mouse responsiveness help - Overclock.net - An Overclocking Community
post #1 of 34 (permalink) Old 12-05-2019, 10:22 PM - Thread Starter
Aymanb's Avatar
Rep: 12 (Unique: 11)
Hi guys.
I've noticed my headphones/soundcards etc. makes MASSIVE difference on my mouse responsiveness. e.g. when I use the hyperX usb soundcard for my headphones, my mouse is obviously still good, but if I just use my soundcard in the pc instead of the USB one, the responsiveness is much much smoother, but then my microphone doesnt work.
Obviously both my soundcards are related to USB - which my mouse also is, so I'm guessing the clash starts there.
Do you have any special settings for USB? I have default windows 10.
I dont really lag or anything, one option is just much more responsive than the other. Easier to aim and flick accurately etc.
Aymanb is offline
post #2 of 34 (permalink) Old 12-05-2019, 10:36 PM
Turtle Rig's Avatar
Rep: 4 (Unique: 4)
Quote: Originally Posted by Aymanb View Post
Hi guys.
One thing I can think of quickly is to get a USB 3.0 Hub connect that to PC then connect your audio ***** and the problem will probably be solved.
INTEL 10980XE @ NO STOCK
GIGABYTE X299X AORUS MASTER
GIGABYTE WF RTX 2080
CORSAIR DOMINATOR PLATINUM RGB @ 64GB 3200 CL16 QUAD CHANNEL B-DIE
CORSAIR MP510 960GB M.2 GEN 3 SAMSUNG 950 PRO M.2 500GB 850 PRO 500GB CRUCIAL M4 500GB LaCie EXTERNAL 2TB PORSCHE DESIGN & 500GB eSATA
CORSAIR AX1600i TITANIUM @ CORSAIR 330r BLACKOUT EDITION CASE
CORSAIR H115i PRO RGB @ NOCTUA NF-14's INTAKE NF-14 EXHAUST NF-P12
AOC 40" CURVED 4k LG 55" C9 OLED G-SYNC 120HZ
Keyboard
LOGITECH 915 LINEAR WIRELESS
Mouse
LOGITECH G PRO WIRELESS
Mousepad
STEELSERIES SMALL
Audio
LOGITECH G935 WIRELESS SCARLETT 2i2 AUDIO INTERFACE KRK ROKITS 10" & SENNHEISER HD 650 & 4.5.0 BTNC SL GRAND 88 Sonar Producer
Turtle Rig is offline
post #3 of 34 (permalink) Old 12-05-2019, 10:47 PM - Thread Starter
Aymanb's Avatar
Any usb 3.0 hub? or does it need special features?
What about if my keyboard has an USB input. Wouldnt that work as a "hub" ?
Aymanb is offline
post #4 of 34 (permalink) Old 12-09-2019, 08:26 AM
NDUS's Avatar
Rep: 1 (Unique: 1)
99% of the time this kind of thing is placebo. Use mousetester with your onboard audio and your audio card, and if there is no difference, there you go.
If you find a difference, you could try putting your audio card into MSI mode - it is conceivable that your onboard mobo audio would be in MSI while your audio card wouldn't.
NDUS is offline
post #5 of 34 (permalink) Old 12-09-2019, 10:04 AM
Turtle Rig's Avatar
Rep: 4 (Unique: 4)
Get Anker 4 port hub.. only 7 bucks. Things start not playing nice as they share the same ***** USB connection with system. Try a different port or front port. Also as I said then Anker 4 port 2 feet cable,, I got two of them.
Keyboard
Mouse
Mousepad
STEELSERIES SMALL
Audio
post #6 of 34 (permalink) Old 12-09-2019, 10:15 PM
gunit2004's Avatar
Rep: 10 (Unique: 10)
I had a similar situation. Needed a way to use my Antlion Modmic microphone (3.5mm connector)
- Onboard Realtek controller on the motherboard made mouse feel laggy as hell, so that was a no go.
- Bought a cheap SABRENT USB audio dongle and simply plugging that audio dongle into my system caused laggy feel, so that was a no go.
In the end I just gave up on using the Antlion Modmic and started using a Samson Meteor mic (also USB) I had laying around and that works flawlessly.
Still don't know the cause to this day lol.
gunit2004 is offline
post #7 of 34 (permalink) Old 12-22-2019, 11:22 PM
r0ach's Avatar
Rep: 168 (Unique: 109)
No, it is not "placebo". Any USB junk you plug in besides the mouse itself, the worse mouse movement gets. The mouse - a real-time, mission critical device - should have it's own interface instead of being lumped in to some poorly thought out expansion port populated by all kinds of junk, much of which doesn't even require real-time performance.
Mouse Input Lag BIOS & Windows Optimization Guide
too many personal messages to reply to
r0ach is offline
post #8 of 34 (permalink) Old 12-22-2019, 11:47 PM
TranquilTempest's Avatar
Rep: 79 (Unique: 64)
Windows is not a real time operating system. There is no setting you can change or interface you can use to make it one, you'd have to completely rewrite the OS. Besides, interrupt endpoints already have priority in the USB stack; even if you have some massive file transfer from a thumb drive completely filling the pipe, it's still going to check the mouse input first in each USB frame.
TranquilTempest is offline
post #9 of 34 (permalink) Old 12-23-2019, 12:12 AM
r0ach's Avatar
Yes, we all know Windows is not a real-time OS. That doesn't mean performance isn't degraded by loading up the USB ports with junk. If your age is like 20, in the old days I seem to recall many people's PC couldn't even handle things like 1000 hz polling rate - maybe even 500hz too, but I forget - so the original USB draft probably didn't even intend to support things like that. Stop making up excuses for a hardware and OS software industry who only really cares about performance of things like webservers even though video games are a bazillion dollar industry now. Mice should have their own interface period.
r0ach is offline
post #10 of 34 (permalink) Old 12-23-2019, 12:47 AM
You're demanding something that won't fix the problem, because you're assigning blame on the USB interface, rather than on windows itself, which is where the blame actually lies. USB with 1ms polling is already lower latency than PS/2, just because the transfer rate of PS/2 is slow enough it takes longer than 1ms to send a single report.
