Why is there zero discussion about Logitech G-Hub permanently destroying mouse response? - Overclock.net - An Overclocking Community
post #1 of 99 (permalink) Old 01-07-2020, 01:28 PM - Thread Starter
r0ach's Avatar
Rep: 176 (Unique: 115)
So, I have always said that anytime you install mouse software and save settings to the mouse, it always gives you a wildly different result each time whether it's Logitech or some other company's software. Even if you're saving a setting of 800 DPI, sometimes it will feel slower and lagging behind, other times faster. It's like the method of writing data to the mice these companies are using is completely incapable of any deterministic behavior WHATSOEVER.
It's ALWAYS been like this. But this phenomenon with Logitech's new G-hub software is exponentially worse than pre-G-hub software where even a caveman should be able to tell. The results should be easily quantifiable if anyone wants to actually test it (QVC). Simply take a brand new mouse like a G302 fresh out of the box that's never been exposed to any form of Logitech software (the mouse controls great fresh out of the box), run it through whatever benching/diagnostics, then do the act of just plugging the mouse in to another computer with G-hub already installed (without even changing a single setting, just plugging it in then unplugging it). Then after you unplug it, it will feel like an entirely different mouse that you will NEVER recreate the fresh out of the box factory movement.
You will be permanently STUCK with inferior cursor control compared to what it shipped with from the factory. This behavior is far easier to notice on AM010 sensors because the sensor really has no positive quality at all besides hair trigger sensor response being about the closest modern thing you can get to a MLT04 in that regard. It's more difficult to notice on a 3366, but the same thing still happens. You can attempt to re-upload new settings to the mouse over and over and sometimes it will get close to how it was from the factory, but generally never quite as good.
I now have to buy a new G302 simply because installing the software permanently destroys the mouse, never capable of getting it back to factory performance state.
Mouse Input Lag BIOS & Windows Optimization Guide
too many personal messages to reply to
r0ach is offline
post #2 of 99 (permalink) Old 01-07-2020, 05:47 PM
SmashTV's Avatar
Rep: 59 (Unique: 46)
MX518 Legendary
Nixeus Revel
Logitech G603 (91g)
Allsop Raindrop XL
Razer Goliathus Speed
SmashTV is offline
post #3 of 99 (permalink) Old 01-07-2020, 05:57 PM
umeng2002's Avatar
Rep: 175 (Unique: 111)
I reinstalled Windows 10 recently, and I was looking at Logitech Gaming Software updates. I saw that G-Hub software, but I googled it and saw people said it was worse than LGS, so I just installed LGS... even if it's no longer updated.
AMD Ryzen 2700X
Asus Prime X470-Pro
EVGA GeForce RTX 2070 XC Ultra
TeamGroup T-Force 16 GB (2x8) Pro Dark (B-die TDPGD416G3200HC14ADC01)
ADATA XPG SX8200 Pro 512GB NVMe
Seasonic Focus Plus Platinum SSR-750PX
Corsair H80i (not V2 or GT)
LG 34UC80-B
Keyboard
Logitech G413
Mouse
Logitech G503 RGB
Audio
Creative SoundBlaster Z (OEM)
umeng2002 is offline
post #4 of 99 (permalink) Old 01-07-2020, 06:36 PM
I Love this Hobby!
Gunderman456's Avatar
Rep: 612 (Unique: 504)
I just bought a Logitech G502 Hero and the G-Hub executable has been staring me in the face for a few days now and I keep shying away in trepidation.
I would like to get the 3 notch side RGB working, customize the rest of the RGB as well as set up the DPI and actually use and save 5 profiles but I'm not brave enough.
Not only do I not trust the software to run the mouse effectively but it might just affect smooth play in games. There are many horror stories out there.
Can anyone quell these fears?
-Guide to 1st Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...ing-guide
-Guide to 2nd Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...e-fan-mod
Fast n' Cheap
(17 items)
Bit'O'Heaven
(16 items)
RYZEN 7 3700X
ASUS TUF GAMING X570-PLUS
MSI Radeon RX 5700 XT
G.SKILL Ripjaws V Series 32GB (2x16GB) DDR4 3600 16-19-19-39 CL 16 1.35V
Corsair Force Series Gen.4 PCIe MP600 500GB NVMe M.2 SSD
Seagate BarraCuda ST3000DM008 3TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" HDD
Optical Drive
LG 16X SATA Blu-Ray Internal Rewriter with 3D Playback and M-DISC Support BH16NS40
Fractal Design Ion+ 860P 80 PLUS Platinum Certified 860W Full Modular
Noctua NH-D15
Veddha GriderCase alpha V1
Operating System
Win 10 Pro 64bit
Nixeus EDG 27" IPS Freesync 1440p 144Hz
Keyboard
Redragon K589 SHRAPNEL RGB Mechanical Keyboard
Mouse
Logitech G502 Hero
Mousepad
ALLSOP Redmond Mouse Pad
Audio
Cambridge Soundworks 5.1
Other
PulseLabz Challenger Gaming Chair
Intel i7 4770k @ 4.5GHz
Asus Maximus VI Rog Gene
Gigabyte AMD R9 290 @ Core 1160MHz & Memory 1350MHz
G.SKILL Trident X DDR3 16GB 2400MHz
Samsung 840 PRO 256GB
Seagate Barracuda 7200.14 3TB
Optical Drive
Pioneer Black Blu-ray 16X BD-R 2X BD-RE
EVGA SuperNOVA G2 1300W 80PLUS Gold Fully Modular
Corsair H60 Push/Pull
PC-JMK5-Cool 5 Open Frame Case
Operating System
Win 7 Pro 64bit
Samsung 245BW 24" 1200p 60Hz
Keyboard
Logitech G15
Mouse
Logitech MX518
Mousepad
Corsair Vengeance MM200
Audio
Yamaha HTR-5830 Polk Audio 3.0
Intel Core i5-3570K @ 4.6GHz
ASRock Z77E-ITX mITX
Sapphire AMD HD 7990 @ Clock 900MHz & Memory 1100MHz
G.SKILL Ripjaws X DDR3 8GB 1600MHz @ 1866MHz
Crucial SSD CT128M4SSD3 128GB mSATA SATA III 6GB
Seagate Barracuda HDD 1TB
Optical Drive
LG DVD R/W
Corsair Professional Series Gold AX850 Fully Modular
Corsair Cooling Hydro Series H100
BitFenix Prodigy Mini-ATX Black Case
Operating System
Win 7 Pro 64bit
Samsung TV 52"
Keyboard
Logitech K330 Wireless
Mouse
Logitech M215 Wireless
Mousepad
Audio
Yamaha RX-V681 PSB/PolkAudio 5.1
Gunderman456 is offline
post #5 of 99 (permalink) Old 01-07-2020, 06:59 PM
umeng2002's Avatar
Will the LGS software work with the Hero version?
AMD Ryzen 2700X
Asus Prime X470-Pro
LG 34UC80-B
Keyboard
Logitech G413
Mouse
Logitech G503 RGB
Audio
post #6 of 99 (permalink) Old 01-07-2020, 07:17 PM
jayfkay's Avatar
Rep: 34 (Unique: 29)
jayfkay is offline
post #7 of 99 (permalink) Old 01-07-2020, 07:33 PM
Facepalm
Falkentyne's Avatar
Rep: 442 (Unique: 307)
I trust r0ach when it comes to mice. That being said, I'm not installing G-hub unless someone pays me.
[email protected] ghz, RX Vega 64, 32GB DDR4, Gigabyte Aorus Master, Seasonic Platinum 1000W, Corsair 760T
Alt: MSI GT73VR Throttlebook with 7820HK @ 4.7 ghz, GTX 1070 MXM TDP mod to 230W, 32 GB RAM
Quote: Originally Posted by sakete View Post
Well, I want you to know I have an academic degree in speculation.
Falkentyne is offline
post #8 of 99 (permalink) Old 01-08-2020, 01:19 AM - Thread Starter
r0ach's Avatar
I have not studied the differences in these softwares much, but If I remember correctly, the default state of LGS was not using a "persistent profile" and G-Hub seems to do something differently, possibly having them as a default setting. So there's a few changes between the two if people are trying to identify possible differences.
Using LGS is not really a cure, though. It still gives you the wildly, non-deterministic mouse settings each time you hit save to upload a new profile to the mouse. I don't know if it's generating different DPIs each time, or doing something else entirely, but everything from cursor sensitivity, speed, to feeling of a dead zone or lack thereof completely changes each time. This is why I believe lots of pros have gravitated towards Zowie mice. Due to being driverless, they're not exposed to this issue. Even if people don't know the issue exists, they just wind up with a better, more consistent experience because they're unable to gimp their mouse with non-deterministic software.
Unless Logitech can fix this issue (they likely have no idea where to even start), they'll likely have to go driverless too - at least for the actual performance, non-casual line - if they want to compete in the big leagues. Then you can also remove other likely problematic things such as the mouse identifying itself as a mouse+keyboard to Windows at the same time.
r0ach is offline
post #9 of 99 (permalink) Old 01-08-2020, 02:51 AM
mfw
ToTheSun!'s Avatar
Rep: 503 (Unique: 234)
I thought it was because of sponsorships and legendary mouse shapes, but I guess it's because of non-deterministic profiles saved to a mouse's internal memory.
But I agree LGS is not a proper cure; Chlorpromazine is.
Intel 6700K
Asus Z170i Pro Gaming
Gigabyte 2070 Super Windforce OC
G.skill Trident Z 3200CL14 8+8
Samsung 850 EVO 1TB
Crucial M4 256GB
Corsair SF600
Noctua NH C14S
Fractal Design Core 500
Operating System
Windows 10 Education
ViewSonic XG2703-GS
Keyboard
Vortex Race 3 RGB
Mouse
Glorious Odin
Mousepad
SteelSeries QcK+
Audio
Fiio E17K v1.0 + Beyerdynamic DT 1990 PRO (Dekoni pads)
ToTheSun! is online now
post #10 of 99 (permalink) Old 01-08-2020, 03:35 AM - Thread Starter
r0ach's Avatar
And here comes the avalanche of Windows 10 noobs.
r0ach is offline
