Progress on a fully custom mouse. - Page 14 - Overclock.net - An Overclocking Community
post #131 of 146 (permalink) Old 08-05-2019, 02:35 PM
gipetto's Avatar
Rep: 12 (Unique: 9)
I recieved a slotted optical switch pcb a few days ago and tried it out today. while the pcb itself works perfectly without light interference due to the lm393 onboard, it doesn't work as well as i had hoped as a rotary encoder. there are back scrolls as many as 1 in 10 and it is very hard to align correctly. I think the backscrolling may be due to rotational bounce in the wheel. no pics because my phone doesn't work properly.
I do recommend those pcbs though, very easy to work with, and possibly a good reference circuit for a quadrature design.
edit: fixed the bugs in the code, wheel works perfectly now. one bug was caused by changing a pinmode from input to output, the delay caused the issue, the other was caused by inverting the logic level of the hardware debouncing. It actually caused an unstable condition which I didn't think was possible but made sense upon thinking about it.
gipetto is offline
post #132 of 146 (permalink) Old 08-18-2019, 10:25 AM
Rep: 6 (Unique: 5)
i wonder if we could make a pcb that could fit any shell to make your own mouse like we do our own keyboards. and obviously the pcb will need hotswap switches.
https://cdn.discordapp.com/attachmen.../universal.png
tailslol is offline
post #133 of 146 (permalink) Old 08-18-2019, 11:03 AM - Thread Starter
TranquilTempest's Avatar
Rep: 79 (Unique: 64)
Well, making a custom mouse PCB is a whole lot cheaper than a custom keyboard PCB. Though you can get away without it using off the shelf sensor module and a teensy or arduino micro. Though I think it's just easier to make a custom PCB so you get everything where you want it. sensor, mounting holes, switch locations, encoder, etc. While microswitches technically have mounting holes, I don't think it's easier to use those than a PCB.
TranquilTempest is offline
post #134 of 146 (permalink) Old 08-18-2019, 01:53 PM
gipetto's Avatar
Rep: 12 (Unique: 9)
Switch sockets come with a weight penalty and are quite deep also, which would likely necessitate drilling a hole in the base for each socket so that the pcb isn't risen up and bottoming out the switches.
While it would be possible to make a custom pcb which integrates the mcu and sensor, there are already similar offerings on the market, for instance the deathadder 3.5g and logitech g403 wired pcb. I've also seen a two part mod with a steelseries rival pcb.
I don't think there would be any weight advantage between a teensy+ sensor board vs an integrated board so there's really no advantage to this for a one-off unless you want the better build quality. It could be cheaper if you can solder smt and have the programmers.
gipetto is offline
post #135 of 146 (permalink) Old 09-23-2019, 11:52 AM
gipetto's Avatar
Rep: 12 (Unique: 9)
I redid my pcb to add support for the ergo intellimouse1.3 shape and isp headers. I removed the reset button due to space constraints from the screw hole. it is accessible from the isp headers. I was strongly considering using jlcpcb's assembly service but they were missing the 1.9v regulator, and I already have enough money spent. Still waiting for my tech to finish soldering.
https://github.com/itsnoteasy/misc/t...mouse8onethree
gipetto is offline
post #136 of 146 (permalink) Old 10-12-2019, 05:52 PM - Thread Starter
Thought I should leave this here, really helpful for understanding the USB stuff: https://www.beyondlogic.org/usbnutshell/usb1.shtml
One thing I originally missed was the 10uf maximum and 1uf minimum capacitance across the 5v input. The maximum inrush current limitation is understandable, but I didn't realize there was a minimum as well, used for device detection. I had 10uf there because I was already using that for the sensor(MCU datasheet recommends 4.7), but there's a tolerance on that cap, and there's more capacitance on the other side of the voltage regulators, I'm not sure how long those take to charge.
I'm sure this won't matter in normal usage, but it probably would have if I ever tried to get it compliance tested. I think I'll add say 10 ohms in series. it will make it easy to measure current usage, and take the edge off the inrush. Any voltage drop across it would have been lost in the LDO regulators anyway.
post #137 of 146 (permalink) Old 10-13-2019, 10:26 PM - Thread Starter
On storing sensitivity presets and other settings in the onboard flash:
The flash memory on my MCU comes in 512 byte pages. You can write one byte at a time, but you can only change 1s into 0s with that operation. To change 0s into 1s you have to erase the whole page. I think this means if I write 0b00000001 to an address, and later write 0b00000010, the value stored will be 0b00000011. If it works like that, I might use the first ~8 bytes of the page as an index, write one bit in the index every time I update a preset, to show which address contains the most recent value. Then I only need to erase after I've filled the whole page, cutting the program erase cycles down to ~1/63 of what it would be using a static address. If there's an error I'll just revert back to the default array of presets.
Or I could just traverse the page until there aren't any more entries, and use the last one. I only really have to read from it when I first plug in the mouse, so I'll probably end up doing this, I'll just keep the current index and values in RAM.
Chip is specified for 20k p/e cycles minimum, so I shouldn't have any problem with endurance using either of these methods.
post #138 of 146 (permalink) Old 12-01-2019, 10:14 AM
gipetto's Avatar
Rep: 12 (Unique: 9)
I decided to get to grips with jlcpcb's assembly service using this kicad script tutorial: https://dubiouscreations.com/2019/10...sembly-service
to use the service i had to move all components to one side and replace the regulator with an adjustable type, as there was no fixed 1.9v in their parts library. i used a value of 2kohms for r1 and 3.3k ohms for r2. any assembly to be done is through hole only. I haven't ordered yet as an earlier version was to be done this week. this will probably be the last work done on the pcb.
https://github.com/itsnoteasy/misc/t...use8onethreev2
edit, had to change the regulator again because jlcpcb put a 9 euro tooling fee on a 10c texas instrument part, also changed led_p resistors to 39.07 ohms by seriesing 49.9r and 180r
gipetto is offline
post #139 of 146 (permalink) Old 12-31-2019, 12:07 PM
gipetto's Avatar
Rep: 12 (Unique: 9)
I got the assembled pcbs in today and figured now would be a good time to learn how to flash over isp. so, following the qmk instructions I flashed a teensy2.0 clone as an avrisp programmer, then wired it to the pcb and flashed it with an atmel-dfu bootloader. but i don't have an example makefile so unless i go the backwards and slightly illegal way of flashing the halfkay bootloader i'm stuck. can anyone help me out? If not it's ok, the other set of pcbs have the halfkay bootloaders on them.
gipetto is offline
post #140 of 146 (permalink) Old 12-31-2019, 03:36 PM - Thread Starter
Here's an example makefile that uses GCC and AVRDUDE https://gist.github.com/holachek/3304890
But I'm definitely not the person to ask about how to set up a toolchain. Maybe try r/embedded or stackoverflow.
Tags
custom , modding , mouse , pcb , shell
