Best Wireless Mouse at the moment? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 30 (permalink) Old 02-04-2020, 06:37 AM - Thread Starter
Hannes969's Avatar
Rep: 0
Hello
ok thank you, but right now i feel a little bit of a different if the mouse software ist active or not?
Also you hear an plug in sound when i close the lgs and also open it, because on the hadware manager there is also logitech virtual mouse in the list.
Hannes969 is offline
post #12 of 30 (permalink) Old 02-04-2020, 02:20 PM - Thread Starter
Hannes969's Avatar
Rep: 0
does the logitech g hub adds latency ?
post #13 of 30 (permalink) Old 02-04-2020, 02:21 PM
LTSC Consiglieri
skupples's Avatar
Rep: 656 (Unique: 350)
idk, never installed it.
mice either work out of the box, or go back to the store.
ghub is 90% RGB tweaking. 10% buttons and DPI re-configuring.
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
skupples is online now
post #14 of 30 (permalink) Old 02-05-2020, 03:35 AM - Thread Starter
Hannes969's Avatar
Rep: 0
Hello
After configuring the right buttons, should i deinstall g hub and also deinstall the virtual g hub mouse and virtueal g hub keybaord in the device manager or not ?
post #15 of 30 (permalink) Old 02-05-2020, 04:19 AM
Rep: 3 (Unique: 1)
I use a G703 wireless. I love it - the lack of cable weight and not having a stupid bungee on my desk is liberating. I'm a mouse freak (I have a large collection..) and I'm pretty stuck on this 703.
acoustic is offline
post #16 of 30 (permalink) Old 02-05-2020, 04:50 AM
deepor's Avatar
Rep: 483 (Unique: 328)
Quote: Originally Posted by Hannes969 View Post
Hello
I would definitely uninstall it. I don't like that it creates these weird devices in device manager.
About LGS, that one seems fine and I keep it installed, but I disabled its auto-start at boot. I start it manually if I want to tweak something on the mouse.
deepor is offline
post #17 of 30 (permalink) Old 02-05-2020, 08:00 AM - Thread Starter
Hannes969's Avatar
Rep: 0
So you also deinstall manually the logitech g hub devices in the device manager ?
post #18 of 30 (permalink) Old 02-05-2020, 09:58 AM
deepor's Avatar
Don't they get removed when you uninstall G Hub?
I didn't install G Hub on my current Windows installation so I don't know.
deepor is offline
post #19 of 30 (permalink) Old 02-06-2020, 04:12 AM - Thread Starter
Hannes969's Avatar
Rep: 0
Heyy
Ok after deinstalling G Hub they get removed. Thx
Right now i bought the logitech G703 Lightspeed and i love it. The feeling without cable is way better than i thought.
I also dont feel any input lag or anything like that. And i am very sensitive at this things.
Do you know any tips for max performance on the wireless connection.
Right now i have the usb cable plugged into the usb 2.0 and put the wireless dongle right infront of my mousepad/mouse.
post #20 of 30 (permalink) Old 02-06-2020, 05:28 AM
deepor's Avatar
I did the same as you on my G305: I've used that extension cable that came with the mouse and put the dongle on my table in front of the mouse pad. I don't know what else you can do to help the mouse.
About checking how good the wireless works, I tried putting my phone playing Youtube next to the mouse while I experimented with the "Mouse Tester" tool. The connection still looked fine, the mouse could still send updates at 1000Hz. I don't know how else to test for wireless problems.
deepor is offline
