Hero sensor surface tuning? - Overclock.net - An Overclocking Community
post #1 of 9 (permalink) Old 10-04-2018, 02:50 AM - Thread Starter
Brumor's Avatar
Rep: 0
Do mice with the Hero sensor have a surface tuning option on the Logitech software?
Brumor is offline
post #2 of 9 (permalink) Old 10-04-2018, 02:52 AM
numberfive's Avatar
Rep: 21 (Unique: 11)
Either I don't see it, or I don't have it for GPW in Ghub
numberfive is offline
post #3 of 9 (permalink) Old 10-04-2018, 02:54 AM - Thread Starter
Brumor's Avatar
Rep: 0
Ok, thanks!
Brumor is offline
post #4 of 9 (permalink) Old 10-04-2018, 02:55 AM
e4stw00t's Avatar
Rep: 13 (Unique: 13)
Hero sensor mice (at least currently) don't support surface tuning, so you didn't overlook anything in the software.
e4stw00t is offline
post #5 of 9 (permalink) Old 10-04-2018, 07:41 AM
Mouse reviewer
Ino.'s Avatar
Rep: 405 (Unique: 238)
Hero has "automatic surface tuning" apparently, forgot where I saw that, but it was stated somewhere by a rep.
Ino. is offline
post #6 of 9 (permalink) Old 10-04-2018, 08:47 AM
boogdud's Avatar
Rep: 20 (Unique: 20)
I'm guessing by automatic, they just mean, you can't change it. It isn't an option on any of my hero equipped mice.
Pretty big oversight/limitation with the hero sensor imo. I don't want to go back to the days of having to use the tape fix when a vendor decides that 4mm liftoff is 'fine' again.
boogdud is offline
post #7 of 9 (permalink) Old 10-04-2018, 11:54 PM
Mouse reviewer
Ino.'s Avatar
Automatic means that the sensor automatically does surface tuning to optimize LOD and whatever else they do, high LOD is a technical flaw so it's not in the interest of any manufacturer.
Ino. is offline
post #8 of 9 (permalink) Old 10-05-2018, 02:12 AM
trism's Avatar
Rep: 29 (Unique: 17)
HERO definately does not have a high LoD, at least on the surfaces I've tested it on. LoD isn't something that only has the higher limit. 1.2 mm should be fine for everyone and you can adjust to it no matter which direction you go as long as it stays in between some values. I would personally have a bit higher LoD in Logitech's 3366.
trism is offline
post #9 of 9 (permalink) Old 10-11-2019, 06:04 PM
Rep: 0
Surface Turning FOUND!
I found the Surface Tuning in G hub!
1. Go to "G Hub Settings"
2. it's in the "My Gear" Tab in Settings.
3. Click on your mouse icon.
4. Select a name for your mouse pad.
5. Start moving the mouse to calibrate it to the surface.
6. Complete.
Jackhammer2332 is offline
