USB mouse hard overclocking (2000 Hz+) - Page 4 - Overclock.net - An Overclocking Community
post #31 of 725 (permalink) Old 02-01-2016, 09:28 AM
bruzanHD's Avatar
Rep: 9 (Unique: 8)
Originally Posted by qsxcv View Post
btw offtopic:
http://www.ebay.com/itm/151969244623
see second picture
so this where the 6000fps mlt04 idea comes from. not sure why people thought that certain wmo/imo's are 6000fps though
Probably because the serial numbers correspond as such. X08 ones and X80 ones that is. I mean to me it would only make sense.
bruzanHD is offline
post #32 of 725 (permalink) Old 02-01-2016, 11:47 AM - Thread Starter
SweetLow's Avatar
Rep: 55 (Unique: 31)
There is not such thing as "sufficient frequency" for orthodoxal overclocker biggrin.gif
4k/8k version:
http://sweetlow.orgfree.com/download/hidusbf3.zip
2. take drivers from hidusbf3.zip and install it (copy to %systemroot%\system32\drivers\ directly or to the folder of hidusbf setup and then install service).
3. reboot after 2!
4. run setup.exe, and try to change rate to 31 or 62. Rate=31 actually equal to 4000 Hz, 62 - 8000 Hz. (Don't forget to restart device.)
P.S. Do not use USB hubs (for first try), it can restrict rate, attach mouse to controller ports directly. I first test my best overclockable mouse (a4tech bw-35) with hub (this hub is USB2.0 hub - but this is not help) - and has 1000 Hz only redface.gif When attached directly to controller - it can reach 1400 Hz average (unstable) biggrin.gif
SweetLow is offline
post #33 of 725 (permalink) Old 02-01-2016, 01:50 PM
acid_reptile's Avatar
Rep: 10 (Unique: 9)
This is not for windows 7, right?
acid_reptile is offline
post #34 of 725 (permalink) Old 02-01-2016, 02:17 PM - Thread Starter
SweetLow's Avatar
Not now.
SweetLow is offline
post #35 of 725 (permalink) Old 02-01-2016, 02:25 PM
lololol
qsxcv's Avatar
Rep: 371 (Unique: 153)
i'll be home in 6-7hours to test 8khz
i don't understand this well, but shouldnt it be possible to do this with the usb2 driver because hi-speed usb supports microframes?
too busy to check forums as regularly
pm me if i forget to respond
qsxcv is offline
post #36 of 725 (permalink) Old 02-01-2016, 02:44 PM - Thread Starter
SweetLow's Avatar
USB2.0 controllers never directly control USB1.1 devices, only through translating hubs, so now i suppose - it's not possible.
SweetLow is offline
post #37 of 725 (permalink) Old 02-01-2016, 08:45 PM
lololol
qsxcv's Avatar
sweetlow, is it possible to get this to work with the intel usb3.0 driver for windows7
In idle they can be more or less the same; try playing music or have some other work-intensive program open though and this should change.
good point which i always forget tongue.gif.
will try in ~18hours
so for my system, with 5 twitch streams open:
1000hz: http://imgur.com/a/9fVjW
500hz (ignore title tongue.gif): http://imgur.com/a/4ekiR
indeed the 500us jumps are much more rare, but the main part of the noise (+-0.1ms) looks identical
qsxcv is offline
post #38 of 725 (permalink) Old 02-01-2016, 08:56 PM
bond10's Avatar
Rep: 8 (Unique: 8)
My CPU usage spikes to 85-90% on 1000 hz. When I'm using 500 hz, it's around 40-50% spikes. 125 hz, less than 15%.
CPU: i5 2500K
Mouse: Deathadder 2013
1000 HZ
Should I stop using 1000 hz??
bond10 is offline
post #39 of 725 (permalink) Old 02-01-2016, 08:57 PM
lololol
qsxcv's Avatar
WMO DOES 8000HZ POLLING
also that's conclusive proof that my (new) x08, with last 4 digits=4103 (41th month of 2003?), does not run at 6000fps, because if it did it would not be possible to have consistent 125us report intervals
qsxcv is offline
post #40 of 725 (permalink) Old 02-01-2016, 09:03 PM
Derp's Avatar
Rep: 735 (Unique: 515)
W M O
M
O
Derp is offline
