Can't get rid of mouse acceleration [Help] - Overclock.net - An Overclocking Community
post #1 of 23 (permalink) Old 11-04-2019, 11:31 AM - Thread Starter
SpirosKGR's Avatar
Rep: 0
Hello guys, why i still have mouse acceleration? I am using mousemovement recorder from the markc to test.
@ 1000hz more red/green lines than
@ 500Hz
https://imgur.com/a/V1rZieS
I tried this test with 1000hz and 500hz but i got pretty much same pretty much results
___________________
What i tried so far.
• * Mouse Options * *
> I set my mouse speed to 6/11,
> turned off the EPP,
> Dactivated the acceleration in the mouse driver
~ Bios Options:
Cpu @ stock
[email protected] only
C states Auto
Intel Speedstep ✓ E N A B L E D
Intel TurboBoost ✓ E N A B L E D
Intel SpeedShift X D I S A B L E D
xhci hand off X D I S A B L E D
My motherboard has only usb 3 ( 3.1 ) usb ports so i dont have any usb 2.0 to test with it.
I am using this port for the mouse:
- EndgameGear XM1 ( Firmware 1.88 - latest )
________________________________
I tried this test with and without markc fix installed and ....... same results :/
I tested this with a Logitech G102, G305..... same results.
i tried this test with different dpi steps ( like 400 800 1000 etc ) and...... got same results.
I tried this test with different surfaces ( Cooler master Shift.RX medium, Steelseries Qck, Razer Goliathus )... same
I tried different kinds of movements, i didn't hit the screen's edge margin or something, i was moving the cursor only in the middle of the screen.
[img] https://i.imgur.com/lbFSbEQ.png [/img]
_________________
-- - What i am using,
Windows 10 LTSB - fresh installed up-to-date
Windows 10 1903 - fresh installed up-to-date
Power Plan: High Performance
Display settings: 1920X1080p, 100%
Refresh rate: 75Hz
-- - Hardware Specs,
i7-8700K stock
ASRock Phantom Gaming ITX/AC
16GB Crucial Ballistix SportLT 3200/16
Sapphire RX580 pulse
Corsair SF600
Samsung 840pro 128, 850evo 500GB
Corsair H110 AIO #arcticP12
What can i do now?
Motherboard issue?
Software/bios wrong setup?
Mouse problem?
SpirosKGR is offline
post #2 of 23 (permalink) Old 11-04-2019, 11:34 AM
The last VRM burner
Rep: 47 (Unique: 27)
Uninstall any extra software for your mouse, including firmware from device manager.
PC for all
(23 items)
i7 5775c @4.2GHz/3.8GHz
MSI Z97 MPower
Iris Pro 6200 1300MHz
F3-2400C11D-16GAB Samsung Rev. Q
Corsair MP510
Samsung Evo 860
Seasonic Focus Plus 750W
Artcic Liquid Freezer II 360mm
Front Arctic P14 PWM PST x2
Top Arctic P14 x2
Back Arctic P12
LianLi 330X
Operating System
Windows 10 64-bit Pro
Samsung C24FG73FQUX
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red Silent + 1.6x6mm o-rings
Mouse
SteelSeries Rival 600
Mouse
Tiger Gaming Arc teflon mouse feet
Mousepad
Artisan FX Raiden
Audio
Audio in Motion SC808 + MUSES8820 + 2x 2xLME49990
Audio
AKG M220
Other
NZXT Hue+
Other
Mayflash F300 Arcade Stick
BroadPwns is online now
post #3 of 23 (permalink) Old 11-04-2019, 11:43 AM - Thread Starter
SpirosKGR's Avatar
Rep: 0
Unfortunately i tried that, also i tried the following:
a) Format, fresh win installation
b) markc acceleration fix
c) no extra mouse drivers
d) > mousemovementrecorder ... same results
post #4 of 23 (permalink) Old 11-04-2019, 11:46 AM
Graphics Junkie
UltraMega's Avatar
Rep: 59 (Unique: 53)
Install Logitech setpoint. From setpoint you should be able to turn off mouse acceleration. Setpoint is the software for all Logitech mice.
4K Rig
(7 items)
Intel 7700k @4.2ghz
Zotec 1080 Ti
16GB 3200mhz DDR4
250GB nvme + 500GB SSD + 4TB HDD
Samsung 4K 65 inch TV
Pixio PX276 27inch 144Hz 1ms 1440p
Audio
Sound Blaster z
UltraMega is offline
post #5 of 23 (permalink) Old 11-04-2019, 11:53 AM - Thread Starter
SpirosKGR's Avatar
Rep: 0
I tried that to. Now i m using the endgame xm1 @UltraMega
post #6 of 23 (permalink) Old 11-04-2019, 12:21 PM
Graphics Junkie
UltraMega's Avatar
Did you disable "enhance pointer precision" in windows?
4K Rig
(7 items)
Intel 7700k @4.2ghz
Zotec 1080 Ti
16GB 3200mhz DDR4
Audio
Sound Blaster z
post #7 of 23 (permalink) Old 11-04-2019, 12:38 PM - Thread Starter
SpirosKGR's Avatar
Rep: 0
The first thing i did ( every time )
post #8 of 23 (permalink) Old 11-05-2019, 06:28 AM
Straszy's Avatar
Rep: 9 (Unique: 7)
Delete pls
Straszy is offline
post #9 of 23 (permalink) Old 11-05-2019, 06:58 AM
numberfive's Avatar
Rep: 22 (Unique: 12)
it is the same when you move your mouse strictly within the edges of the mousetester (not the screen)?
what is up with the polling? its 80 then 1k then 80 again. do you try to move it as slow as possible?
numberfive is online now
post #10 of 23 (permalink) Old 11-05-2019, 10:36 AM - Thread Starter
SpirosKGR's Avatar
Rep: 0
I tried all of that
Tags
endgame , markc , mouse acceleration , mouse movement recorder , xm1
