USB mouse hard overclocking (2000 Hz+) - Page 63 - Overclock.net - An Overclocking Community
post #621 of 786 (permalink) Old 06-28-2019, 12:23 AM - Thread Starter
SweetLow's Avatar
Rep: 55 (Unique: 31)
Quote: Originally Posted by X7SHaDe View Post
These steps enabled me to retain the overclocked polling rate, but I think if I try to change it again, the overclock will be disabled because I only have the "nopatch" driver now.
If you carefully read description just about your post then you have to understand that all signed versions of hidusbf.sys are actually "nopatch" versions on modern windows 10.
SweetLow is offline
post #622 of 786 (permalink) Old 06-29-2019, 03:23 PM
Rep: 0
Im moving from windows 7 to 10 soon because they are abandoning it and im also buying a ryzen 9.
The problem is I don't know how things are in windows 10 in order to oc my wmo to 500hz without test mode. Can it be done?
I cannot read 63 pages.
I have also found this guide, is it legit?
https://github.com/vadash/1000hz
WMOman is offline
post #623 of 786 (permalink) Old 08-01-2019, 06:52 AM
Rep: 0
atsiv method broken on latest windows build (18945 - 1907). Can downclock but no overclock. The attached file is a zip of usbport.sys and USBXHCI.sys. File sizes larger than 1903
X7SHaDe is offline
post #624 of 786 (permalink) Old 08-02-2019, 01:07 AM - Thread Starter
SweetLow's Avatar
Ok. I will check this now but if the MS code has changed, then I can probably fix it only after two weeks.
P.S. usbxhci.sys was changed
SweetLow is offline
post #625 of 786 (permalink) Old 08-21-2019, 02:57 PM
Rep: 0
How can i check if my mouse supports ocing? I have an issue with a4 custom driver which seems to block refresh rates highet than 145. And cheapest possible logi with stock win 10 driver oces surprisingly good so its not the fault of pc i think.
Ultimauser is offline
post #626 of 786 (permalink) Old 08-23-2019, 12:04 AM - Thread Starter
SweetLow's Avatar
Ok, test version for this build.
SweetLow is offline
post #627 of 786 (permalink) Old 08-26-2019, 02:01 AM - Thread Starter
SweetLow's Avatar
Ok, little guide - how to completely unload atsiv (its driver) after using.
https://github.com/LordOfMice/Tools/...ster/atsiv.zip
In archive you will find the real atsiv's drivers (which are just incorporated in atsiv.exe - but can be extracted).
You have to (all with elevated rights)
0. Copy atsiv.sys to any folder, but the usual path for drivers is %windir%\system32\drivers (only once)
1. Create service for driver (only once):
sc create atsiv type= kernel start= demand binpath= system32\Drivers\atsiv.sys
(spaces are MATTER). The example is in Create_Service.cmd
2. then you can start and stop this service (and load atsiv.sys in & unload it from memory) by usual way in any time:
sc start atsiv
sc stop atsiv
So to load atsiv, then load and unload hidusbfp and then unload atsiv:
sc start atsiv
atsiv.exe /f d:\path\hidusbfp.sys
atsiv.exe /u hidusbfp.sys
sc stop atsiv
Hope this help.
pwd to internal archive is my exact nickname
SweetLow is offline
post #628 of 786 (permalink) Old 08-30-2019, 01:55 PM
Rep: 0
Sorry for my english, I use google translator
For several days now I can’t accelerate the mouse to 500hz. After reading many posts on this forum, I could not find the answer.
I have Windows 7 7601 x64. Mouse: WMO 1.1. I'm trying to overclock the mouse on USB 2.0 and 3.0 but all to no avail. Above 125hz does not accelerate. Can only lower to 31hz and 62hz. Tell me pls the actual ways to solve overclocking to 500hz.
update: After a few hours of searching, I found advice to remove the USB HUB 3.0 driver. The mouse disconnected, usb ports stopped working. Within 5 minutes, all drivers (except 3.0) were installed and everything worked.
Last edited by lightwalkerr; 08-31-2019 at 05:15 AM. Reason: Found a simple answer
lightwalkerr is offline
post #629 of 786 (permalink) Old 09-07-2019, 07:55 PM
lololol
qsxcv's Avatar
Rep: 373 (Unique: 154)
yay 8khz working again.
info and my procedure (i'm not sure what's actually necessary, but this worked for me without much effort)
0. my laptop is on win 10, version 1903, os build 18917.1000
1. enable test signing
run command prompt as administrator, then run
Bcdedit.exe -set TESTSIGNING ON
reboot
2. download hidusb.zip from https://github.com/LordOfMice/hidusb...er/hidusbf.zip
download hidusbfn.zip from
unzip both
3. run hidusb\Driver\Setup.exe
make sure "Filter on Device" is unchecked for now.
click "Install Service"
close it
4. in hidusbfn\DRIVER\AMD64, copy hidusbf.sys to C:\Windows\System32\drivers
replace existing file.
5. open Setup.exe again. check "Filter on Device", set the rate, and click restart
6. ???
7. profit
too busy to check forums as regularly
pm me if i forget to respond
7980xe
4770k
(16 items)
7980xe direct die @ 4.4/4.2/4.2 GHz, 1.135V
x299 aorus master
strix 5700 xt oc
4x32gb crucial ballistix 3200cl16
wd black sn750 1tb
seasonic snowsilent 1050
3x nemesis gts 360mm, fans: gt 1850rpm
lian li o11 dynamic
Operating System
win10
viewsonic xg2703-gs
Keyboard
logitech g410
Mouse
logitech g pro wireless
Mousepad
supermat
4770k @ 4.6GHz
maximus vii impact
nvidia gtx 970
crucial ballistix tactical 16gb
crucial mx100
silverstone sx500-lg, fan removed
nxzt x53
ncase m1 v3
Operating System
gentoo
Operating System
win 7 ultimate
sony gdm-fw900
Keyboard
kbp v80 matias quiet
Mouse
logitech g pro (3366)
Mousepad
allsop raindrop xl
Audio
chord mojo
Audio
sennheiser hd800
qsxcv is offline
post #630 of 786 (permalink) Old 09-16-2019, 12:39 AM
Rep: 0
does the overclock work on model o- ?
and final mouse air 58
thanks!
charlieputh is offline
