USB mouse hard overclocking (2000 Hz+) - Page 67 - Overclock.net - An Overclocking Community
post #661 of 724 (permalink) Old 10-20-2019, 11:34 AM
dior
Rep: 0
Quote: Originally Posted by SweetLow View Post
>will still downclock
Ok. If you really can downclock than you have working driver.
>using atsiv method
And what do you received when try hidusbfp.sys loading?
So I have my atsiv setup to run on startup with Task Scheduler, but if I load the driver manually I get: 'Operation completed successfully'.
I've not yet tried disabling secure boot but I feel doubtful it would makea difference.
Joel Burton is offline
post #662 of 724 (permalink) Old 10-20-2019, 12:17 PM - Thread Starter
SweetLow's Avatar
Rep: 55 (Unique: 31)
what??? it's impossible to have SUCH message on hidusbfP.sys loading through atsiv.exe.
Atsiv v1.01 - Windows driver loader
Copyright 2007 Linchpin Labs and OSR
All Rights Reserved
Attempting to start driver D:\TOOLS\ATSIV\hidusbfp.sys
Error 0xc0000001, operation failed
That is what expected.
SweetLow is offline
post #663 of 724 (permalink) Old 10-20-2019, 01:09 PM
dior
Rep: 0
All Rights Reserved
Ah sorry, my mistake, yes you're correct. Same result ^
post #664 of 724 (permalink) Old 10-20-2019, 06:10 PM
Rep: 0
I've dropped back to test mode on Windows 10 x64 1903 version 18362.418 and my WMO is working again at 1000hz (using https://github.com/LordOfMice/hidusb...r/hidusbfn.zip).
Couldn't get the atsiv method working again without test mode, but will keep trying.
Defrag82 is offline
post #665 of 724 (permalink) Old 10-21-2019, 06:29 AM - Thread Starter
SweetLow's Avatar
As i already said about such situation - the code inside hidusbf.sys and hidusbfp.sys responsible for patching is identical.
1. Look at the my log above. You shall have exactly the same response. And will be better for you and Joel Burton to send YOUR logs and don't send "i have the same result". Screenshots and logs are definitely better then words "I did all right but nothing is working."
2. If your REALLY ready for isolation of root of the problem in your system i can help. BUT! I (as probably all other people) really don’t like spending my time and not even getting any reaction in return.
SweetLow is offline
post #666 of 724 (permalink) Old 10-21-2019, 06:44 AM
dior
Rep: 0
Screenshot for mine. Have also PM'd you.
post #667 of 724 (permalink) Old 10-21-2019, 06:55 AM - Thread Starter
SweetLow's Avatar
Looks like your really try to load hidusbfp and (visually) nothing prevents to do so. Ok. If the next step (go to setup.exe and restart your mouse there with higher rate) isn't working then:
1. I will give your debug version of hidusbfp.sys some time later and describe what you have to do with it.
2. Check USB controller and its driver file (name and version) you are using for your mouse (the last addition to OP).
SweetLow is offline
post #668 of 724 (permalink) Old 10-21-2019, 07:53 AM
dior
Rep: 0
I have finally figured out what was wrong!
So my mouse despite being plugged into normal USB (no hub) - was going through a different xhci driver (asmtxhci.sys) which wasn't being recognised. I have since swapped some of my peripherals around at the back of my PC, ensuring the mouse was operating through USBXHCI.sys and now it looks like I'm overclock easy.
Thanks Sweetlow for the troubleshooting/help.
Cheers
post #669 of 724 (permalink) Old 10-21-2019, 08:17 AM - Thread Starter
SweetLow's Avatar
Cheers
Nice to hear that.
P.S. My offer to Defrag82 is still open, of course.
SweetLow is offline
post #670 of 724 (permalink) Old 10-28-2019, 04:35 AM
Rep: 0
500hz limit
https://github.com/MineSweeper73/100...ling-Hack-1903
The overclocking was successful as described above link, but there's a problem.
Why does my mouse only apply to 500 Hz?
Even if I set it at 1000 Hz, it works at 500 Hz.
I don't know if my mouse is the problem or my computer is the problem.
(windows 10 1903, usb 2.0 vertical mouse)
bin kk is offline
