USB mouse hard overclocking (2000 Hz+) - Page 74 - Overclock.net - An Overclocking Community
post #731 of 757 (permalink) Old 03-30-2020, 05:24 PM
Don't play with fire or you will get burned IMO. Taking it to a ammount that can damage the mouse possibly... who knows!
INTEL 10980XE @ NO STOCK
GIGABYTE X299X AORUS MASTER
GIGABYTE WF RTX 2080
CORSAIR DOMINATOR PLATINUM RGB @ 64GB 3200 CL16 QUAD CHANNEL B-DIE
CORSAIR MP510 960GB M.2 GEN 3 SAMSUNG 950 PRO M.2 500GB 850 PRO 500GB CRUCIAL M4 500GB LaCie EXTERNAL 2TB PORSCHE DESIGN & 500GB eSATA
CORSAIR AX1600i TITANIUM @ CORSAIR 330r BLACKOUT EDITION CASE
CORSAIR H115i PRO RGB @ NOCTUA NF-14's INTAKE NF-14 EXHAUST NF-P12
AOC 40" CURVED 4k LG 55" C9 OLED G-SYNC 120HZ
Keyboard
LOGITECH 915 LINEAR WIRELESS
Mouse
LOGITECH G PRO WIRELESS LIZZARD GRIP 3M TAPE
Mousepad
STEELSERIES SMALL
Audio
LOGITECH G935 WIRELESS SCARLETT 2i2 AUDIO INTERFACE KRK ROKITS 10-3 Gen4 & SENNHEISER HD 650 & 4.5.0 BTNC SL GRAND 88 MIDI Controller CAKEWALK BY BANDLAB
Turtle Rig is offline
post #732 of 757 (permalink) Old 03-31-2020, 01:31 AM - Thread Starter
SweetLow's Avatar
Rep: 55 (Unique: 31)
Quote: Originally Posted by raboq3 View Post
-Disable secureboot (ready)
-Set bcdedit -set loadoptions DISABLE_INTEGRITY_CHECKS (ready)
-Set bcdedit -set TESTSIGNING ON (ready and not)
-Rebooted (ready)
-Installed SweetLow Certificate (Make sure you install it under "Local Machine") (readyx10^1000)
-Copied atsiv to C:\Program Files\atsiv (ready)
-Created atsiv tasks in Task Scheduler copying MouseOC_1.xml & MouseOC_2.xml (ready changed VID)
-Run Setup.exe, Filter On Device @ 500 (ready)
-Install Service, click Restart. (ready)
also copied the /hidusbf/amd64/1khz/hidusbf.inf to /sys32/driver/
stuck on 125hz
can go 31hz and 62hz
any advice?
It's good that you made software working. But i will comment you actions.
Ok.
IDK where this came from to Windows 10 1909. The only version where it is working is Vista RTM!
It is good for TEST mode and doesn't need for atsiv, of course.
>-Rebooted (ready)
Ok, if you disable secure boot (any possible method) or set Test Mode the reboot is needed.
IDK why, but i can run all without it installing
You can run it from any folder, of course.
I always recommended first to check atsiv manual and only after that run it trough scheduler task (one task, not taskS).
first to Install Service (one time), then Filter On Device @ 500, then Restart
there isn't .inf in this folder. probably you are talking about hidusbf.sys from hidusbfN.zip. This action is needed for Test Mode method only and prohibited for atsiv.
SweetLow is offline
post #733 of 757 (permalink) Old 04-01-2020, 08:13 PM
smcelroy86's Avatar
Rep: 0
I can get the USB overclocked to 500Hz with either test mode enabled or without it enabled using ATSIV. However the anti cheat software for FACEIT requires test mode to be disabled and states ATSIV is not allowed and I must uninstall it. So is there no fix for this or am I missing something? Thanks peoples. (On Windows 10 1909 BTW)
smcelroy86 is offline
post #734 of 757 (permalink) Old 04-01-2020, 09:27 PM - Thread Starter
SweetLow's Avatar
Yes, because you continue to ignore recommended reading.
SweetLow is offline
post #735 of 757 (permalink) Old 04-02-2020, 06:13 AM
EniGma1987's Avatar
Rep: 348 (Unique: 257)
In all fairness, your "recommended reading" is a contradictory mess that few can decipher.
EniGma1987 is offline
post #736 of 757 (permalink) Old 04-02-2020, 07:21 AM - Thread Starter
SweetLow's Avatar
I always asked to point to these "cryptic, dull, jibberish... " and have ZERO return right now. I listen you very carefully...
SweetLow is offline
post #737 of 757 (permalink) Old 04-02-2020, 09:03 PM
smcelroy86's Avatar
Rep: 0
I read your entire post friend, I am not a "computer person" and trying my best to make this work. All you offer is rude comments in return, I understand you get endless questions, still no reason to be impolite.
post #738 of 757 (permalink) Old 04-03-2020, 04:36 AM - Thread Starter
SweetLow's Avatar
Of course, it is not rude. If you not a "computer person" than you must RTFM all. If you don't understand why - that manual exactly for not a "computer person". But if you still have problems then AFTER that i will help.
Ok, if you read entire post did you notice "If you use atsiv then check your AV (or something else like anti-cheat engine) in case you are unable to load atsiv. Or use atsiv and then unload it completely before loading of such engine." link? It's is exactly what you need and i assume the only point where such engines mentioned at all.
SweetLow is offline
post #739 of 757 (permalink) Old 04-16-2020, 05:48 PM
ELKR's Avatar
Rep: 0
The first mouse I overclocked started randomly disconnect and reconnecting. I looked it up and it says that a damaged usb cable will do that. When I would wiggle the thin usb cable near the mouse it would disconnect and reconnect. I assumed the cable broke from use.
My new mouse is now disconnect and reconnecting while playing games. It never does it on the desktop. Even if I disable filter on device it still does it. Did I damage the mouse by overclocking it? I'm left with no mouse
ELKR is offline
post #740 of 757 (permalink) Old 04-17-2020, 12:52 AM - Thread Starter
SweetLow's Avatar
It looks more like a bad port, not the mouse itself. Of course, to isolate problem exactly you have to check this mouse on other PC and other mouse on this PC.
P.S. You have time to write a long post with very little information. Where is the mouse model for example?
SweetLow is offline
