CM teases new MasterMouse S with better build quality - Page 3 - Overclock.net - An Overclocking Community
post #21 of 59 (permalink) Old 05-27-2019, 10:25 AM
gourami's Avatar
Rep: 0
i'm actually really hyped for this mouse. better cable, better sensor position, very low weight and a great shape imo. gonna pre order for sure.
Quote: Originally Posted by Zammin View Post
With the MM711, I wonder does that indicate a larger sized shell shell or something?
according to the cm rep on reddit, it's heavier because it has rgb.
gourami is offline
post #22 of 59 (permalink) Old 05-27-2019, 12:27 PM
gunit2004's Avatar
Rep: 7 (Unique: 7)
The Glorious Model O is made in Cooler Master's factory. I wonder if some of the design ideas like the honeycomb PBT shell and paracord cable are being lifted from the Model O and being implemented in this new CM mouse as part of a deal or something. Very interesting, looking forward to hearing more details and getting some pics.
Same shape. + RGB and software implementation according to the rep on Reddit.
gunit2004 is offline
post #23 of 59 (permalink) Old 05-27-2019, 03:43 PM
a_ak57's Avatar
Rep: 60 (Unique: 46)
We now have a picture of what's presumably a prototype. I think it's a bit amusing they actually changed the hexagons to match their logo.
a_ak57
(20 items)
Intel i5 3570K at 4.2 GHz
ASRock P67 Fatal1ty Professional
EVGA GTX 1080 Ti SC Black Edition
2x 4GB Corsair Vengeance DDR3 1600MHz
2x 4GB G. Skill Ripjaws 1600MHz DDR3
Crucial MX500 1TB
Seagate ST3000DM001
Toshiba PH3500U-1I72
Optical Drive
Pioneer Blu-ray Drive BDC-207DBK
Cooler Master V850
Corsair H100i
NZXT H630 (matte black)
Operating System
Windows 10 64-bit
Dell U2713HM
ASUS VG236H
Keyboard
Cooler Master Novatouch
Mouse
Logitech G Pro Wireless
Mousepad
HyperX Fury S Speed Edition Large
Audio
Sennheiser HD800
Audio
Grace Design M9XX
a_ak57 is offline
post #24 of 59 (permalink) Old 05-27-2019, 04:00 PM
gunit2004's Avatar
Rep: 7 (Unique: 7)
Hope to god that is a prototype and not what the final product is.
Considering they said the final product would have a paracord type cable and all that... it doesn't seem to be final.
But I would hope they improve on other things like the mouse wheel, buttons, etc.
That picture there literally looks like they slapped a different shell on a existing Mastermouse S PCB. It literally has the same mouse wheel and everything.
post #25 of 59 (permalink) Old 05-27-2019, 05:03 PM
Crymore13's Avatar
Rep: 2 (Unique: 2)
I miss the Recon...
Crymore13 is offline
post #26 of 59 (permalink) Old 05-27-2019, 07:59 PM
a_ak57's Avatar
Well, CM just posted a bunch of pictures and info on reddit. They also confirmed that the cable in the prototypes is just a regular cable and they'll be using a paracord for the actual release.
https://imgur.com/a/pbWxbmK
Alright let's sort some things out. Curse you Google, you're too good.
MM710
- Shape: Ambidextrous, side buttons on the left, based on MasterMouse S with modifications
- Weight: <52G without cable
- Coating: Matte black with UV coat
- Cable: Paracord is planned
- Sensor: Pixart PMW3389
- Main Buttons: Omron D2F (20 million rating)
- Holes: Lots of them. Cooler Master hexagons
- RGB: Nope
- Price: $49.99
- Date: Expected September
- Availability: This won't be limited production
MM711
Same as above with some differences below:
- Weight: <57G without cable
- Coating: Matte white with UV coat
- RGB: Yep
- Price: $59.99
- Date: Expected October
- Availability: This also won't be limited production
Notes
- The units above are working prototypes. There are still changes we would like to make and we're open to feedback.
- The images you've seen prior to this post are of a non-working prototype without a PCB and other innards.
- We determined that the holes on the main mouse buttons are up a little too far shown here. We will fill those holes in to make it easier to place your fingers there.
- The sensor position is more central compared to the MasterMouse S shown here. On the left is the MasterMouse S, Right is MM710/711
- We will attempt to do a paracord cable. Granted, it won't be true paracord because to sell the mouse, it must still have some shielding to be compliant, but we'll try to make it light and flexible.
- This isn't a one-and-done release. We want people to actually try this mouse.
- No, this won't make you connect with nature.
Also, I hacked a prototype of this mouse together so I have used it and compared it to the numerous mice I (used to) own. However, it was using the CM110 bottom plate and PCB, so exact performance isn't guaranteed (I think it weighed somewhere around 65g). However, feel free to ask questions and leave some suggestions!
a_ak57
(20 items)
Crucial MX500 1TB
Seagate ST3000DM001
Optical Drive
Cooler Master V850
Corsair H100i
Operating System
Windows 10 64-bit
Dell U2713HM
ASUS VG236H
Keyboard
Mouse
Mousepad
Audio
Sennheiser HD800
Audio
Grace Design M9XX
a_ak57 is offline
post #27 of 59 (permalink) Old 05-28-2019, 01:34 AM
dontspamme's Avatar
Rep: 9 (Unique: 8)
I'm gutted they didn't move the sensor more than they did.
Yeah, it is improved... but just barely. ;(
dontspamme is offline
post #28 of 59 (permalink) Old 05-28-2019, 03:24 AM
PedMar's Avatar
Rep: 2 (Unique: 2)
Lmao &#x1f602;
PedMar is offline
post #29 of 59 (permalink) Old 05-28-2019, 04:05 AM
t3ram's Avatar
Rep: 7 (Unique: 7)
Looks promising, if the mouse has great quality I probably change from my g303 to this
t3ram is offline
post #30 of 59 (permalink) Old 05-28-2019, 04:12 AM - Thread Starter
Leopardi's Avatar
Rep: 15 (Unique: 15)
"However, it was using the CM110 bottom plate and PCB"
So the CM110 coming without holes as well? Tbh the holes are just too much. I wouldn't be able to grip on the buttons without touching the holes.
Why not just make the bottom plate holed? 70g is plenty light, I doubt it would be more than that this way.
Leopardi is offline
