Overclock WMO Help needed - Overclock.net - An Overclocking Community
post #1 of 11 (permalink) Old 05-01-2019, 02:35 PM - Thread Starter
Brumor's Avatar
Rep: 0
What does one need to do to get the most (performance) out of a WMO?
I just got one and have no idea what I'm doing.
Help appreciated.
Thank you.
Brumor is offline
post #2 of 11 (permalink) Old 05-01-2019, 02:38 PM
OCN is bad civilization
Melan's Avatar
Rep: 112 (Unique: 86)
https://www.overclock.net/forum/375-...g-2000-hz.html
Instructions are straightforward.
You could also try replacing WMOs horrid wire and primary switches but that's if you don't like them. Other than that, overclock to 1khz and enjoy your mouse.
Melan is offline
post #3 of 11 (permalink) Old 05-01-2019, 02:41 PM - Thread Starter
Brumor's Avatar
Rep: 0
Which switches do you recommend?
Brumor is offline
post #4 of 11 (permalink) Old 05-01-2019, 02:45 PM
Mouse Junkie
vanir1337's Avatar
Rep: 39 (Unique: 35)
D2F-01F strictly.
Logitech G PRO Wireless | Custom Huado Mousepad | Sharkoon PureWriter TKL Blue | HyperX Cloud
vanir1337 is offline
post #5 of 11 (permalink) Old 05-01-2019, 02:48 PM
Melan's Avatar
I'll be installing D2F-F-3-7 on my WMO when I'll find some time for it. Others might recommend something like D2F-01F or whatever.
For cable replacement you might need to install 5 pin JST 2 socket first since the wire is probably soldered in. Then order a paracord or something else. Just make sure the pins are in correct order.
Melan is offline
post #6 of 11 (permalink) Old 05-01-2019, 02:59 PM - Thread Starter
Brumor's Avatar
Rep: 0
I must’ve done something wrong, now none of my mice are working after a reboot. Welp!
Edit: Fixed it, nvm.
Brumor is offline
post #7 of 11 (permalink) Old 05-01-2019, 04:24 PM - Thread Starter
Brumor's Avatar
Rep: 0
It’s not working, I don’t know what I’m doing wrong. I started setup.exe and changed my mouse to 1000Hz. Then went into test mode, plugged my mouse out and replaced hidusbf.sys in the widows drivers folder by the one in the zip (inside the AMD64 folder). Then I plugged my mouse in again and repeated the first step, but I’m still at 125Hz. Help please!
Brumor is offline
post #8 of 11 (permalink) Old 05-02-2019, 03:36 AM - Thread Starter
Brumor's Avatar
Rep: 0
Do I just cut off the third pin from each omron switch to install it? Thank you.
Brumor is offline
post #9 of 11 (permalink) Old 05-02-2019, 11:06 AM - Thread Starter
Brumor's Avatar
Rep: 0
Thank you to everyone who tried to help. I just got it to work!
(This guide helped: https://www.overclock.net/forum/375-...l#post27714496)
Brumor is offline
post #10 of 11 (permalink) Old 05-02-2019, 12:06 PM
Melan's Avatar
Yes. Just make sure you cut off the correct one.
Melan is offline
