Tutorial: G305 button cell battery (weight reduction to 69g) - Page 2 - Overclock.net - An Overclocking Community
post #11 of 17 (permalink) Old 05-28-2019, 07:54 PM
dahomosapien's Avatar
Rep: 0
Quote: Originally Posted by Gilles3000 View Post
I'd would be a significant mod, yes. and honestly I have no idea whether it would work with G Powerplay.
But getting it to work in a specific "parking" spot on the mouse mat would be relatively easy.
You'd need a:
Lithium battery:
https://www.aliexpress.com/item/33018052683.html
Charging module:
https://www.aliexpress.com/item/32835132061.html
Charging coil for the mouse:
https://www.aliexpress.com/item/32852366953.html
buck converter(to lower the voltage to 1.5v for the mouse):
https://www.aliexpress.com/item/32725312642.html
Finally any mousemat of your choice with qi wireless charging build in.
Thanks so much. What I was really asking is - is it possible to replace the G305 battery with a capacitor and rely on a charging mat? Or it's not a simple process?
dahomosapien is offline
post #12 of 17 (permalink) Old 05-29-2019, 02:52 AM
Meep
Gilles3000's Avatar
Rep: 313 (Unique: 227)
Seems like the powerplay mat works at a different frequency than qi coils. So it won't work with those. So you either need to rip the receiver out of an actual an actual powerplay mouse or make your own, which would be anything but simple.
There's a large passive wireless power surface made by power republic meant for small LED's t, that should work with just about any decent coil. But from what I've seen they're not cheap nor do I have a clue where to even buy them. You're probably better off just buying an actual powerplay mouse at that point.
Gilles3000 is offline
post #13 of 17 (permalink) Old 06-10-2019, 09:13 AM - Thread Starter
Rep: 8 (Unique: 8)
@Gilles3000 I started 3D printing shells for the G305 and that would be sick to charge the battery like that. Do you think I could go even further and give power to the mouse by induction to completely get rid of a battery?
p1r4nh4 is offline
post #14 of 17 (permalink) Old 06-19-2019, 10:58 PM
Rep: 0
Yeah man - this is the ultimate question. If it's possible without an overly difficult level of effort, then I'll be onto that straight away.
post #15 of 17 (permalink) Old 06-19-2019, 11:46 PM
Meep
Gilles3000's Avatar
Full pad induction would require at least a capacitor. And a matched induction pad and receiver.
There is some induction stuff for led's (both off the shelf and diy) that could work, but I'm not sure how well it would scale to the size of a decent mousepad.
The diy stuff seems cheap enough to give a shot, but the big off the shelf induction surfaces all seem quite expensive.
post #16 of 17 (permalink) Old 06-20-2019, 12:09 AM
Overclocker
JackCY's Avatar
Rep: 345 (Unique: 244)
i would love to do this, but I have no idea how. Are you able to refer me to a link? Would it damage the mouse, considering that the G305 does not have POWERPLAY?
Really excited to hear your response. Thank you
You can convert phones to wireless charging, it's all the same thing, wireless charging is nothing more than 2 coils transferring electricity wirelessly. Considering bottom of most mice is plastic you don't have to cut the bottom either unlike metal phones that need to have the place/part under coil swapped to plastic. There are endless small batteries on hobby sites such as hobbyking.
I see others linked some similar chargers to what I saw. But in a larger more standalone package.
You don't need a 24/7 charging, you can do a parking spot under your mat for the night, etc. What to keep in mind is how the charging will affect rest of the device.
If you can charge on whole pad and enough while in use, then yes you could potentially only use a large capacitor but then batteries aren't that much heavier either and often smaller at higher capacity. Capacitors are good for high currents. Batteries for low currents and storage, which is what you need.
JackCY is offline
post #17 of 17 (permalink) Old 07-18-2019, 08:30 AM
Rep: 0
Which battery holder should i buy for this? any cr2032 holder can work with it? I cannot find holder for lr44 in my town.
Can you suggest me any of these?
https://www.birikimpilleri.net/pil-g...pil-yuvasi?p=2
obican is offline
