Thoughts on Logitech G703? Powerplay mouse pad? - Overclock.net - An Overclocking Community
post #1 of 11 (permalink) Old 01-25-2020, 07:26 AM - Thread Starter
To The Game
Chargeit's Avatar
Rep: 292 (Unique: 198)
Hello,
I'm looking to replace my G700s (right over 5 years old). I've looked at a few options and the mouse that best fits what I want in a mouse seems to be the G703 (outside the built in battery). What are your thoughts on the G703? Is the charging Powerplay mouse pad worth it at $120?
My usage,
90% general pc usage
5% photo/video editing
5% gaming
What I want in a mouse,
Wireless (No wires other then charging)
Designed for right handed use (no ambidextrous).
Battery life that lasts 24 hours min at 1000 polling rate.
1000 polling rate.
Optical sensor.
2 programmable side buttons.
Nothing too crazy with the physical design. I'm not a huge fan of the visuals of a lot of newer hardware and I think they'll age poorly. I intend to use this mouse for at least 4 or 5 years.
As for what games I play, I tend to play co-op online games such as RDR2, Gta v, Far Cry, The Division, GRWL (old one), Diablo 3, Skyrim. I don't game often and might go weeks without gaming. When I do game it's usually a co-op with my friends.
I have no budget though I don't want to waste money.
Thanks,
*Ok guys, I just ordered a G604. Going to give that a try and see how I like it. I own two G602 so I have an idea of what to expect though lets see how the redesign does.
Chargeit is offline
post #2 of 11 (permalink) Old 01-25-2020, 10:09 AM - Thread Starter
To The Game
Chargeit's Avatar
Chargeit is offline
post #3 of 11 (permalink) Old 01-25-2020, 11:38 AM
SmashTV's Avatar
Rep: 58 (Unique: 45)
I don't think it's worth it. It's small-ish and costs a ton.
When you look at the battery loading mice, they get months of battery life. Unless you're really keen on the tech and plan to stick with it, I wouldn't bother with the Play mat.
Even the ones with the built in battery usually get a few days to a week or two. Charging isn't as bad as it used to be!
SmashTV is offline
post #4 of 11 (permalink) Old 01-25-2020, 12:22 PM - Thread Starter
To The Game
Chargeit's Avatar
When you look at the battery loading mice, they get months of battery life. Unless you're really keen on the tech and plan to stick with it, I wouldn't bother.
Issue I'm having is finding a form factor that looks like it will work for me. While having 1000 polling rate, optical sensors and being right handed. Would be nice if they came out with an updated version of this G700s with optical sensors but doesn't looking like that's happening.
Yeah the size is kind of 50/50. My main mice are a G700s at home and a G602 at work so I'm used to fairly large mice.
I'm generally against built in batteries since they kind of represent planned obsolescence though in the case of a mice I do see where it would help keep the weight down.
I'll look around some more. Not in a huge hurry though when unplugged my G700s is starting to wake the computer. I was able to confirm it was the G700s by turning it off and having the computer stay in sleep mode.
Chargeit is offline
post #5 of 11 (permalink) Old 01-25-2020, 12:44 PM
OCN is bad civilization
Melan's Avatar
Rep: 112 (Unique: 86)
Take a look at G604.
Melan is offline
post #6 of 11 (permalink) Old 01-25-2020, 01:01 PM - Thread Starter
To The Game
Chargeit's Avatar
Yeah I'm checking that one out right now.
Use a G602 at work. I like it overall but when I tried using the G602 at home something about the angle of my setup caused me to hit the side buttons a lot and I couldn't get used to it. Outside that I only use two of the side buttons for page up/page down making the other buttons kind of in the way.
Though looking around the G602 might be my best option.
The more you learn about what you like and dislike the harder it becomes to make decisions when buying stuff.
Ok, think I'm going to try the G604. While I'm not a huge fan of all the extra buttons I like that it's 1000 polling rate, optical sensor and has an adjustable mouse scroll wheel. Looking over the stats it should be about 20g lighter then my G700s or G602 and offer a lot more battery life compared to my G700s.
Chargeit is offline
post #7 of 11 (permalink) Old 01-25-2020, 01:31 PM
Rep: 3 (Unique: 1)
I love my G703. I charge it maybe once every 3 days? lol.
Played CSGO at a high level and frankly, I find the tracking better than my old Razer Deathadder or the numerous Finalmouse/Logitech mice I've ran through, as well as no wire weight or having to deal with stupid cord bungees (or taping the wire to the wall lol)
acoustic is offline
post #8 of 11 (permalink) Old 01-25-2020, 01:37 PM - Thread Starter
To The Game
Chargeit's Avatar
I just ordered the G604. I'll keep the G703 on the back burner in case I don't like the G604.
Fun fact, I ordered a G703 a few days back from Amazon and they sent me a G203 instead. It did work out for me since I hadn't realized the G703 had a built in battery which I'm not a huge fan of. Though if the G604 doesn't work out I'll give the G703 another try.
Chargeit is offline
post #9 of 11 (permalink) Old 01-25-2020, 02:33 PM
mfw
ToTheSun!'s Avatar
Rep: 447 (Unique: 218)
I have both the Powerplay mat and the G703. IMO, it's not worth the $100. Enable USB charging while the PC is off and let it charge when you're away. You'll have a 25-30h mouse without having to constrain yourself to a miniscule mousepad (and spending the extra money).
I bought it because of the novelty, but it quickly proved to be a pointless addition.
Intel 6700K
Asus Z170i Pro Gaming
Gigabyte 2070 Super Windforce OC
G.skill Trident Z 3200CL14 8+8
Samsung 850 EVO 1TB
Crucial M4 256GB
Corsair SF600
Noctua NH C14S
Fractal Design Core 500
Operating System
Windows 10 Education
ViewSonic XG2703-GS
Keyboard
Vortex Rac3 RGB
Mouse
Glorious Odin
Mousepad
Gigabyte AMP500
Audio
Fiio E17K v1.0 + Beyerdynamic DT 1990 PRO (Dekoni pads)
ToTheSun! is offline
post #10 of 11 (permalink) Old 01-25-2020, 05:02 PM - Thread Starter
To The Game
Chargeit's Avatar
Yeah with the hours some of these mice are now claiming it does seem to be less of an issue then it is with this G700s that might get 5 hours at 1000 polling rate.
Pad isn't that small. Larger then the one I'm using right now. Though I like to use my pad in portrait which gives this pad more depth. Also hold my mouse more fingertip style so I don't require too much space for movement.
Chargeit is offline
