is there any benefit to running a dpi closer to your monitor resolution? - Overclock.net - An Overclocking Community
post #1 of 30 (permalink) Old 04-03-2019, 09:17 PM - Thread Starter
alexander1986's Avatar
Rep: 0
I know a lot of people play with 400-800 dpi for example on 1920x1080 resolution, I play with 800 dpi aswell,
Just wondering if there is any technical reason that a dpi closer to your monitor resolution would be better? because I've read that somewhere but might be false
like for example 1600 dpi or 2000 dpi when playing on 1920x1080, or just stay on lower dpi as long as it feels good?
thanks
alexander1986 is offline
post #2 of 30 (permalink) Old 04-03-2019, 09:29 PM
Grasp of the intangible
RyzenShine's Avatar
Location: 4 walls and some trees. There are rumors of wifi though
Rep: 0
I usually run 2000 to 2500 because I am accustomed to small hand movements of the mouse to cover much ground. I don't have a huge computer space, so over the years I got VERY acquainted with using wrist movements instead of whole hand movements. But that is personal. I also game in multiple resolutions (both 1080 or 1440 at up to 144hz)... It is an adjustment at times, but usually within an hour or two I can acclimate.
RyzenShine is offline
post #3 of 30 (permalink) Old 04-03-2019, 09:32 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 960 (Unique: 592)
Just use what feels best, you don't need to match anything.
600 DPI master race
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 16GB
Mushkin Pilot NVMe 1TB
Samsung 860 Evo 1TB
Sandisk Ultra II 480GB SSD
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU
Dell E2311H
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Audio
SMSL SA50 + FiiO E10K
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
Audio
Monoprice Modern Retro
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Rii RKM709 Wireless
Mouse
Logitech M510
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is offline
post #4 of 30 (permalink) Old 04-03-2019, 10:56 PM
TranquilTempest's Avatar
Rep: 77 (Unique: 62)
Not unless you only have one inch of play in moving your mouse around on the table, or have some RSI issues that make you not want to move the mouse very far.
TranquilTempest is offline
post #5 of 30 (permalink) Old 04-04-2019, 12:34 AM
white owl's Avatar
Rep: 135 (Unique: 102)
There might be some technical reason that one DPI is "better" than another but I usually just set speed to 6 in Windows, disable the precision thing then set a few different numbers to the DPC switch and move the mouse around till I find a zone that's comfortable. Then I reset the numbers assigned to the switch to be closer together so I can find the one I like best or change in game if I feel like, all your game sensitivity settings should revolve around your DPI.
Quote: Originally Posted by SpeedyVT
If you're not doing extreme things to parts for the sake of extreme things regardless of the part you're not a real overclocker.
Quote: Originally Posted by doyll View Post
The key is generally not which brands are good but which specific products are. Motherboards and GPUs are perfect examples of companies having everything from golden to garbage function/quality.
Hot n Bothered
(12 items)
4790k 4.7Ghz
Asus Sabertooth Z97 MkII 2
EVGA GTX 1080 SC
16gb G.Skill Sniper 2400Mhz
2x Kingston v300 120gb RAID 0
WD Blue
Seasonic 620w M12 II EVO
Cooler Master 212 Evo
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
I have pretty lights.
white owl is offline
post #6 of 30 (permalink) Old 04-04-2019, 03:35 AM
numberfive's Avatar
Rep: 3 (Unique: 3)
there is no technical reason to match dpi with monitor resolution
numberfive is offline
post #7 of 30 (permalink) Old 04-04-2019, 04:37 AM
Not a Linux Lobbyist
the1freeMan's Avatar
Rep: 38 (Unique: 30)
No.
Plus 2d plane (osu, rts) vs 3d view matrix (fps, tps) is totally different.
Higher resolutions will want more cpi on 2d because 1 count = 1 pixel with accel and interpolation off.
3d view matrix is unrelated from resolution.
So for both no, screen's horizontal resolution is not to target even for 2d. Might work for you.
For me, 1200cpi on 1920*1080 feels the best in 2d and 800 for 3d (no difference between 800*600 or 4k, if this surprises you, this guy managed to have the patience to explain it thoroughly once and for all: https://www.reddit.com/r/Competitive...elieve_in_the/)
"a bad joint can't be that bad right?" -q
the1freeMan is offline
post #8 of 30 (permalink) Old 04-04-2019, 06:39 AM
mfw
ToTheSun!'s Avatar
Rep: 362 (Unique: 191)
Quote: Originally Posted by the1freeMan View Post
No.
This. Modern 3D engines use angular movement.
Just use whatever feels comfortable in Windows at 6/11 (only because some in-game menus don't use raw input).
I like 2000 DPI at 1440p.
Intel 6700K
Asus Z170i
MSI 2080 Sea Hawk X
G.skill Trident Z 3200CL14 8+8
Samsung 850 EVO 1TB
Crucial M4 256GB
Corsair SF600
Noctua NH C14S
Fractal Design Core 500
Operating System
ViewSonic XG2703-GS
Keyboard
Ducky One 2 Mini
Mouse
Corepadded Logitech G703
Mousepad
Asus Scabbard
Audio
Fiio E17K v1.0 + Beyerdynamic DT 1990 PRO (B pads)
ToTheSun! is offline
post #9 of 30 (permalink) Old 04-04-2019, 07:21 AM
pininfarina575's Avatar
Rep: 0
I do 2000~2400dpi - for me, it's more precise and accurate to control the mouse with my fingers and my wrist rather than leaving it up to my forearm(?) movement to cover many inches of actual mouse movement. but again, that's just what I found to be my preference and what I'm used to...
Sometimes let's say I'm using a 8x scope in a game, then this may be a bit too sensitive - but some mice have a button you can press-hold to lower sensitivity during the button hold... or you can change sensitivity for scope use in some games.
Main Gaming PC
(8 items)
Wife's Gaming PC
(7 items)
Racing Sim
(8 items)
Intel Core i9 9900k 5.0Ghz 1.290v AVX Offset 0
Gigabyte Z390 Aorus Master
EVGA GeForce RTX 2080 Ti FTW3 Ultra
Corsair Vegeance RGB Pro 16GB (2x8) 3466Mhz
Samsung 970 Pro 512GB + Samsung 860 Evo 1TB
EVGA SuperNOVA G3 850W
Corsair H150i Pro
Fractal Design Define R6
Intel Core i5 9600k
Gigabyte Z390 Aorus Pro
Gigabyte GeForce RTX 2080 Gaming OC
Corsair Vegeance LPX 3000Mhz 16GB (2x8GB)
Samsung 860 Evo 500GB + Western Digital Blue 1TB 7200rpm HDD
SeaSonic 750W
Corsair H100i Pro
Intel Core i7 4770k
AsRock Z87 Fatal1ty Killer
Sapphire Radeon RX580 Nitro+ 8GB
G. Skill Ares 1600Mhz 16GB (2x8GB)
Samsung 840 Pro 256GB + Western Digital Blue 1TB 7200RPM
SeaSonic G-Series 650W
Cooler Master ML240L
Fractal Design Define R4
pininfarina575 is offline
post #10 of 30 (permalink) Old 04-04-2019, 07:23 AM
Missing the Old days
Cerberus's Avatar
Rep: 247 (Unique: 214)
Max on mouse, stock ingame (g602)
a full 720 rotation is like 4 inches
No arm movement, only wrist.
"But I, being poor, have only my dreams. I have spread my dreams beneath your feet. Tread softly because you tread on my dreams."
Folding Rack
(10 items)
Work Folder
(7 items)
AMD r7 2700x
ASUS ROG Crosshair VI Hero
Nvidia Titan X Pascal
Zotac GTX 980 AMP!
PNY Anarchy-X 2x8GB 3200Mhz
256GB Plextor M8Pe m.2
Corsair RM750X
big metal box
Operating System
Microsoft Windows 10 x64
DELL S2716DG
Keyboard
Logitech G910
Mouse
Logitech G602
Mouse
Steelseries Mat
Audio
Logitech G602
Other
steam controller
AMD r7 1700x
MSI X470 Gaming Plus
GIGABYTE GTX 1080
GIGABYTE GTX 1080
Geil EVO 1x4GB DDR4
Toshiba 3TB
Silverstone ST-1000PT
4U Rosewill
Operating System
Ubuntu 18.04LTS
Headless
AMD FX8350
BIOStar TA970
AMD FURY X
Zotac GTX 960
Gskill 2x8GB DDR3
Western Digital Blue 2TB
Corsair 650w
Cerberus is offline
