Xtrfy Project4 ( Lightweight Ergo ) - Page 5 - Overclock.net - An Overclocking Community
post #41 of 49 (permalink) Old 08-22-2019, 03:22 AM
sandywind's Avatar
Rep: 0
Will the size be closer to EC1 or EC2 or Xtrfy M1? EC2 & Skoll are too small for me.
sandywind is offline
post #42 of 49 (permalink) Old 08-22-2019, 04:45 PM
Staticks's Avatar
Rep: 0
120 mm long, 39 mm tall. So quite similar dimensions to EC2.
You would think that may be too small if you have larger hands, but it really depends on your grip style. The fact that I could get along with the 115 mm Roccat KPM says a lot. For gaming purposes, I would rather a mouse be too small than too big.
Mouse: Cougar Revenger S | Glorious Model O-
Mousepad: Ktrio Lycra Cloth Pad | Cooler Master MP510 Cordura Pad
Staticks is offline
post #43 of 49 (permalink) Old 08-23-2019, 08:30 AM
sandywind's Avatar
Rep: 0
Not for me, 18.5 x 10.5, moreover I have developed an inflammation of the last articulation of my little finger; I suspect that bending it too much to reach the mouse side exerts a torque on it when I lift the mouse; haven't noticed any problems in everyday desktop usage. Ideally I need an ergonomic shaped mouse that is wide enough to allow for a large contact area between its right side and my little finger, so that its gravity force is distributed among all articulations. Some shots (roughly after 6'11") from Badseed Tech's review of the G502 Lightspeed (he also has a 10.5cm hand width) show the quite obvious problem of current "narrow" mice for people with wide hands, talking about it and the GPW. (BTW, the wired Logitech G502 is my main.)
post #44 of 49 (permalink) Old 11-10-2019, 11:38 PM
Zammin's Avatar
Rep: 22 (Unique: 8)
I got my M4 Retro Edition today. I like the mouse shape and the clicks feel very good. My only issue is with the cable, it's very stiff and while it looks like a paracord it's one of the worst paracord-like stock cables I've felt. I'm tempted to do a custom paracord mod, as I do on most of my mice, but the trouble is this mouse has a very specific color theme and I can't find any aftermarket paracord colors that match the beige look of the mouse, however the stock cable matches perfectly.
I haven't opened the mouse up yet but my suspicion is that the stock cable probably has one of those really thick shield wires in it. The stock sleeve is a paracord sleeve but it's really tight around the wires, which is what makes me believe it has a thick shield wire inside. Does anyone know if it's possible to remove the shield wire from the stock cable cleanly? I've never modified a stock cable before, I've only installed new ones. I'm wondering if I should try cutting the sleeve off the USB connector end and snipping the shield wire, then pull it out via the other end (JST connector end).
If anyone has any advice on this kind of mod that would be great!
Primary System Specs: Lian Li PC-O11 DX - ROG Maximus XI Formula - Watercooled Intel 9900k (4.9Ghz) - Watercooled RTX 2080 Ti FE - G.Skill Trident Z RGB 3200Mhz CL16 32GB - Corsair RM1000i PSU - Samsung 970 EVO 2TB NVME SSD
Secondary System Specs: Fractal Design Define S2 - ROG Maximus X Code - Watercooled Intel 8700k (5Ghz) - Watercooled Strix GTX 1080Ti OC - G.Skill Trident Z RGB 3200Mhz CL16 16GB - Seasonic X-1050W PSU - Intel 600P NVME SSD
Zammin is offline
post #45 of 49 (permalink) Old 11-11-2019, 08:08 AM
Capsaicin Addict
James N's Avatar
Rep: 38 (Unique: 26)
When palm gripping it, is the tip of your thumb in line with the sensor or is the sensor more towards the root of your thumb?
James N is offline
post #46 of 49 (permalink) Old 11-11-2019, 05:34 PM
Zammin's Avatar
Rep: 22 (Unique: 8)
My hand is a bit too big to properly palm grip it (19.5x9cm) so I can't really answer that accurately, sorry.
To be honest though I think it will depend on the size of your hand and where you choose to place your thumb more than anything.
Zammin is offline
post #47 of 49 (permalink) Old 11-15-2019, 02:30 AM
Zammin's Avatar
Rep: 22 (Unique: 8)
I haven't gotten around to trying to mod the stock cable yet, but I did cut some lizard skins 0.5mm grips for the M4. If anyone else has the retro version, the "Razor Camo" lizard skins bat grip is a really good color match.
Zammin is offline
post #48 of 49 (permalink) Old 11-15-2019, 01:01 PM
deewe's Avatar
Rep: 4 (Unique: 4)
What mousepad is that?
deewe is offline
post #49 of 49 (permalink) Old 11-15-2019, 06:19 PM
Zammin's Avatar
Rep: 22 (Unique: 8)
It's a custom X-Raypad "Thor" speed pad. I sent them the image and had them print it for me. You can give them any image in the appropriate size and they can make one for you. The pad itself is pretty slick. Has a silky sort of feel to it. It's pretty fast too.
Name:	9004003-thor-custom print.jpg
Zammin is offline
