Sensor upgrade for g9x possible? - Overclock.net - An Overclocking Community
post #1 of 14 (permalink) Old 02-01-2018, 05:00 AM - Thread Starter
Linux Lobbyist
Tsubakii's Avatar
Rep: 0
Has anyone managed to put a 3360 sensor inside the g9x? Or fit a 3360 mouse inside a g9x grip? anything similar?
i swear by god
thanks if you have anything to contribute to this topic. this mouse has the best fingertip grip design of all but it's stuck with a laser sensor...
Tsubakii is offline
post #2 of 14 (permalink) Old 02-01-2018, 05:32 AM
Aliandro1d's Avatar
Rep: 5 (Unique: 4)
Sure you can do it some people here might even do it for a price i dunno what the g9 is kike inside but generally you either stick a 3360 pcb mouse in the g9 shell cut out any plastic that stops it sitting flat and find some way to securely mount the pcb generally people cut out the posts from their other mouse and glue them on to the bottom of the modded mouse, or some one here more tech savy than i can use a custom board with a 3360 and do what every they do to fit it all in. But yes it's posible i put my rog sica 3310 pcb into some random old school samsung mouse shell(insane shell so good) trickiest part was getting the shells buttons to hit the omrons you have to do allot of cutting and testing of plastic pieces if the shell doesn't naturally allign, also cut a big hole in the bottom so the sensor can actually trackand the. might post some pics later.
Aliandro1d is offline
post #3 of 14 (permalink) Old 02-01-2018, 07:29 AM
gipetto's Avatar
Rep: 9 (Unique: 7)
here's what its like inside. I'd hacksaw the pcb across behind the wheel and desolder everything. that's what i did with my kone xtd. the tilt wheel won't work though.
gipetto is offline
post #4 of 14 (permalink) Old 02-01-2018, 08:55 AM
munchzilla's Avatar
Rep: 59 (Unique: 50)
bit OT but does anyone have the videos from the guy who made the video in the OP? I can't find the rants he made.
munchzilla is offline
post #5 of 14 (permalink) Old 03-01-2018, 08:34 AM - Thread Starter
Linux Lobbyist
Tsubakii's Avatar
Rep: 0
Quote: Originally Posted by gipetto View Post
https://www.youtube.com/watch?v=cCs2dr-XOSA&t=360s
ive disassembled my g9x multiple times but the inside sure is a mess, its nothing like the kinzuadder
Tsubakii is offline
post #6 of 14 (permalink) Old 03-01-2018, 11:20 AM
gene-z's Avatar
Rep: 37 (Unique: 34)
Look at the Zalman 4k. It's a small shape similar to G100s, but a tiny bit smaller and better sensor. Looks almost identical to the g9x, minus the shell addon.
gene-z is offline
post #7 of 14 (permalink) Old 03-03-2018, 05:01 PM
Linux Lobbyist
revoc's Avatar
Rep: 0
I wish I still had mine. Such a classic.
revoc is offline
post #8 of 14 (permalink) Old 05-05-2018, 07:16 AM
c1tramon's Avatar
Rep: 0
https://www.youtube.com/watch?v=aZ7aBzQyDKM
i swear by god
Hi.
My old dream is also related to the modification of the G9 mouse. This is the most convenient form for me, for which it is impossible to find a replacement.
I turned to Logitech with the question about what it was good to make a spectacular G9 mouse comeback, and do it on the basis of the actual sensor.
Logitech Marketers was not interested in this idea, as it seemed to me.
There is already experience in implementing 3366 in the body of another mouse (in Russian):
https://mysku.ru/blog/diy/62432.html
As for G9, it has a functional that is not inherent in other bodies, namely, a rocker for switching the DPI levels (+ and -). This is a problem for me, which I think about.
Nevertheless, for the solution of my problem the electrical circuit of G502 mouse can be useful. It also has a two-position switch for the DPI levels.
At the same time, I do not rule out the possibility of performing a modification with the Mercury sensor from the G102 mouse, which satisfies my requests. However, the G102 mouse has only one cyclic DPI switch, and its electrical circuit is constructed in a different way.
Here is my patient (fully operational) and his alleged donors:
rivBox
(28 items)
Intel Core i7-8700K
ASRock Z370 Extreme4
Palit GeForce GTX 1070 Super JetStream
G.Skill Ripjaws V 2x8GB DDR4 PC4-25600
Samsung 850 EVO 500 Gb
OCZ Vertex 4 128Gb
WD Red 2TB NAS (WDC WD20EFRX-68EUZN0)
Optical Drive
Samsung SH-S223C
be quiet! Dark Power Pro 11 650W
Noctua NH-D14
Scythe GentleTyphoon 120 mm
Cooler Master MegaFlow 200 mm
CM HAF 922
Operating System
Windows 10 x64
LG 23MP65D-P
Keyboard
logitech g810 orion spectrum
Mouse
Steel Series Rival 500
Mouse
Logitech G403 Prodigy Wired Programmable Gaming Mouse
Mouse
Mad Catz R.A.T. PRO S Gaming Mouse
Mouse
Logitech G502 Proteus Core Gaming Mouse
Mouse
Logitech G9 Gaming Mouse
Mouse
Logitech G102 Prodigy
Mousepad
Kingston HyperX FURY Pro M Mousepad
Mousepad
Razer Goliathus 2013 Speed Standard Mousepad
Mousepad
Logitech G240 Mousepad
Audio
Creative SB Audigy SE
Audio
Kingston HyperX Cloud II
Audio
Pioneer SE-M390
c1tramon is offline
post #9 of 14 (permalink) Old 05-06-2018, 02:44 AM
Ex-resident Kinzu shill
Alya's Avatar
Rep: 62 (Unique: 39)
Weren't you using the Aurora Tsubaki? Anyway, I saw a guy that fitted an NKEY G007 into a wide grip on this site. Post is here https://www.overclock.net/forum/26976409-post144.html
It's this guy https://www.youtube.com/channel/UCHJ...QVtV4xs7KRDXpg I'm subbed to him, his content is great.
"Push your mouse to the limited with Overdrive. Legendary shape enhanced with premium martials."
Alya is offline
post #10 of 14 (permalink) Old 05-06-2018, 09:43 AM
c1tramon's Avatar
Rep: 0
Thanks for the idea.
In this way, you can put the G9 armor on a G102 mouse. Although, this is only an approximation to the ideal form, because the functionality of the mouse G9 will be lost.
It is a pity that the armor does not fit on the G102 mouse (not compatible in size). But, if desired, you can refine the body of the mouse G102.
rivBox
(28 items)
Intel Core i7-8700K
OCZ Vertex 4 128Gb
Optical Drive
Samsung SH-S223C
Noctua NH-D14
CM HAF 922
Operating System
Windows 10 x64
LG 23MP65D-P
Keyboard
Mouse
Mouse
Mouse
Mouse
Mouse
Mouse
Mousepad
Mousepad
Mousepad
Audio
Audio
Audio
Pioneer SE-M390
c1tramon is offline
