Click Latencies compiled - Page 46 - Overclock.net - An Overclocking Community
post #451 of 497 (permalink) Old 03-31-2020, 04:55 AM
Mouse addict
cdcd's Avatar
Rep: 33 (Unique: 23)
Quote: Originally Posted by badben25 View Post
inb4 +20ms after firmware update
I've suggested they should do the same thing ROCCAT is doing (ZeroDebounce) and make it an option, either very low debounce + slam clicks or slightly higher debounce + no slam clicks. Fingers crossed...
Mice currently owned: Logitech G402/G403/G303/G Pro, Zowie FK1/EC2-A/EC2-B/ZA12, Razer Deathadder 2013/Basilisk, Cooler Master Mastermouse S/MM530/MM520, Roccat Kone Pure Owl-Eye, Dream Machines DM1 Pro S/FPS/DM3 mini, EVGA Torq X3/X5, Ninox Venator, HP Omen 600, Thermaltake Ventus X RGB Optical/Ventus R, Microsoft WMO, Steelseries Rival 310, Nixeus Revel, Ozone Neon M50
Looking to buy and try: Ninox Astrum
cdcd is offline
post #452 of 497 (permalink) Old 04-08-2020, 10:48 AM
Ainalcar's Avatar
Rep: 1 (Unique: 1)
If it is what I think it is, that's not unusual. All Logitech mice also switch to double their click latency when lifted.
Do you have any info on whether XM1 has the same issue?
Thanks
Ainalcar is offline
post #453 of 497 (permalink) Old 04-10-2020, 09:38 PM
senileoldman's Avatar
Rep: 13 (Unique: 13)
More or less obscure mouse, but the Valkyrie Pro 2.0 (only G9x clone on the market) has 16.1ms click delay compared to the Ikari.
senileoldman is offline
post #454 of 497 (permalink) Old 04-11-2020, 05:29 PM
Rep: 0
Wireless Mouses Faster?
Howdy,
Can someone tell me how Linus's
video fits into this discussion? Linus's test found that several good wireless gaming mouses have an equal and sometimes better click-to-screen-response time as good wired gaming mouses. He used an interesting method: frame by frame analysis with a 1000FPS video camera. I see the click latency table in the first post and it made me wonder if Linus's results support the click latency table or not. I will admit to being a true novice here so I welcome all replies! Thanks! --Jhana108
jhana108 is offline
post #455 of 497 (permalink) Old 04-11-2020, 06:02 PM
TranquilTempest's Avatar
Rep: 79 (Unique: 64)
Quote: Originally Posted by jhana108 View Post
Howdy,
Can someone tell me how Linus's Wireless Mouse Response Time Test video fits into this discussion? Linus's test found that several good wireless gaming mouses have an equal and sometimes better click-to-screen-response time as good wired gaming mouses. He used an interesting method: frame by frame analysis with a 1000FPS video camera. I see the click latency table in the first post and it made me wonder if Linus's results support the click latency table or not. I will admit to being a true novice here so I welcome all replies! Thanks! --Jhana108
The test methodology isn't ideal, because some mice go into a power saving mode when not actively moving, and you're clicking at the end of the motion, not the start of it. It would be much better to compare the USB output of a mouse to the output of an independent linear encoder, so that you can compare linearity and latency over the whole motion, not just the start point. It's also dubious to use a high speed camera for this, when you could just read the USB data directly, and avoid all the confounding variables of the PC's render chain, and the monitor's refresh rate.
TranquilTempest is offline
post #456 of 497 (permalink) Old 04-12-2020, 03:21 AM - Thread Starter
¯\_(ツ)_/¯
badben25's Avatar
Rep: 44 (Unique: 36)
Do you have this mouse with you? I've been curious about it for quite a while.
And apparently you can adjust the click latency in the software. Have you tried doing so?
badben25 is offline
post #457 of 497 (permalink) Old 04-15-2020, 08:54 AM
Rep: 60 (Unique: 49)
Noticed button up on the M545 wireless seems to take surprisingly longer.
Kinzu v2 USB showing better symmetry
24ms up or down FW 0.98.
Logitech M150 wireless
Down : Avg 7.92, Min 5.99, Max 10.00, Median 8.00
Up : Avg 39.03, Min 38.00, Max 40.01, Median 39.97
Times in milliseconds
Again wireless showing much longer time for mouse button up
Generic Sigmachip MX8733 USB
Down 16 ms
Up 16ms
Measurements are absolute, not relative.
ucode is offline
post #458 of 497 (permalink) Old 04-20-2020, 08:53 AM
ELKR's Avatar
Rep: 0
Has any mouse with optical switches been tested yet for example the razer viper?
ELKR is offline
post #459 of 497 (permalink) Old 04-22-2020, 08:27 AM
ELKR's Avatar
Rep: 0
I bought a zalman zm-m600r. The click latency chart says fm1.18 to 2.26. Mine came with firmware 2.29.
Was version 2.29 firmware tested?
Is it possible to downgrade firmware?
ELKR is offline
post #460 of 497 (permalink) Old 04-22-2020, 08:44 AM
Mouse addict
cdcd's Avatar
First time I'm hearing that the M600R came shipped with a FW this recent.
In general, I'd advise against updating to any FW past the release one on the Zalman. Read from here onward for further details.
cdcd is offline
