USB mouse hard overclocking (2000 Hz+) - Page 58 - Overclock.net - An Overclocking Community
post #571 of 738 (permalink) Old 02-11-2019, 12:30 AM - Thread Starter
SweetLow's Avatar
Rep: 55 (Unique: 31)
Quote: Originally Posted by xga View Post
Unchecking filter device or adjusting the rates doesn't affect it. Nothing except a full reboot brings the cursor back, not even re-plugging the mouse.
It's a real MLT04 WMO. How do I check what xHCI controller I have? Windows just calls it "Intel(R) USB 3.0 eXtensible Host Controller - 1.0 (Microsoft)." Is the motherboard model enough? ASrock z370m-itx/ac
Better is PCI IDs from Device Manager, example just on previous page. (You can copy IDs by CTRL-C, screenshot is not need).
On different port even???
Intel controllers is very stable in hard overclocking, but may be you have one of the bad items.
But as I said in such situation the best is check other 100% working device on this PC and check this device on other 100% working PC.
SweetLow is offline
post #572 of 738 (permalink) Old 02-12-2019, 12:45 AM
xga
Rep: 0
The ID is PCI\VEN_8086&DEV_A2AF&SUBSYS_A2AF1849&REV_00\3&115 83659&0&A0
xga is offline
post #573 of 738 (permalink) Old 02-13-2019, 03:15 AM
Rep: 0
Cautionary is offline
post #574 of 738 (permalink) Old 02-21-2019, 07:37 AM
Frim11's Avatar
Rep: 0
I'm using nixeus revel and the software didn't work at all.
Is this because the mouse has onboard memory?
Frim11 is offline
post #575 of 738 (permalink) Old 02-21-2019, 01:12 PM - Thread Starter
SweetLow's Avatar
This is my last answer here about "nothing works". This software definitely works always in one of the possible modes of use and it is described in the readme (and many times in this thread).
SweetLow is offline
post #576 of 738 (permalink) Old 02-24-2019, 02:14 AM
Rep: 0
I was using Windows 7 previously and this program was working. I switched to the new Windows 10. What I did didn't work. I could not. Because there are so many different methods and they are all mixed up trying.
I am using Windows 10 version 1809. Can you explain step by step how I can work without test mode?
memmeba is offline
post #577 of 738 (permalink) Old 02-24-2019, 02:27 AM
Rep: 0
my mouse default hertz 125, im using windows 10 1809 version.
i read all steps and applied. only work 31-62-125 hertz...
when using windows 7 in advance, my mouse could be 500 hertz...
help me?
memmeba is offline
post #578 of 738 (permalink) Old 03-18-2019, 09:58 AM
bobkitty's Avatar
Rep: 0
I can only get 1000 hz to work and that is only if I use the hidusbfp.sys file with the size 9.144 KB using atsiv.exe, more than 1000hz is nogo here.
but some days I get strange 1-2 sec freezes, its weird (
bobkitty is offline
post #579 of 738 (permalink) Old 03-19-2019, 01:02 AM - Thread Starter
SweetLow's Avatar
Why do you think that you have hardware which can allow more than 1000Hz?
SweetLow is offline
post #580 of 738 (permalink) Old 03-20-2019, 08:45 AM
bobkitty's Avatar
Rep: 0
I dunno here is my mobo - ROG STRIX Z370-G GAMING
I would just expect a brand new mobo to work since my old lenovo pc with 4770 cpu easy got to 6000 hz polling rate, but you are right who knows what kind of cheap **** they put in gaming branded mobos
I can live with 1000 hz, but the mouse freezes is killing the fun
bobkitty is offline
