FKMINI2 Review by MattKelly - Page 3 - Overclock.net - An Overclocking Community
post #21 of 33 (permalink) Old 05-11-2018, 09:50 PM
Shwiqo6434's Avatar
Shwiqo6434 is offline
post #22 of 33 (permalink) Old 05-23-2018, 05:50 AM
Linux Lobbyist
Rep: 0
Wait, there's two switches for changing dpi right? but can you change polling rate? If not what's the default polling rate?
ILIKEPIPPELI is offline
post #23 of 33 (permalink) Old 05-26-2018, 02:15 PM
Linux Lobbyist
3Shells's Avatar
Rep: 4 (Unique: 3)
Do not buy this mouse, mine came in today and its defective - horrible skipping and angle-snapping.
3Shells is offline
post #24 of 33 (permalink) Old 05-26-2018, 03:04 PM
Mouse Junkie
vanir1337's Avatar
Rep: 36 (Unique: 33)
"Mine is broken so all other copies have to be broken too?"
Logitech G PRO Wireless | Custom Huado Mousepad | Sharkoon PureWriter TKL Blue | HyperX Cloud
vanir1337 is offline
post #25 of 33 (permalink) Old 05-26-2018, 03:38 PM
Ex-resident Kinzu shill
Alya's Avatar
Rep: 62 (Unique: 39)
My FKMini2 also has terrible skipping issues, but the angle snapping is actually marketed by them.
"Push your mouse to the limited with Overdrive. Legendary shape enhanced with premium martials."
Alya is offline
post #26 of 33 (permalink) Old 05-26-2018, 08:28 PM
Linux Lobbyist
3Shells's Avatar
Rep: 4 (Unique: 3)
I've been able to fix the skipping issue by disassembling the mouse and ensuring that the screws on the PCB are screwed in as tightly as possible. Now that I am actually able to use the mouse, I was able to conclude that its too small for my 7 inch hands. Also Alya I can agree with you on there being too much pre-travel on the right-mouse button, definitely an annoyance.
Edit: Still skipping, albeit to a much lesser degree.
3Shells is offline
post #27 of 33 (permalink) Old 05-27-2018, 07:04 AM
Aliandro1d's Avatar
Rep: 5 (Unique: 4)
ye it was skipping because they didn't change the shell thickness from the 3090 most likely(along with it no being screwed tight) which has a higher LOD so there was no tolerance for the 3325 LOD, you could always sand the bottom and add thinner mouse feet, though as far as i know the m1 feet are pretty thin (.6??mm) and they're really good imo, i have 2 sets of 40 commatech m1 spare feet which i put on all my mice so i can access the screw holes and the glide is better than most other brands
Aliandro1d is offline
post #28 of 33 (permalink) Old 05-27-2018, 10:47 AM
Linux Lobbyist
Rep: 0
Soo this mouse has angle snapping and even the OP didn't mention it ... Well it can't be that bad, right?
I'm going to get me hands on the FKMINI 2 in a few days, we'll see if it will also have skipping..
post #29 of 33 (permalink) Old 06-24-2018, 09:44 PM
dahomosapien's Avatar
Rep: 0
Can the angle snapping be turned off in any way?
dahomosapien is offline
post #30 of 33 (permalink) Old 06-25-2018, 01:13 PM
Linux Lobbyist
Rep: 0
I guess not without software (which the fkmini2 doesn't have), its just something that is built in. I wouldn't recommend this mouse unless you really like the design. Youre better off getting something else
