USB mouse hard overclocking (2000 Hz+) - Page 73 - Overclock.net - An Overclocking Community
post #721 of 738 (permalink) Old 02-20-2020, 08:05 AM
EniGma1987's Avatar
Rep: 346 (Unique: 255)
Quote: Originally Posted by SweetLow View Post
>Using Windows 10 64-bit v.2004
>It looks like I need to download the "hidusbfn.zip" file for my version of Windows? https://github.com/LordOfMice/hidusb...r/hidusbfn.zip
No, with very high probability you need even more recent version:
https://www.overclock.net/forum/375-...l#post28099512
Or such version just does not exists right now. See the last p.s. of the first post.
And yes, read one of the manual referenced in the first post if you are experiencing a problem with figuring out what exactly you need to do.
And, of course, the best practice for hard overclocking is testing your system with overclockable device before you will try to overclock unknown devices.
Thanks for the reply. Downloading the newer version let me understand everything properly.
Your first post in the "PS" section seems to say use the "hidusbfn" file if I was on windows above version 1803. Since this is not true anymore, and because this file does not contain any setup.exe or readme files for how to do things it should probably be removed so as not to give out incorrect information.
EniGma1987 is offline
post #722 of 738 (permalink) Old 02-20-2020, 08:42 AM - Thread Starter
SweetLow's Avatar
Rep: 55 (Unique: 31)
What are you talking about? hidusbfn is ADDITION to hidusbf. When it is needed described exactly in the last p.s. (and hidusbf is needed always). But not only that is described there. Something about what you will need to do if you have VERY new Windows version.
SweetLow is offline
post #723 of 738 (permalink) Old 02-21-2020, 08:39 PM
keento's Avatar
Rep: 0
is there a way to set the mouse polling rate at 500 or 1000hz even when i dont move it?
the slight and slow movements are not detected and it's really annoying when playing
i am on windows 10
and i used many mice of different brands
keento is offline
post #724 of 738 (permalink) Old 02-22-2020, 11:47 PM - Thread Starter
SweetLow's Avatar
No. As minimum with normal firmware zero movements don't send to host.
It's strange especially with modern sensors and its possible high DPI settings.
SweetLow is offline
post #725 of 738 (permalink) Old 02-26-2020, 05:18 AM
Rep: 0
Anyone test the Ikari laser or optical past 1000hz?
1ms_hand2eye is offline
post #726 of 738 (permalink) Old 03-09-2020, 12:46 AM
Rep: 0
Hello.
I have the MSI Interceptor DS B1 mouse. Can I apply this overclocking to it?! Sorry i've never done such a thing before (still new to PC) so I'm afraid to mess things up.
Thank you.
LifeEngineer is offline
post #727 of 738 (permalink) Old 03-12-2020, 08:18 AM - Thread Starter
SweetLow's Avatar
Quote: Originally Posted by LifeEngineer View Post
Hello.
Thank you.
Yes. You can TRY to overclock any USB device.
It is safe kind of overclocking You can't break anything.
SweetLow is offline
post #728 of 738 (permalink) Old 03-18-2020, 05:40 AM
Rep: 0
This is how my administrator device list looks like:
Do I need to do anything before attempting the overclock? if so, what and how? its not clear to me on the main post.
Quake3WMOmafia is offline
post #729 of 738 (permalink) Old 03-30-2020, 04:07 PM
raboq3's Avatar
Rep: 0
i used to made this work years ago, but now i havent,
after 3 days, i have to ask for help :/
mouse: WMO 1.1a,
Win: 10 1909
my device tree, looks iquals as the previous postt,
Device:
"USB\VID_045E&PID_0040\5&7D4680E&0&4"
"USB\VID_045E&PID_0040&REV_0300"
"USB\VID_045E&PID_0040"
Name: Microsoft USB Wheel Mouse Optical
Driver: HidUsb
Binary: \SystemRoot\System32\drivers\hidusb.sys
Path: C:\WINDOWS\System32\drivers\hidusb.sys
Version: 10.0.18362.175 (WinBuild.160101.0800)
Binary: HIDUSBF.SYS
Path: C:\WINDOWS\System32\DRIVERS\HIDUSBF.SYS
Version: 1.2.0.0
LowerFilters: hidusbf
BusSpeed: 0
bInterval: 2
Overrided.bInterval: 2
Controller:
"PCI\VEN_8086&DEV_A36D&SUBSYS_201F1043&REV_10\3&11 583659&1&A0"
"PCI\VEN_8086&DEV_A36D&SUBSYS_201F1043&REV_10"
"PCI\VEN_8086&DEV_A36D&SUBSYS_201F1043"
"PCI\VEN_8086&DEV_A36D&CC_0C0330"
"PCI\VEN_8086&DEV_A36D&CC_0C03"
Name: Controladora de host USB genérico compatible con xHCI - Controlador de host eXtensible Intel(R) USB 3.1 - 1.10 (Microsoft)
Driver: USBXHCI
Binary: \SystemRoot\System32\drivers\USBXHCI.SYS
Path: C:\WINDOWS\System32\drivers\USBXHCI.SYS
Version: 10.0.18362.693 (WinBuild.160101.0800)
-Disable secureboot (ready)
-Set bcdedit -set loadoptions DISABLE_INTEGRITY_CHECKS (ready)
-Set bcdedit -set TESTSIGNING ON (ready and not)
-Rebooted (ready)
-Installed SweetLow Certificate (Make sure you install it under "Local Machine") (readyx10^1000)
-Copied atsiv to C:\Program Files\atsiv (ready)
-Created atsiv tasks in Task Scheduler copying MouseOC_1.xml & MouseOC_2.xml (ready changed VID)
-Run Setup.exe, Filter On Device @ 500 (ready)
-Install Service, click Restart. (ready)
also copied the /hidusbf/amd64/1khz/hidusbf.inf to /sys32/driver/
stuck on 125hz
can go 31hz and 62hz
any advice?
raboq3 is offline
post #730 of 738 (permalink) Old 03-30-2020, 04:29 PM
raboq3's Avatar
Rep: 0
mouse: WMO 1.1a,
Win: 10 1909
Device:
Driver: HidUsb
Binary: HIDUSBF.SYS
Version: 1.2.0.0
BusSpeed: 0
bInterval: 2
Controller:
Driver: USBXHCI
-Rebooted (ready)
stuck on 125hz
any advice?
after 1 more try, i made it
ty sweetlow
raboq3 is offline
