Mousepad Slower Than G-SR? - Page 6 - Overclock.net - An Overclocking Community
post #51 of 57 (permalink) Old 12-16-2017, 11:03 PM
Zhuni's Avatar
Rep: 22 (Unique: 19)
I wonder if it might be worth experimenting with treating the surface your self. Grab a few qck minis and try out some different things
Zhuni is offline
post #52 of 57 (permalink) Old 12-17-2017, 12:28 PM
Eh, Wha?
Zero4549's Avatar
Rep: 724 (Unique: 534)
Going with the above post, if you really want a sluggish but still smooth surface, apply candle wax.
Systems: Fukurou | Prodigy | Tempest | ArcaneServers: Minecraft SMP | Logs: Build Log - Arcane | Video Logs: Project Arcane
Quote:Originally Posted by Zen00 https://www.overclock.net/img/forum/go_quote.gifZero, you are a master story teller, I am sleep now. http://files.overclock.net/images/smilies/thumb.gif
Stygian
(14 items)
Arcane
(33 items)
Sanctum
(9 items)
6700
Trident Z RGB
Intel 660p
WD Gold
Seasonic Focus Plus Gold
NZXT H440 Razer Edition
Operating System
Windows 10 Pro
Nixeus NX-EDG27v2
Dell S2316H
Keyboard
X-Armor U9BL
Mouse
Razer Deathadder Chroma
Mousepad
Cougar Control
Audio
Creative X7 LE
Audio
Audio Technica ATH-A900X
Core i7 980x
GIGABYTE GA-EX58-UD5
MSI GeForce GTX 1080TI DUKE
MSI GeForce GTX 680 Lightning
Kingston HyperX T1
Samsung 840 EVO
WD Caviar Black FASS
Plextor M5S
WD Velociraptor
WD FALS
Optical Drive
Sony DVD Burner w/ Lightscribe
Optical Drive
LG Bluray + HDDVD
EVGA 1000 P2
Black Ice GTX 360
Black Ice GTX 240
Cooler Master HAF 932
Operating System
Windows 10 Pro (64)
X-Star DP2710
ASUS VK266H Black 25.5" 2ms LCD
Keyboard
X-Armor U9BL (Mech)
Mouse
Mouse
Cougar Control
Audio
ATH-A900X
Audio
Maudio AV-40
Audio
Polk PSW-10
Audio
Zalman Mic-1 (Clip-on Mic)
Audio
Sound Blaster X7 LE
Other
Logitech G13
Other
Wacom Intuos 3
Other
Modded PS4, PS3, Xbox 360, and Logitech PC Controllers
Other
Thrustmaster T.16000M FCS HOTAS
Other
Rocketfish 720p Webcam
Other
Scythe "3-Foot Switch"
Ryzen 7 1700
MSI B350M Mortar Arctic
RX Vega 64
G.Skill TridentZ
Samsung EVO 960
Consatellation
Corsair HX 1050
Raijintek Aeneas White Window
Operating System
Windows 10 Pro
Zero4549 is offline
post #53 of 57 (permalink) Old 05-19-2019, 07:43 PM - Thread Starter
MattKelly's Avatar
Rep: 0
Thought I'd bump this to see if anyone has found something since this thread was created. I went on to alter some surfaces myself (i.e. sanding certain types of cloth, shaving with a razor, all sorts of weird stuff) and while I was sometimes able to create something that was *slightly* slower, it was always at the cost of the surface losing its smoothness or consistency.
So, still after a pad that is slower than my worn black G-SR, but while retaining an overall smoothness.
MattKelly is offline
post #54 of 57 (permalink) Old 05-19-2019, 09:22 PM
Rep: 2 (Unique: 2)
imo best way to achieve this would almost certainly be changing feet to a completely different material. teflon/uhmw etc are all used for low friction reasons, so if you want dramatic changes in friction this would be the fastest route
I really don't know anything about plastics, but you could try getting various materials and just cutting them out. anything that's used in machine work could probably do the trick. there is obviously a thing as too much friction hence not using rubber side of mouse pad and stuff, so this stuff can get way too slow really quickly. Some of this stuff can be pretty mean to mouse pads, too. Some really cheap office mice just have abs plastic circles that are the same material as the rest of the mouse. Can confirm it's a little slower, but it actually still glides. It's kinda rough upon first use, but it's on the more tolerable side. I doubt abs feet would be the solution, but weird things like that would definitely be the fastest way to make gains. Would have to replace those materials pretty constantly tho feelsbad
I've also seen people on this site actually talk about making wooden mouse feet :^)
Another thing that I actually hate myself for saying is lighter weight stuff MIGHT not actually be "better." I've used really lightweight stuff and I actually know you have as well, so it might sound weird since it obviously feels better to just toss around. I use a g303 w/ stock feet on a g-sr-se and at one point I tried modding weight down a little bit (still definitely heavier than some other mice I've tried) and it felt really off. I don't know what my opinion is on weight anymore even tho it's "obvious" lighter should be better. The entire experience made me pretty uncomfortable and I went back to normal weight G303. I don't know if this is just because I've used a normal weight G303 for a few years as my main and am used to it. I had issues with shape for the really light stuff I've used, so I have not had a proper comparison for weight alone on a shape I like until messing with G303.
Lolcarrots is offline
post #55 of 57 (permalink) Old 05-19-2019, 09:49 PM - Thread Starter
MattKelly's Avatar
Rep: 0
I resonate with all of this post, haha. Just last night I did extensive testing on heavier vs lighter weight on mice (AB'ing two of the same shapes but with altered weights) solely because I wanted a slower interaction between my mouse and the pad. I've also done my best to familiarize myself with the physics side of all this, so between thinking objectively and testing my subjective impressions as well, I've come to the conclusion that I still do think lighter weight is better. The benefit that is gained from the heavier shell is indeed the increased feeling of control / stability, but I feel that's only coming from the side effect of higher friction. The increased inertia of the higher weight is a simultaneous negative in my opinion (most notably when doing fast corrections during LG fights, but also in the ability to stop large flicks with as much stability as possible). So in my head I'm thinking: light shell (when possible), but as slow of a pad / feet interaction as I can find (without static:dynamic friction being affected so heavily that smoothness is lost). Right now on my worn black G-SR I can still make incredibly light / slow movements if needed and the mouse will move very smoothly - it never sticks - but I know I can achieve even slower (in fact, I know I can achieve something much slower, because of a happy accident...)
So I was using some black hotline feet from China, and I forgot to take the plastic off of them. Immediately I noticed a slower and smoother setup than I've ever felt before (and I've tested a lot of pads / feet at this point...) Unfortunately the protective plastic eventually curled up on me and became unusable, but for that short period of time my suspicions were confirmed for me. Right now I'm using PureTrak's Original feet (the small blue plastic-y feet, not the HD version they sell) and so far those are the slowest feet that I've found. I've tried Artisan's feet in the past (both materials and in both shapes - doughnut hole vs the solid circles) and I've also tried the Hotline Master feet. I mention the Artisan and Master feet in particular because they were among the slower options I've found, however they both created that sticking effect where the static friction was too high relative to the dynamic friction, so I couldn't do smooth, slow, small movements. This doesn't happen with the PureTrak Original feet at all, and on top of that the dynamic friction manages to still be noticeably slower than the Artisan / Master feet. So that's where I'm at right now - still preferring lighter weight so long as I can balance that with a slow enough setup for pad / feet - and so far that's my black G-SR with the PureTrak Originals, but I know there is more improvement to be found here (those few minutes with the protective plastic left on were really nice, gosh darn it...)
post #56 of 57 (permalink) Old 05-19-2019, 10:20 PM
Rep: 2 (Unique: 2)
I personally know I definitely won't go any heavier than stock g303, but it's so awkward feeling for specifically this mouse. I have REALLY liked the super lightweight feeling on stuff like the croad m325, but specifically the g303 was different for me. I don't know if this is because of the angled sides causing me to ever so slightly lift upwards and the weight could cause me to keep the mouse more on the pad.
Have you tried using various tapes? Not PTFE or UHMW, but something else. If you know you like the protective plastic layer, that's actually pretty convenient since you could probably find something with an adhesive already on it for that purpose.
post #57 of 57 (permalink) Old 05-19-2019, 10:29 PM - Thread Starter
MattKelly's Avatar
Rep: 0
That's interesting you have a different perspective with the G303 specifically. I can't really comment much in that regard - I have one lying around here as well, but I don't use it because the slanted sides \__/ mess with my finger adjustments. I'm more of a straight |__| sides kind of guy.
I haven't tried various tapes yet (it's been in the back of my head for a while though). I guess I just don't know where to start. Every coefficient of friction table I look up mostly deals with UHMW, PTFE, etc... and you're right that it's convenient I have some inclination to what I liked, but even still I don't know where to start since it was just the flimsiest piece of plastic. Not sure what I'd be looking for (I mean, some type of adhesive dots yeah, but I don't really know what type of plastic / material I'm searching for).
