Help: change click force on zowie za13 - Overclock.net - An Overclocking Community
post #1 of 10 (permalink) Old 02-23-2018, 11:34 AM - Thread Starter
-IIToRII-'s Avatar
Rep: 0
So the title says it all..
I need help to make the "m1" and "m2" lighter .
love the shape of the mouse, but the click are to stiff.
-IIToRII- is offline
post #2 of 10 (permalink) Old 02-23-2018, 12:22 PM
Leopardi's Avatar
Rep: 21 (Unique: 21)
za12 is lighter, if you can take the bigger shape
Leopardi is offline
post #3 of 10 (permalink) Old 02-23-2018, 01:19 PM
plyr's Avatar
Rep: 7 (Unique: 7)
There are some screws inside that you can remove and make the buttons loose a bit.
plyr is offline
post #4 of 10 (permalink) Old 02-23-2018, 03:01 PM
sirneb's Avatar
Rep: 3 (Unique: 3)
I know not everyone have the skill to do this but changing to the japanese omron switches really does make a huge difference. For some mice, loosening or tightening screws might make a difference.
sirneb is offline
post #5 of 10 (permalink) Old 02-23-2018, 04:10 PM
AloneInTheDuck's Avatar
Rep: 12 (Unique: 10)
Open the switch (you can make it with a needle, don't lose parts), gently push this plate so that it bends. Do this until the click becomes light enough
AloneInTheDuck is offline
post #6 of 10 (permalink) Old 02-25-2018, 01:43 AM
Leopardi's Avatar
Wonder what screws?
Leopardi is offline
post #7 of 10 (permalink) Old 02-25-2018, 02:44 AM
Mouse Junkie
vanir1337's Avatar
Rep: 39 (Unique: 35)
Sand down the shell in the inside a little bit, and/or solder in D2F-01F's. My ZA12 is modified this way and the clicks are way better than on a stock one.
Logitech G PRO Wireless | Custom Huado Mousepad | Sharkoon PureWriter TKL Blue | HyperX Cloud
vanir1337 is offline
post #8 of 10 (permalink) Old 02-25-2018, 01:43 PM
plyr's Avatar
Rep: 7 (Unique: 7)
Quote: Originally Posted by Leopardi View Post
Wonder what screws?
The top buttons of the mouse are attached to the shell with plastic and 3 screws, If you remove the screws its only plastic, and its enough no keep things in place, but the buttons will loose a bit of pressure.
This picture is not mine, some zowie mice dont even have the screws, but when I opened my ZA13 there was 3, on these red circles you see on the picture.
plyr is offline
post #9 of 10 (permalink) Old 02-27-2018, 05:38 AM - Thread Starter
-IIToRII-'s Avatar
Rep: 0
Thanks, i will try this I should bend it downwards, right?
post #10 of 10 (permalink) Old 02-28-2018, 01:51 PM
Yep, bend down. Be careful, that easily to break
