Is there a larger ambi mouse other than the fk1+ on the market? - Overclock.net - An Overclocking Community
post #1 of 39 (permalink) Old 04-12-2018, 07:17 AM - Thread Starter
Rhys7's Avatar
Rep: 0
I dont think there is, just wondered if you guys knew of anything i could try? left handed so stuck with ambi mice...
fk1+ not wide enough, too flat, bottom of the mouse doesnt fill my hand enough to use wrist arm movement correctly...
hands are about 21.5 x 11...
cheers..
even if its some cheap knock off, i just want to feel a larger shell thats comfortable..
Rhys7 is offline
post #2 of 39 (permalink) Old 04-12-2018, 08:03 AM
Mouse addict
cdcd's Avatar
Rep: 30 (Unique: 22)
Finalmouse Ultralight Pro
Mice currently owned: Logitech G402/G403/G303/G Pro, Zowie FK1/EC2-A/EC2-B/ZA12, Razer Deathadder 2013/Basilisk, Cooler Master Mastermouse S/MM530/MM520, Roccat Kone Pure Owl-Eye, Dream Machines DM1 Pro S/FPS/DM3 mini, EVGA Torq X3/X5, Ninox Venator, HP Omen 600, Thermaltake Ventus X RGB Optical/Ventus R, Microsoft WMO, Steelseries Rival 310, Nixeus Revel, Ozone Neon M50
Looking to buy and try: Ninox Astrum
cdcd is offline
post #3 of 39 (permalink) Old 04-12-2018, 08:05 AM
gipetto's Avatar
Rep: 9 (Unique: 7)
have you tried an io1.1? I'M 21.5 x 10 and I find it's all i want to use of late.
gipetto is offline
post #4 of 39 (permalink) Old 04-12-2018, 08:18 AM - Thread Starter
Rhys7's Avatar
Rep: 0
its much more narrow at the bottom had it and sent it back...just like the g900 too narrow at the bottom
Have you actually tried an FK1+? it looks very similar in terms of dimensions to the io1.1...where can i buy one? its worth a try..
Rhys7 is offline
post #5 of 39 (permalink) Old 04-12-2018, 08:32 AM - Thread Starter
Rhys7's Avatar
Rep: 0
looking on ebay now which version should i be buying? the io1.1 original ? is there differences?
Rhys7 is offline
post #6 of 39 (permalink) Old 04-12-2018, 09:30 AM
Aliandro1d's Avatar
Rep: 5 (Unique: 4)
G900 is the largest ambidextrous that I know off, but the this thread just seems stupid. In no way is the lack of palm touching the mouse hindering your movement or not allowing "correct" wrist movements. My palm doesn't touch my mouse at all and I'm the god damn best 360 no scoper on these forums.
Aliandro1d is offline
post #7 of 39 (permalink) Old 04-12-2018, 10:15 AM
gipetto's Avatar
Rep: 9 (Unique: 7)
sadly i have not tried the fk1, the only zowie i ever tried was a ec2 evo, which, like the g203 I found much too small to be usable. afaik there's only two shell versions of the io1.1, the iomini and the standard microsoft size. you should buy the io1.1 from aliexpress as the chinese fixed a shell fault that caused double tap. I think this would do.
https://www.aliexpress.com/item/Whol...810478053.html
gipetto is offline
post #8 of 39 (permalink) Old 04-12-2018, 12:55 PM - Thread Starter
Rhys7's Avatar
Rep: 0
a thin 11cm wide hand...do you have one? i dont think you do, probz average hands, if your hands ever grow then try g900 then we can talk...its too narrow i have to squeeze my hand just to have good proper contact with that mouse...its like a stress position and is no good for aiming...and if the bottom of your hand is not comfortable on the mouse how you going to move the mouse? it isnt possible without error, fingers forcing at tight grip...you end up forcing every movement from fingers which is tiring
in fact the g900 isnt big at all IMO anyone thats ever used that mouse and been any good with it has tiny hands
Rhys7 is offline
post #9 of 39 (permalink) Old 04-12-2018, 01:01 PM - Thread Starter
Rhys7's Avatar
Rep: 0
I already ordered from ebay its the io1.1a its the same shell as yours? i kinda just want to see how the shell fits thats all
Rhys7 is offline
post #10 of 39 (permalink) Old 04-12-2018, 01:25 PM
Avalar's Avatar
Rep: 37 (Unique: 27)
The Sensei 310 is really wide iirc. Wider than all of my other mice.
Ryzen 1600
ASRock AB350
Asus Strix GTX 1070
G-Skill 2x8GB 3200MHz
Samsung 850 EVO 1TB
EVGA 500BQ
Cryorig H7
Rosewill Viper Z
Operating System
Windows 10 Pro
Acer GN246HL
Keyboard
Corsair K65
Mouse
Too many
Mousepad
Too many
Audio
SHP9500
Avalar is offline
