, 12:52 AM - Thread Starter
SweetLow's Avatar
Rep: 55 (Unique: 31)
It's not hardware related probably:
https://www.overclock.net/t/1597441/digitally-signed-sweetlow-1000hz-mouse-driver/340#post_25560676
Fresh Windows 10 x64 Anniversary (or newer) + Secure Boot enabled
SweetLow is online now
post #334 of 725 (permalink) Old 01-13-2017, 01:44 AM
cool2000m's Avatar
Rep: 0
the 1000 hz works though.
and I don't have secure boot enabled, and also its a new installation.
post #335 of 725 (permalink) Old 01-13-2017, 02:46 AM - Thread Starter
SweetLow's Avatar
1. as opposed to what? what is nominal polling rate of mouse - 125Hz?
2. as i can see you have some kind of hub between mouse and controller. look at first message of thread carefully.
post #336 of 725 (permalink) Old 01-13-2017, 01:57 PM
cool2000m's Avatar
Rep: 0
Thats just the thing, its plugged straight into the usb 3.1a socket and the other usb 3.0's are the front panel.
post #337 of 725 (permalink) Old 01-14-2017, 12:03 AM - Thread Starter
SweetLow's Avatar
Really? Look at / Post screenshot of your via usb 3.0 controller and it's device subtree expanded when mouse not attached.
If "generic usb hub" disappear - than you simply have not right hardware.
And what about my first question?
post #338 of 725 (permalink) Old 01-14-2017, 01:16 AM
cool2000m's Avatar
Rep: 0
yes, sorry, the mouse in question is an intellimouse explorer 3.0 legends edition with a default polling rate of 125 hz. the 1000 hz works fine but in 2.0 usbs the polling rate switches to the listed numbers of 62 hz and 32 hz and because the usb 3.0 cant go that low it breaks, I think.
here is the screenshot as requested:
I assure you there is no usb hub.
what i see when enabled:
motherboard is the MSI 970 gaming
post #339 of 725 (permalink) Old 01-14-2017, 02:21 AM - Thread Starter
SweetLow's Avatar
My friend, there IS usb hub. No matter it is not separate device - it is present in hardware path to mouse.
Nice, now we can be sure that problem lay inside PC.
as i can understand you have some second xHCI controller. what is the picture of device manager if you attach mouse to this controller (port of this controller)?
p.s. at second screenshot i can see some errors of using setup wink.gif if you have composite devices - install filter with "Process Parent" checkbox set. It's very easy now - look at green lines only smile.gif
post #340 of 725 (permalink) Old 01-15-2017, 04:18 PM
culturist's Avatar
Rep: 0
Is it real to overclock Razer mice to 2000+ hz?
I've tried with my Taipan with no results.
culturist is offline
