B.FRIEND G2 Lizard 3360 (Korean G Pro clone, possibly with straight sides) - Page 2 - Overclock.net - An Overclocking Community
post #11 of 21 (permalink) Old 10-06-2017, 11:03 AM
s0rry's Avatar
Rep: 10 (Unique: 8)
Why does everyone want straight sides?
s0rry is offline
post #12 of 21 (permalink) Old 10-06-2017, 11:32 AM
Linux Lobbyist
chr1spe's Avatar
Rep: 20 (Unique: 17)
Apparently the slight curvature on the sides of the g pro makes it unusable for some people for what ever reason. I don't really understand why, but it seems a lot of people are much more picky about shapes than I could even consider being. As long as a mouse is small and has a narrow butt I'm fine for the most part. I will say I don't like that the curvature makes the contact area between my fingers and the mouse smaller. If anything I would rather have it curved the opposite direction so it was more concave instead of convex on the sides. Its still very grippy and easy to hold on to though since it is wider at the top than the bottom.
chr1spe is offline
post #13 of 21 (permalink) Old 10-06-2017, 12:03 PM
AAGGHH~ MY EYES~ AAGGHH~
uaokkkkkkkk's Avatar
Rep: 157 (Unique: 67)
in this case, b friend, akko, n key, are all from the same chinese factory/manufacturer. so whatever.
uaokkkkkkkk is offline
post #14 of 21 (permalink) Old 10-06-2017, 02:48 PM
s0rry's Avatar
Rep: 10 (Unique: 8)
Having the sides curved inward make it easier to grip with claw grip. One of the reasons why I didn't like the G100s is because the sides were too straight.
s0rry is offline
post #15 of 21 (permalink) Old 07-20-2020, 04:10 PM
Heleii's Avatar
Rep: 2 (Unique: 1)
Did anyone actually get this mouse? Judging by pictures (see the curve at the base) and some korean reviews, the shape should be closer to Logitech G1. I also found a sound test.
Heleii is offline
post #16 of 21 (permalink) Old 07-21-2020, 03:17 AM
Heleii's Avatar
Rep: 2 (Unique: 1)
Okay here's another view on the shape (google translate):
Regarding the grip feeling, many critics say that the grip feeling of g2 is similar to that of g1. I've been using the G1 for years, and I've used the g1-like mouse several times. However, the grip of the G2 doesn't seem to match the G1 perfectly. I think it's a bit closer to the feel of the G1 than the NMOUSE 4K or G102. It's because it's glossy... and it feels a bit bigger than the G1. The hips are almost similar. Same for the side length. But the G2 is definitely longer. I think it would have been nice if my hands were slightly bigger
If you are about the size of your hand F10, I think it will be perfect for your use.
If you look at the bottom, it's a bit longer than the G1? You will see that.
The G102 and G PRO are also good mice, but there are some people who feel like they are'empty' when they grasp. The G2 seems to be good in that it fills in those deficiencies.
Heleii is offline
post #17 of 21 (permalink) Old 07-21-2020, 04:50 AM
Mouse addict
cdcd's Avatar
Rep: 33 (Unique: 23)
Abkoncore A660 (AKA Abko Hacker A660) shell by the way, nothing particularly special.
Mice currently owned: Logitech G402/G403/G303/G Pro, Zowie FK1/EC2-A/EC2-B/ZA12, Razer Deathadder 2013/Basilisk, Cooler Master Mastermouse S/MM530/MM520, Roccat Kone Pure Owl-Eye, Dream Machines DM1 Pro S/FPS/DM3 mini, EVGA Torq X3/X5, Ninox Venator, HP Omen 600, Thermaltake Ventus X RGB Optical/Ventus R, Microsoft WMO, Steelseries Rival 310, Nixeus Revel, Ozone Neon M50
Looking to buy and try: Ninox Astrum
cdcd is offline
post #18 of 21 (permalink) Old 07-22-2020, 04:13 AM
Heleii's Avatar
Rep: 2 (Unique: 1)
I don't think the shape is the same. If you look at the base, they are very different. A660 looks more like G102/G203/Pro.
I won't probably get this mouse because it's bigger (at least longer) than G1.
Heleii is offline
post #19 of 21 (permalink) Old 07-22-2020, 04:31 AM
Mouse addict
cdcd's Avatar
You be the judge:
cdcd is offline
post #20 of 21 (permalink) Old 07-24-2020, 02:32 AM
Heleii's Avatar
Rep: 2 (Unique: 1)
I'm talking about small differences, just like G1 vs G102. Surely they are quite similar but these small details can make a difference.
Heleii is offline
