Logitech G FK / Logitech G Pro Wireless Mouse - Page 246 - Overclock.net - An Overclocking Community
post #2451 of 2556 (permalink) Old 05-10-2019, 11:45 AM
Blomkungen's Avatar
Rep: 0
No offense but you should either post in the G pro wired thread or open a new one.
Blomkungen is offline
post #2452 of 2556 (permalink) Old 05-10-2019, 02:09 PM
deepor's Avatar
Rep: 483 (Unique: 328)
Quote: Originally Posted by ithehappy View Post
Tell me something, when I reboot my system my the mouse's LED profiles reset and goes to default. Even after logging into windows my set LED profile never loads, until I open LGS manually and hit on the Lighting Settings option within the software! The moment I click on it my set LED config gets loaded on the mouse. This was not the case with G HUB. I quite well remember that it stored my preferred settings on the mouse itself and after a reboot even though the mouse LED would reset momentarily but within a few seconds it would load my settings. Never had to open the G HUB software post a reboot, so I suppose it stored the settings on the mouse itself as opposed to what LGS is doing? it's a bit confusing.
In LGS, there is check box to choose between saving the profile on the mouse or just in the software. Click on the first icon at the bottom of the window that looks like a house to get to the screen with that check box.
deepor is offline
post #2453 of 2556 (permalink) Old 05-10-2019, 05:09 PM
SmashTV's Avatar
Rep: 58 (Unique: 45)
Can anyone measure how far the sensor is from the top and bottom ends of the shell?
MX518 Legendary
Nixeus Revel
Logitech G603 (91g)
Allsop Raindrop XL
Razer Goliathus Speed
SmashTV is offline
post #2454 of 2556 (permalink) Old 05-10-2019, 06:18 PM
Mouse Maniac
mjc12's Avatar
Rep: 0
Just got an RMA replacement mouse from Logitech, batch number 1831 -> 1916. Sent in the RMA request for rubbing buttons, did not expect how much of a difference the coating would be though. Never really had a problem with the mouse slipping before, but now it feels as grippy as good Zowie matte coating. Buttons are also better but I expected that. Scroll wheel is less notchy too, rolls smoother and easier.
8770k @ 5 GHz | EVGA GTX 1070 SC | Windows 10 Pro
Mice: Logitech G Pro Wireless | Logitech G403 Wireless | Logitech G Pro | Logitech G203 | Zowie EC1-A | Zowie EC1-B | Zowie ZA11 | Zowie FK1+ | Zowie FK1 | Finalmouse Ultralight Sunset
Mousepads: Artisan FX Hyate Otsu Soft XL | Artisan FX Zero XSoft XL | Artisan Hyate Otsu XSoft L | Steelseries QCK Heavy | Zowie GSR Black | HyperX Fury S Speed | HyperX Fury S Pro
mjc12 is offline
post #2455 of 2556 (permalink) Old 05-11-2019, 08:48 AM
ithehappy's Avatar
Rep: 3 (Unique: 2)
Kindly redirect me to that topic. I have no interest in stealing a topic.
Mine was set at this by default-
Bur funnily enough, if I toggle it to the other option, Automatic Game Detection mode, which supposedly stores the profiles on my computer, there is no problem after a reboot, LoL. Somehow the on-board memory mode is unable to save the profiles to the mouse or load it automatically post a reboot or something?
ithehappy is offline
post #2456 of 2556 (permalink) Old 05-12-2019, 09:17 AM
Blomkungen's Avatar
Rep: 0
post #2457 of 2556 (permalink) Old 05-12-2019, 10:49 AM
ithehappy's Avatar
Rep: 3 (Unique: 2)
ithehappy
Yes, thanks, that second link redirects to G Pro thread, though that's the 3366 version of it, but it will work.
Good bye.
post #2458 of 2556 (permalink) Old 05-13-2019, 07:41 AM
DyndaS's Avatar
Rep: 3 (Unique: 3)
So... the gap between buttons is bigger now?
Im having 1846, and I have noticed this issue. Maybe not a big deal when i use it, but i can force it do do it if i want to.
Did they changed the coating or something?
btw.
Are yours main buttons rattle when you shake the mouse up/down ?
DyndaS is offline
post #2459 of 2556 (permalink) Old 05-16-2019, 08:51 AM
DyndaS's Avatar
Rep: 3 (Unique: 3)
I have noticed some issue with the scroll switch in the G Pro Wireless and G305. It desactivate before you release it if you just use less pressure. Sometimes you can do even double click with it. I coudn't force my Roccat Kone Pure to do this even if I wanted to.
When I press hard its ok but when i put less pressure it desactivate even if it is not relased. The position of it is still full presst.
2-3 times in last week I even closed more then 1 cart at once because of double click.
Could you test your mouse?
There is some software I was using: https://www.passmark.com/products/keytest.htm
DyndaS is offline
post #2460 of 2556 (permalink) Old 05-16-2019, 04:33 PM
Mouse Junkie
vanir1337's Avatar
Rep: 39 (Unique: 35)
Quote: Originally Posted by DyndaS View Post
I have noticed some issue with the scroll switch in the G Pro Wireless and G305. It desactivate before you release it if you just use less pressure. Sometimes you can do even double click with it. I could force my Roccat Kone Pure to do this even if I wanted to.
https://www.youtube.com/watch?v=KfpF...ature=youtu.be
Mine did the same, I've replaced the switch and it's good ever since. Definitely the switch's fault.
Logitech G PRO Wireless | Custom Huado Mousepad | Sharkoon PureWriter TKL Blue | HyperX Cloud
vanir1337 is offline
