USB mouse hard overclocking (2000 Hz+) - Page 65 - Overclock.net - An Overclocking Community
post #641 of 771 (permalink) Old 10-07-2019, 12:48 PM
Rep: 0
Has anyone got this working with Windows 10 1903 (OS Build 18362)?
I had it working & loading without test mode via the atsiv method, but the latest windows update broke the driver again
Defrag82 is offline
post #642 of 771 (permalink) Old 10-08-2019, 03:20 AM - Thread Starter
SweetLow's Avatar
Rep: 55 (Unique: 31)
Then you have to know what you have to do.
SweetLow is offline
post #643 of 771 (permalink) Old 10-08-2019, 12:59 PM
Rep: 0
I actually don't!
Is there a working version somewhere? I've had a look at both threads and it's not obvious to me. Thanks!
Defrag82 is offline
post #644 of 771 (permalink) Old 10-09-2019, 12:36 AM - Thread Starter
SweetLow's Avatar
I actually don't!
Then it's time to read README:
"USBPORT.SYS/USBXHCI.SYS ... simply too new and so unknown to the program."
Then take one logical step - why are these new files unknown to program?
SweetLow is offline
post #645 of 771 (permalink) Old 10-11-2019, 01:03 PM
Rep: 0
I know the driver will fail when USBPORT.SYS/USBXHCI.SYS are new/unknown to the driver, I'm just asking if there's an version of the driver that works with the latest version of Windows 10. It's often difficult to tell what version people should be using or whether any given version of Windows is supported.
If you want me to do something (like provide you with the new versions of the files) then please tell me.
I have no idea if you already have them or are working on a fix, or whether I can help in another way.
Defrag82 is offline
post #646 of 771 (permalink) Old 10-14-2019, 03:55 AM - Thread Starter
SweetLow's Avatar
Yes. That is what i want.
SweetLow is offline
post #647 of 771 (permalink) Old 10-14-2019, 10:48 AM
Rep: 0
I tried this but got inconsistent polling rates.
This is mostly an FYI for anyone else that has similar hardware. But if anyone has anything they could suggest to get it to run at a consistent 1000. I'd appreciate it.
System is Win 7 pro x64.
Amd 1800x
Microsoft Sidewinder X5 (yes it's old)
I didn't know what the default polling rate was.
So I tested with the Mouserate.exe.
The polling rate was steady at 500 with little variation.
I'm happy that my existing driver is running at 500. I was afraid that since it was old that it would be slower than that.
I installed Hidusb. (Not the Hidusb-FN version.)
It installed fine. Windows did not ask for or indicate the need to install the certificate.
I turned the filter on, and set it to 1000.
The AVERAGE polling rate did go to 999. (1000 effectively)
But the polling rate varied widely from 200-999. Seemingly jumping up and down for no apparent reason.
I turned the filter off and repeated the test several times.
With the filter off, using the default driver the polling rate was steady and varied very little from the average 499.
With the filter on and set to 1000, the polling rate swung wildly from 200-999. But the avg still showed 999.
I tried setting the filter to 500 just to see what would happen. Again the avg was 499 but the rate swung wildly through a range of 100-499.
The MS sidewinder mouse came with it's own driver and software. So maybe the two aren't compatible. And I did not install or use the certificate so maybe that was an issue as well.
I considered that it's an old mouse so may be mouse itself couldn't handle the 1000 rate, but it does 500 with it's MS driver very consistently and was inconsistent with the custom driver at both 1000 and 500.
So I'm still using the default driver.
I am interested in finding out if my gaming experience would improve if I was able to go from 500 to a steady 1000. But that may not be possible with this mouse.
Thanks for the files. I appreciate the effort that went into making them.
taggerinc is offline
post #648 of 771 (permalink) Old 10-15-2019, 07:45 AM - Thread Starter
SweetLow's Avatar
Just following links in sticky thread of Mice subforum:
>MouseTester Software Reoloaded: The go-to utility of this subforum for recording and analyzing everything performance-related in a mouse. Encompasses all functionalities found in Enotus (and does all of them better), with "x vs y" plot replacing MSpaint and MouseMovementRecorder for angle-snapping tests and 1x1 count tests respectively.
SweetLow is offline
post #649 of 771 (permalink) Old 10-16-2019, 06:31 AM
dior
Rep: 0
I also can't get it to work with 1903 - I can send you those files SweetLow if you need? Don't really want to retire my IMO but it's looking more and more likely. PM
Joel Burton is offline
post #650 of 771 (permalink) Old 10-16-2019, 08:48 AM - Thread Starter
SweetLow's Avatar
And what prevented you from doing this?
SweetLow is offline
