Model O- - Page 17 - Overclock.net - An Overclocking Community
Model O-
post #161 of 165 (permalink) Old 11-14-2019, 03:33 PM
ATH-YF's Avatar
Rep: 1 (Unique: 1)
2 month update..
Since fingertip grip isn't my thing I had to take the Model O- mod one step further.
I can use arm aiming more steadily with this little back support while still retaining a lot of finger freedom.
Name:	20191114 Glorious O- hump mod.jpg.jpg
ATH-YF is offline
post #162 of 165 (permalink) Old 11-14-2019, 04:04 PM
Gigantoad's Avatar
Rep: 9 (Unique: 8)
Speaking of mods. I felt the clicks were a bit too stiff for me (I like them very light) so I opened it up to see if I could change that. I ripped out the LCD strips while I was at it. Turns out I didn't need to open it for the clicks, you can simply stick something into the gap behind the buttons. That will give them more forward push, increase the default tension so to speak. I used this guitar pick:
https://www.amazon.com/Dunlop-44P-60.../dp/B0002D0CGW
Cut out little pieces and experiment with the position. Buttery smooth clicks. If you wanna just try how it feels, you can also put a finger somewhere around the gap and push gently while clicking with the other hand.
Very happy with the mouse now. Middle click sucks though, but that is usually the case on these mice.
Gigantoad is offline
post #163 of 165 (permalink) Old 11-14-2019, 07:13 PM
Gigantoad's Avatar
Rep: 9 (Unique: 8)
Oh and of course that also eliminates some of the sideway play of the buttons, although I can't say it bothered me to begin with.
post #164 of 165 (permalink) Old 11-20-2019, 12:48 AM
Zammin's Avatar
Rep: 22 (Unique: 8)
Has anyone in here gotten to try the new ascended cord? If so, how does it compare to a custom paracord? Is it pretty close like the G-Wolves cable? Or is it only a small improvement over the original ascended cord?
Primary System Specs: Lian Li PC-O11 DX - ROG Maximus XI Formula - Watercooled Intel 9900k (4.9Ghz) - Watercooled RTX 2080 Ti FE - G.Skill Trident Z RGB 3200Mhz CL16 32GB - Corsair RM1000i PSU - Samsung 970 EVO 2TB NVME SSD
Secondary System Specs: Fractal Design Define S2 - ROG Maximus X Code - Watercooled Intel 8700k (5Ghz) - Watercooled Strix GTX 1080Ti OC - G.Skill Trident Z RGB 3200Mhz CL16 16GB - Seasonic X-1050W PSU - Intel 600P NVME SSD
Zammin is offline
post #165 of 165 (permalink) Old 11-20-2019, 02:54 AM
e4stw00t's Avatar
Rep: 13 (Unique: 13)
Here's a solid comparison: https://www.reddit.com/r/MouseReview...v2_on_model_o/
e4stw00t is online now
