How does surface calibration work? - Overclock.net - An Overclocking Community
post #1 of 21 (permalink) Old 03-11-2016, 10:00 AM - Thread Starter
Linux Lobbyist
m0uz's Avatar
Rep: 68 (Unique: 52)
Talking about IR sensors, don't care about laser.
Is it something to do with LED intensity? I'm fascinated by it. I had a really rough cloth pad which had a LOD of about 4-5 CDs with the Torq X5 on default. After surface tuning, it came down to Zowie levels. Incredible.
m0uz is offline
post #2 of 21 (permalink) Old 03-11-2016, 11:34 AM
lololol
qsxcv's Avatar
Rep: 362 (Unique: 150)
no it just adjusts sensor parameters which determine the lift-off detection threshold. basically things like how much contrast there must be in the image it sees in order to consider tracking
btw for the case of 3366, i was wrong; the surface calibration affects tracking directly, not just the lift-off.
too busy to check forums as regularly
pm me if i forget to respond
qsxcv is offline
post #3 of 21 (permalink) Old 03-11-2016, 11:45 AM
Mouse reviewer
Ino.'s Avatar
Rep: 405 (Unique: 238)
Decreasing led intensity is a ghetto solution supposedly used on some older A3090 mice. But I'm not sure which. As qsxcv said it's not used for new sensors.
Please elaborate, I wasn't around for a while. What else does it do?
Ino. is offline
post #4 of 21 (permalink) Old 03-11-2016, 11:50 AM
lololol
qsxcv's Avatar
according to the datasheet
one register adjusts the lift-off threshold, the other adjusts the threshold for determining what counts as a feature or not
qsxcv is offline
post #5 of 21 (permalink) Old 03-11-2016, 11:54 AM
Maximillion's Avatar
Rep: 123 (Unique: 88)
I'm not sure if having less "features" of a surface recognized is really a good thing.
"To give the gamer more control and command over so much power there is some sort of a smoothing agent incorporated on the mouse chip that gives that different feel, that edge, that authority over your shots."
Maximillion is offline
post #6 of 21 (permalink) Old 03-11-2016, 11:56 AM
lololol
qsxcv's Avatar
likewise being too eager to consider something a feature isn't good either.
so that's how surface calibration could potentially improve the tracking,
qsxcv is offline
post #7 of 21 (permalink) Old 03-12-2016, 01:09 AM
pixie99's Avatar
Rep: 2 (Unique: 2)
Should the g303 used with drivers then? I realised that it doesn't have a function to adjust LOD
pixie99 is offline
post #8 of 21 (permalink) Old 03-12-2016, 07:10 AM
c0dy's Avatar
Rep: 34 (Unique: 31)
In theory you can add a calibration and tweak the settings yourself in
"AppData\Local\Logitech\Logitech Gaming Software\settings.json"
"surfaceTuning" :
    "Logitech.Gaming.Mouse.G303.Daedalus.Apex" :
      "{8d56eb33-30d4-421b-8058-17ca8f582f31}" :
        "ledDrive" : 0,
        "minSqual" : 255,
        "name" : "Puretrak",
        "pixelThreshold" : 5,
        "time" : 1456507907
I've tested pixelThreshold and minSqual. Only pixelThreshold made a difference tho.
Everything past 15 made my mouse not move at all.
Just close the Logitech Software, Edit and Save the file and restart the Software and apply the calibration (switch to the default one first).
Havn't tested changes with the moustester plots tho. So if anybody wants to, maybe you can find something out.
c0dy is offline
post #9 of 21 (permalink) Old 03-12-2016, 09:28 AM
lololol
qsxcv's Avatar
yup pixelthreshold is the register that could affect tracking
you can uninstall the software after the calibration if you like
qsxcv is offline
post #10 of 21 (permalink) Old 03-12-2016, 10:30 AM
Furiosus's Avatar
Rep: 5 (Unique: 5)
Since I can only manually configure the 3366, would someone with a G502 or 303 be able to post the the Surface Analysis for the Zowie G-TF Speed?
Furiosus is offline
