Click Latencies compiled - Page 32 - Overclock.net - An Overclocking Community
post #311 of 377 (permalink) Old 01-01-2019, 06:52 AM
Rep: 0
Does the G300s have the same latency as G300?
MousePro is offline
post #312 of 377 (permalink) Old 01-11-2019, 11:39 AM
Timecard's Avatar
Rep: 6 (Unique: 6)
Is the bump test a relatively accurate or repeatable method for measuring click latency across different systems or what is the variability between doing this on other systems? Assuming they have the same mice and each mouse has the same firmware, MCU, and switches for those vendor models. Also would having each mouse on a different controller noticeably impact the results?
I assume every system will have a base processing speed/latency between input buffers so differences on the test system should be relatively consistent or at least proportionate.
If this was discussed somewhere else let me know, I haven't found it yet or i missed it over the totality posts.
Timecard is offline
post #313 of 377 (permalink) Old 01-12-2019, 07:39 AM
impopo's Avatar
Rep: 0
I would like to know if when we move the mouse and the latency of the click are the same ?
impopo is offline
post #314 of 377 (permalink) Old 01-12-2019, 11:18 AM
TranquilTempest's Avatar
Rep: 78 (Unique: 63)
Short answer is no. Long answer is that some sources of latency impact both(like USB polling rate), and some sources of latency only impact one or the other(image processing in the sensor, delay based debounce for switches).
TranquilTempest is offline
post #315 of 377 (permalink) Old 01-25-2019, 09:49 AM
sprite08's Avatar
Rep: 6 (Unique: 3)
Quote: Originally Posted by vf- View Post
Interesting...
Steelseries Rival 310 is 4.4
I'm shocked at the Steelseries Sensei 310. 10.3ms
rival 310 isn't 4.4. KPM fw1.12 (right key) vs rival 310 fw 1.33.0.0 (left key)
sprite08 is offline
post #316 of 377 (permalink) Old 01-29-2019, 10:38 AM
Mouse Junkie
vanir1337's Avatar
Rep: 37 (Unique: 34)
Microsoft Pro IntelliMouse
+5.9 compared to Ikari, +1.4 compared to G203 (the test was done with covered lenses).
Logitech G PRO Wireless | Custom Huado Mousepad | Sharkoon PureWriter TKL Blue | HyperX Cloud
vanir1337 is offline
post #317 of 377 (permalink) Old 01-31-2019, 07:47 AM
Mouse Junkie
vanir1337's Avatar
Cooler Master MasterMouse MM830
+6 ms to Ikari (+1.5 ms to G203, covered lenses)
(Sorry for posting this and the previous one separately, forgot to do this one. )
post #318 of 377 (permalink) Old 02-05-2019, 06:22 AM
RamenRider's Avatar
Rep: 2 (Unique: 2)
Can someone test Cooler Master Mizar? It is my favorite mouse and I believe it to be test worthy. There is a setting on the software that allows it to change the Button Response time ranging from 250us to 32ms. There are also 2 firmware versions that change the latency of several buttons.
Redpilled Current Rig Ryzen 5-1600/XFX Black Edition RX-580/Asus x370 Pro-Gaming/Geil Super Luce 3000hz 16GB/
RamenRider is offline
post #319 of 377 (permalink) Old 02-27-2019, 10:06 PM
sprite08's Avatar
Rep: 6 (Unique: 3)
rival 310 fw 1.33.0.0 (right key) vs kinzu v1 (left key) => rival 310 is 7 - 8ms
Name:	kz vs rival.jpg
Name:	kz vs rival 1.jpg
sprite08 is offline
post #320 of 377 (permalink) Old 03-09-2019, 05:25 PM
pox02's Avatar
Rep: 2 (Unique: 2)
Msi GM60
+0.9 ms to Ikari (-0.6 ms to IRIS)
pox02 is offline
