USB mouse hard overclocking (2000 Hz+) - Page 57 - Overclock.net - An Overclocking Community
post #561 of 725 (permalink) Old 02-06-2019, 07:37 AM
AloneInTheDuck's Avatar
Rep: 12 (Unique: 10)
Quote: Originally Posted by SweetLow View Post
I have 0 Hz under Mozilla with 500Hz mouse. But, of course, you are the boss.
*facepalm*
Again: after overclock, coursor moves slow like in slideshow
mouserate show 1hz
Any ideas what wrong and how to fix it?
AloneInTheDuck is offline
post #562 of 725 (permalink) Old 02-06-2019, 08:00 AM - Thread Starter
SweetLow's Avatar
Rep: 55 (Unique: 31)
It's much better. Then show me what you will have with ordinary (1k) driver with 31Hz set (don't forget to reboot).
SweetLow is offline
post #563 of 725 (permalink) Old 02-06-2019, 09:53 AM
Ok. I run 1khz driver and reboot pc. As you can see, no problem with 1khz
Mouse explorer 3.0, sensor mlt04
post #564 of 725 (permalink) Old 02-07-2019, 01:06 AM - Thread Starter
SweetLow's Avatar
Nice. Definitely it is asmedia controller problem. The last - can you post its PCI ID (from device manager) for information.
SweetLow is offline
post #565 of 725 (permalink) Old 02-07-2019, 04:06 AM
Sad (
ID from "copy IDs" in your program
"USB\VID_045E&PID_0047\6&34B0E9E7&0&4"
"USB\VID_045E&PID_0047&REV_0300"
"USB\VID_045E&PID_0047"
And PCI IDs from device manager
post #566 of 725 (permalink) Old 02-07-2019, 05:24 AM - Thread Starter
SweetLow's Avatar
Thanks. I will make link from first post to this case next time. Very interesting external effects.
SweetLow is offline
post #567 of 725 (permalink) Old 02-07-2019, 05:47 AM
Not a Linux Lobbyist
the1freeMan's Avatar
Rep: 43 (Unique: 33)
@AloneInTheDuck
Why do you "install service" every time?
"a bad joint can't be that bad right?" -q
the1freeMan is offline
post #568 of 725 (permalink) Old 02-08-2019, 02:03 PM
xga
Rep: 0
I'm trying to overclock my WMO to above 1000hz. Every time when I click "restart" after selecting 31 or 62 using the 2khz/4khz or 4khz/8khz driver, instead of going to high hz, the mouse remains on and the PC still thinks it's "connected," but the cursor completely disappears and is completely unrecoverable without a reboot. I made sure it's plugged into a USB3 port. 125hz-1000hz always works fine, 31hz-62hz works normally before running one of the 2khz+ bat files to remap them.
Is this correct?
* run 2kHz-4kHz.cmd
* move driver in AMD64 to system32/drivers
* run setup.exe
* click Install Service
* reboot pc
* run setup.exe
* select 31 or 62 rate and check Filter On Device
* click Restart
* now, mouse is zombie device (still detected as a mouse, lighting up, no visible cursor) until I actually reboot the PC
Windows 10 Pro x64 17134
xga is offline
post #569 of 725 (permalink) Old 02-10-2019, 03:08 AM - Thread Starter
SweetLow's Avatar
You do all right.
Really? If you revert rate to 125 Hz (for example) without reboot nothing happens, mouse is dead still?
>my WMO
If this is mlt04 WMO then i can say that probably problem is your xHCI controller. What controller do you use?
SweetLow is offline
post #570 of 725 (permalink) Old 02-10-2019, 05:08 PM
xga
Rep: 0
Unchecking filter device or adjusting the rates doesn't affect it. Nothing except a full reboot brings the cursor back, not even re-plugging the mouse.
It's a real MLT04 WMO. How do I check what xHCI controller I have? Windows just calls it "Intel(R) USB 3.0 eXtensible Host Controller - 1.0 (Microsoft)." Is the motherboard model enough? ASrock z370m-itx/ac
xga is offline
